Could you help me about my project? I dose real time voltage monitor ADC by PIC16F877 and send the data value to PC (serial port). It’ seems a big problem about the sampling rate? I’m comparing my project between boards (ETT16F877) with Oscilloscope but result error very much. Need you help me for suggestions? Below picture my soft code PIC and VB6.(Sorry I'm not good english )
CCS for PIC. #include <16F877.H> #define TxD PIN_C6 #define RxD PIN_C7 #define CLOCK_SP 10000000 #fuses HS #fuses NOLVP,NOWDT #fuses NOPROTECT #device ADC=10 #use delay (clock=CLOCK_SP) #use rs232(baud=9600,xmit=TxD,rcv=RxD) #use fast_io(A) #define Vbe 0.0048875855327468230694037145650049 // Vref/1023 (5/1023) void main(void) { int16 value; float volt; setup_adc_ports(0x82); // A0 A1 A2 A3 A5 E0 E1 E2 Ref=Vdd setup_adc(ADC_CLOCK_INTERNAL); // Clock RC set_adc_channel(0); // Read Analog input RA0 do{ value = Read_ADC(); delay_us(10); volt = Vbe*(float) value; printf("\n\r%f",volt); } while (TRUE); } Code VB6 Option Explicit Dim data As String Dim i As Variant Dim n As Variant Dim MyData As String Dim stime As Variant Dim sdate As String Private Sub cmdExit_Click() MSComm1.PortOpen = False End End Sub Private Sub Command1_Click() MSComm1.PortOpen = False End Sub Private Sub Form_Load() Dim oExcel As Object Dim oBook As Object Dim oSheet As Object Label4.Caption = " Data Save" Shape2.BackColor = vbGreen Shape2.BackStyle = 1 MSComm1.CommPort = 1 MSComm1.InBufferSize = 1024 MSComm1.OutBufferSize = 512 MSComm1.RThreshold = 1 MSComm1.Settings = "9600,n,8,1" MSComm1.PortOpen = True Timer3.Interval = 1000 Label6.Caption = Date Label5.Caption = Time If MSComm1.PortOpen = False Then Shape1.BackColor = vbRed Label2.Caption = " Disconnect to HW " End If MSChart1.ColumnCount = 1 MSChart1.RowCount = 30 MSChart1.chartType = VtChChartType2dLine MSChart1.Plot.Axis(VtChAxisIdY).ValueScale.Auto = False MSChart1.Plot.Axis(VtChAxisIdY).ValueScale.Minimum = 0 MSChart1.Plot.Axis(VtChAxisIdY).ValueScale.Maximum = 10 MSChart1.Plot.Axis(VtChAxisIdY).ValueScale.MajorDi vision = 10 MSChart1.data = data Timer1.Enabled = True Timer2.Enabled = False End Sub Private Sub Label3_Change() Open "C:\Voltage Detect " & Date$ & " .txt " For Append As #1 'Print #1, Date$ + Time$ + Label3.Caption 'Print #1, Trim$(Date$) + Trim$(Time$) + Trim$(Label3.Caption$) Print #1, Date$ + " " + Time$ + " " + Label3.Caption$ Close #1 End Sub Private Sub MSComm1_OnComm() On Error Resume Next If MSComm1.CommEvent = comEvReceive Then data = MSComm1.Input Label3.Caption = data Shape1.BackColor = vbGreen End If MSChart1.data = data For i = 1 To MSChart1.RowCount + 1 MSChart1.Row = i + 1 n = MSChart1.data MSChart1.Row = i MSChart1.data = n Next i MSChart1.Column = 1 MSChart1.Row = MSChart1.RowCount End Sub Private Sub Timer1_Timer() Shape2.BackColor = vbRed Shape2.BackStyle = 1 Timer2.Enabled = True Timer1.Enabled = False End Sub Private Sub Timer2_Timer() Shape2.BackColor = vbBlue Shape2.BackStyle = 1 Timer2.Enabled = True Timer1.Enabled = False End Sub |
Wave from by Oscilloscope. And result by txt file data.
06-07-2008 09:20:37 2.99 06-07-2008 09:20:37 2.98 06-07-2008 09:20:37 2.99 06-07-2008 09:20:37 2.98 06-07-2008 09:20:37 2.99 06-07-2008 09:20:37 2.98 06-07-2008 09:20:37 2.83 06-07-2008 09:20:37 3.23 06-07-2008 09:20:37 3.00 06-07-2008 09:20:37 3.01 06-07-2008 09:20:37 3.00 06-07-2008 09:20:37 3.01 06-07-2008 09:20:37 3.00 06-07-2008 09:20:37 3.01 06-07-2008 09:20:37 2.99 06-07-2008 09:20:37 3.01 06-07-2008 09:20:37 3.00 06-07-2008 09:20:37 3.01 06-07-2008 09:20:37 2.84 06-07-2008 09:20:37 2.91 06-07-2008 09:20:37 3.01 06-07-2008 09:20:37 2.99 06-07-2008 09:20:37 3.01 06-07-2008 09:20:37 3.00 06-07-2008 09:20:38 3.01 06-07-2008 09:20:38 3.00 06-07-2008 09:20:38 3.01 06-07-2008 09:20:38 3.00 06-07-2008 09:20:38 3.01 06-07-2008 09:20:38 3.00 06-07-2008 09:20:38 2.94 06-07-2008 09:20:38 2.99 06-07-2008 09:20:38 3.03 06-07-2008 09:20:38 3.02 06-07-2008 09:20:38 3.03 06-07-2008 09:20:38 3.02 06-07-2008 09:20:38 3.03 06-07-2008 09:20:38 3.02 06-07-2008 09:20:38 3.03 06-07-2008 09:20:38 3.03 |
Help me please
hi apple,
Could you explain in more detail. Are you saying the PIC program is causing the sampling 'error' or the VB6 program in the PC. Is it the 'accuracy' or the 'sampling rate' you are concerned about.? I dont write programs in 'C', but many members are expert in 'C' programming.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
If i will use PIC16F877 to do low cost scope. How are you think?
PIC16F877 , it can do the measurement is like a picture that at , press come to get ? , |
| Crazy scope | spuffock | General Electronics Chat | 28 | 25th August 2007 05:28 PM |
| 16f877 pic pin voltages when data is writing | uditha33 | Micro Controllers | 2 | 6th June 2007 03:26 AM |
| What is on the top of this scope? | Andy1845c | General Electronics Chat | 12 | 7th April 2007 03:10 PM |
| New scope | zachtheterrible | General Electronics Chat | 10 | 27th August 2006 02:23 AM |
| Rearranging data - 16F877 in assembler | atferrari | Micro Controllers | 3 | 1st December 2005 09:00 AM |
