Old 16th June 2008, 04:18 AM   (permalink)
Question USB instead of parallel port
I am a beginner in micro-controller programming.
I built a programmer that uses parallel port to program atmega16 micro controller and is working perfectly but I have a laptop and it doesn't have any parallel ports. I want to use USB to program my micro-controller. HOw can it be implemented.
kashthealien is offline   Reply With Quote
Old 16th June 2008, 04:36 AM   (permalink)
You can't build USB programmers. USB Is very difficult to work with for hobbiests (and even engineering companies). You'd have to buy one.
You might have some hope if you had a serial programmer, but parallel...probably not since it's so old.
NO, that picture isn't me so don't bother asking if we can be friends.
Old 16th June 2008, 05:08 AM   (permalink)
Spend the money and get yourself an Atmel Dragon programmer/debugger. You only have to buy it once (around $75) and then the pain is over. It's a great programmer and debugger. Does every programming/debugging mode that is available for AVRs. Well worth the $$.
There's a list of compatible chips there for the Dragon. It doesn't work on many of their older chips, which was a bit of an annoyance for me. But I have my old STK-500 for those...
futz is online now   Reply With Quote
Old 16th June 2008, 07:25 AM   (permalink)
Unhappy Thank U
My laptop doesn't have even a serial port.
It has 4 USB ports and an express port thats all
and I m just a student cant afford $75
Old 16th June 2008, 07:39 AM   (permalink)
Then use a serial programmer & use USB-RS232 converter.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline   Reply With Quote
Old 16th June 2008, 07:41 AM   (permalink)
Have you seen the Junebug programmer/tutor pcb, from BlueRoomElectronics [aka Bill]
blueroomelectronics - Smart Kits Build Smart People
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 16th June 2008, 07:45 AM   (permalink)
Hi Eric OP is an ATMEL Freak
Gayan
My Website
Old 16th June 2008, 07:49 AM   (permalink)
Morning Gayan,
A little missionary work may help him to convert to PIC's..
Eric
PIC tutorials:
Old 16th June 2008, 09:35 AM   (permalink)
Thank u, I guess RS232 will help
Old 16th June 2008, 01:16 PM   (permalink)
It is easy to wire up almost any AVR to get USB connectivity.
Your request for a USB programmer is here:
USBasp - USB programmer for Atmel AVR controllers
L.Chung
eblc1388 is offline   Reply With Quote
Old 16th June 2008, 01:22 PM   (permalink)
thanx i got the rs232 connected it to the serial port.
just have to finish the software part
Old 16th June 2008, 03:10 PM   (permalink)
Some usb to rs232 do not use some of the comm lines required, but I hear that the more pricey ones do.
Krumlink is offline   Reply With Quote
pin three on parallel port Gaston Micro Controllers 13 23rd December 2006 07:52 PM
LCD to parallel Port to USB Overclocked Electronic Projects Design/Ideas/Reviews 1 5th December 2005 06:52 AM
Parallel port control port: is it Write Only or Read/Write elexhobby Electronic Projects Design/Ideas/Reviews 5 12th September 2005 12:01 PM
parallel port aibelectronics Electronic Projects Design/Ideas/Reviews 4 23rd August 2005 03:06 PM
Operate a relay from a PC port RS232 or Parallel port Eddie ESV Electronic Projects Design/Ideas/Reviews 2 12th June 2004 07:43 AM
