Hi!
I’m receiving a string of 10 digit number & I’m saving each number in 10 GP registers. After receiving the 10 digit number it will show the number in binary form. Problem is its working for first round & after no more work. Code:
LIST P=16F628A #include <P16F628A.INC> errorlevel -302 __CONFIG _CP_OFF & _DATA_CP_OFF & _LVP_OFF & _BOREN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT cblock 20h Read_Count,Enable,d1,d2,d3 endc cblock 30h Data1,Data2,Data3,Data4,Data5,Data6,Data7,Data8,Data9,Data10,Data11 endc org 0x0000 clrf STATUS goto Init_Ports org 0x0004 retfie ;********************************* ;Initialisation & setup the ports ;********************************* Init_Ports movlw 07h ;turn off comparators & make pins for GP movwf CMCON bsf STATUS,RP0 ;B1 movlw b'00000010' ;RB1 = Input & others output movwf TRISB movlw b'00000000' ;make all portA ports outputs movwf TRISA bcf STATUS,RP0 ;B0 nop nop Init_USART bsf STATUS,RP0 ;B1 movlw b'00100100' ;Enable TXEN,High Baud rate movwf TXSTA movlw .25 ;set Baud Rate = 9600 movwf SPBRG bsf PIE1,RCIE ;enable Recieve Interrupt Enable nop nop bcf STATUS,RP0 ;B0 nop nop clrf RCSTA movlw b'10010000' ;Enable SPEN,CREN movwf RCSTA bcf PIR1,RCIF ;recieve more reception nop nop Init_INTCON movlw b'01000000' ;GIE,PEIE movwf INTCON bcf PIR1,RCIF ;recieve more reception clrf PORTA clrf PORTB clrf Enable call Data_Clear goto Begin Data_Clear clrf Data1 clrf Data2 clrf Data3 clrf Data4 clrf Data5 clrf Data6 clrf Data7 clrf Data8 clrf Data9 clrf Data10 return ;****************************** ;Main program starts from here ;****************************** Begin movlw 30h movwf FSR movlw .11 movwf Read_Count ;load number of characters to be recieved Read_Loop call Read_CHR movwf INDF incf FSR,F decfsz Read_Count,F goto Read_Loop bsf Enable,0 goto Start Read_CHR btfss PIR1,RCIF ;is it a reception? goto Read_CHR bcf PIR1,RCIF movf RCREG,W ;yes,then take a copy of the character return Start btfss Enable,0 goto Start movf Data1,W ;display number1 andlw b'00001111' movwf PORTA call Delay movf Data2,W ;display number2 andlw b'00001111' movwf PORTA call Delay movf Data3,W ;display number3 andlw b'00001111' movwf PORTA call Delay movf Data4,W ;display number4 andlw b'00001111' movwf PORTA call Delay movf Data5,W ;display number5 andlw b'00001111' movwf PORTA call Delay movf Data6,W ;display number6 andlw b'00001111' movwf PORTA call Delay movf Data7,W ;display number7 andlw b'00001111' movwf PORTA call Delay movf Data8,W ;display number8 andlw b'00001111' movwf PORTA call Delay movf Data9,W ;display number9 andlw b'00001111' movwf PORTA call Delay movf Data10,W ;display number10 andlw b'00001111' movwf PORTA call Delay bcf Enable,0 clrf PORTA call Data_Clear goto Begin Code:
Private Sub Command1_Click() MSComm1.Output = Text1.Text & vbCr End Sub |
According to the datasheet page 82, Quote:
From your program code, PEIE is enabled but GIE is not. If it's not entering the ISR when the reception is completed, I think you don't need to do anything to INTCON register. But why not using the ISR upon the reception? Also, RCIF bit is read only, it's cleared when RCREG is read. I noticed there're some nop around the codes, which are unnecessary BTW, what do you mean it works for the first round and not after that? Only the first byte of data can be received correctly?
Superman returns..
I assume you are reading 11 bytes so it includes the carriage return. Apart from that your code looks fine. Are you leaving enough time in VB before sending the next block?
Mike. |
Hi bananasiong first I tested in ISR routine but didn't work so I shifted the whole program to main routine.After doing the code in the main it works for the first round.
First round is if I enter a 10 digit number ex: "1234567893" it will show the number in binary.When I again send this number it wont display & not working.Thats the problem. Last edited by Suraj143; 16th June 2008 at 03:39 AM. |
The only thing I can think of is that you are getting an overrun error. What happens if you add,
Begin clrf RCSTA movlw b'10010000' ;Enable SPEN,CREN movwf RCSTA movlw 30h movwf FSR movlw .11 movwf Read_Count ;load number of characters to be recieved Read_Loop call Read_CHR BTW, you should be receiving 11 bytes. Last edited by Pommie; 16th June 2008 at 03:59 AM. Reason: Added the clrf. |
Hi Mike I'll check that.I'm wondering why I use decimal 11 to receive 10 characters?
Thanks |
I added another instruction above. You need to receive 11 characters because your send 10 numbers and then a carriage return (vbCr).
Mike. |
Hi Mike nice news it worked nicely.Here is the edited ones.
Begin clrf RCSTA movlw b'10010000' ;Enable SPEN,CREN movwf RCSTA movlw 30h movwf FSR movlw .10 movwf Read_Count ;load number of characters to be recieved Read_Loop call Read_CHR movwf INDF incf FSR,F decfsz Read_Count,F goto Read_Loop call Read_CHR ;check the CR as well xorlw .13 btfss STATUS,Z goto Begin bsf Enable,0 goto Start So now I'm thinking a method to detect a character or a string without detecting a fix length. What about adding a small delay to expire the Read_CHR routine? |
The easiest way to fix this would be to always send 10 characters from your VB program,
Dim Temp As String
Temp = Text1.Text & "00000000000"
Temp = Left(Temp, 10)
MSComm1.Output = Temp & vbCr
End Sub
MSComm1.Output = Left(Text1.Text & "00000000000", 10) & vbCr
End Sub
Mike. |
Hi Mike I understood that VB method is easy. Thanks for that.
If I enter 123 & click the command button does it send “1230000000”? So the PIC software still detects the 10 digit string but the last seven digits it will save as “zeros” I think this method I can apply to send ASCII characters as well without getting stuck in the program. But consider I want to detect the string “1230” & save in GP registers for later use. So the balance zeros will add to the last zero in the string? So I miss that zero? |
In that case the best method would be to detect the CR.
Begin clrf RCSTA movlw b'10010000' ;Enable SPEN,CREN movwf RCSTA movlw Data1 movwf FSR Read_Loop call Read_CHR movwf INDF ;store it xorlw 0x0d ;is it CR btfsc STATUS,Z goto GotCR incf FSR,F movfw FSR ;get FSR xorlw Data1+d'11' ;got 11 characters? btfsc STATUS,Z decf FSR,F ;yes so prevent buffer overflow goto Read_Loop GotCR bsf Enable,0 goto Start If you send 1230 then the numbers will be in Data1-Data4 and Data5 will be CR (0x0d). Mike. |
Excellent code Mike.A clever thinking.I'm going to use it right now.Why I cant do that like you.mmmmm I must do lots of code stuff to get experience.
I got everything that I expected from you. Thanks again Mike |
Very nice Mike!
-BaC Quote:
Error: {Panic!} when trying to load: [reality shell]. kernel: "universe has been halted"... Information Underground |
| PIC USART-HyperTerminal problem.. | asp1987 | Micro Controllers | 17 | 8th April 2008 07:00 PM |
| PIC16F628A USART receiving problem | AWHF | Micro Controllers | 12 | 15th March 2008 04:25 PM |
| PIC18F252 USART problem | mikesmixes777 | Micro Controllers | 8 | 18th December 2007 02:27 PM |
| USART not receiving correct characters | HakBot | Micro Controllers | 27 | 9th October 2007 01:33 PM |
| URGENT!! 16F877 & USART & Interrupt & Recieve Problem | DaMieN | Micro Controllers | 0 | 18th September 2007 10:52 AM |
