Problems as below:
Connecting to MPLAB ICD 2 ...Connected Setting Vdd source to MPLAB ICD 2 Target Device PIC12F629 found, revision = Rev 0x10 ...Reading ICD Product ID Running ICD Self Test ...Passed MPLAB ICD 2 Ready Erasing Target Device... ...Erase Succeeded MPLAB ICD 2 Ready Programming Target... ...Validating configuration fields ...Erasing Part ...Programming Program Memory (0x0 - 0xB2) Verifying... ...Program Memory ICD0161: Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x1283, Val Read = 0x3FFF) ICD0275: Programming failed. MPLAB ICD 2 Ready Code:
ICDWarn0044: Target has an invalid calibration memory value (0x3FFF). Continue? ICD0161: Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x1283, Val Read = 0x3FFF) ICDWarn0044: Target has an invalid calibration memory value (0x3FFF). Continue? ( i already programmed 1 of my same pic (succeeded), this is the 2nd 1, what's wrong with it?) What is it about? Thanks... Last edited by nicholastyc; 5th June 2008 at 11:51 AM. |
That is the calibration for the internal RC oscillator. Unless you are using that oscillator and you need its full accuracy, you can ignore that warning.
sadly yes... i m using the internal OSC, i think i already configured the setting correctly.
why am i encounter this problem everytime i try to connect the ICD2? its works fine for 1 time...and 1 chip was successfully configured. |
Post the CONFIG lines of your program.
Hi, config line as below,
__CONFIG _CP_OFF & _MCLRE_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _BODEN_OFF & _CPD_OFF &_PWRTE_OFF |
Use MLCRE_ON and see what happens
| 15 second warning bug | Papabravo | Feedback/Comments | 5 | 29th May 2008 02:05 AM |
| C30 pointer warning - should be legal, but why the warning? | futz | Micro Controllers | 20 | 14th March 2008 07:27 PM |
| Car Reversing Warning | wetterfugal | Electronic Projects Design/Ideas/Reviews | 5 | 28th October 2007 04:50 PM |
| low battery warning | philba | General Electronics Chat | 17 | 2nd August 2006 01:59 AM |
| warning | zachtheterrible | Feedback/Comments | 2 | 11th February 2005 02:52 PM |
