Old 5th June 2008, 11:05 AM   (permalink)
Smile Important features to have on 18F4620 Board?
Well right now as far as electronics goes, I have been working on a little 18F4620 control board, and I have figured out what ports will do what:
PORTA Motor Control, LED output for Motor controls
PORTB Sensor Interaction/LED indicators
PORTC Sensor Interface?
PORTD Dunno?
PORTE Use E0,E1 E2 (E3 is reset, want to have that seprate) as LED indicators
Problem is, that I have a lot of pins and ports to work with (take that Basic s*** 2)
So I was wondering what should I do with Port C and Port D? I was thinking of using them and bringing the pins to a LCD board (I understand the basics of LCD's now ) and I am thinking that would be a good idea.
I have each port brought out to 2x5 headers (awesome idea by 3v0 on his boards) and I could easily change the function if needed. I have a HD74480 LCD so I can easily communicate with it, and I have already programmed a LCD with my uPICFAT to display "WHAT CHU TALKIN BOUT WILLIS" on it. I have also just started with INPUT commands too, and by taking data from an input and displaying it on the LCD (button input).
So what should I do with entire PORTC and PORTD?
www.crosstheroadelectronics.com for the uPICFAT (I got mine for free, the guy who sells them is a mentor on team 217 Thunderchickens who is visiting my HS today )
Krumlink is offline   Reply With Quote
Old 5th June 2008, 12:06 PM   (permalink)
3v0
The 2x5 port connector goes back a long way. They may have existed on the targets I used back in the mid 70's.
I think you are on the right track already. I would not try to use up the ports. Keep them available via the 2x5's so you can add functionality as you need it.
EDIT: On could argue that you do not need such a large chip. Given that you do not know what your final robot will look like I like the idea of the extra ports.
3v0 is offline   Reply With Quote
Old 5th June 2008, 01:00 PM   (permalink)
I was going to have Ports ABCD on 2x5 headers, and have E0,E1 E2 and E3 (E3 is reset) as dedicated LED's and E3 as a reset. I will then have seperate boards that go from the port I need (say, a PORT D LCD board).
Old 5th June 2008, 01:02 PM   (permalink)
I would definitely fit an LCD as it makes debugging so much easier. Breakpoints and single stepping are great until you get time critical stuff. For the rest of the ports, I agree with 3v0, keep them free until you need them.
What language are you using?
Pommie is offline   Reply With Quote
Old 5th June 2008, 01:17 PM   (permalink)
C programming language. I am looking for the Hitatchi 74480 pinout.
got it (awesome page for it) http://www.myke.com/lcd.htm
Old 5th June 2008, 01:25 PM   (permalink)
that might be the wrong LCD
Old 5th June 2008, 01:35 PM   (permalink)
That is the normal character based LCD data sheet. What makes you think it isn't?
Old 5th June 2008, 01:38 PM   (permalink)
I got confused a bit. I think I have a different LCD than that
Old 5th June 2008, 01:41 PM   (permalink)
There are LCD that have different connectors. Does yours have the 7*2 connector on the left hand side?
Like this,
Old 5th June 2008, 01:44 PM   (permalink)
OK. I have everything all figured out, and I really confused myself. I have the HD44780 LCD and how to interface with it. LOL.
Old 5th June 2008, 01:48 PM   (permalink)
Mine has the 16x1 header. It is a 16x2 LCD, and the uPICFAT does not utilize all 8 data lines, but I will have to use 2 ports to use the LCD (read write) if I wanted to use all 8.
EDIT: I have decided to utilitize all 8 data lines, taking up an entire port. I also have the option to change what module to use on it too. I then need a Read/write control, and a instruction/register select line.
Old 5th June 2008, 01:49 PM   (permalink)
But that pretty much requires dedicating pins on the PCB layout that might be needed for some other project.
I'm beginning to think that using a dedicated PIC as an LCD interface which supports SPI, I2C, or Serial connection to a host device might not be a bad idea. Then all you need is 1, 2, or 3 wires from any project board to connect to the LCD (and keypad perhaps?) when you need it.
Mike
<added>
The first general purpose PIC proto' board I designed (2003) had a 28 pin footprint within a 40 pin footprint which allowed me to use either type of chip on the same board. I wish I had had the foresight to install 10 pin dual row connectors for each port (great idea)...
Old 5th June 2008, 02:02 PM   (permalink)
I am making this on a radioshack perf board, because I wanted to be able to make this somewhat quickly. In the future I can make a PCB if this design works well.
I have come up with a sweet acronym as usual
ViPER
Versatile Programmable Experimental Robot
awesome eh?
Old 5th June 2008, 02:11 PM   (permalink)
ViPER
awesome eh?
Awesome indeed unless it starts to hiss.
Looking forward to seeing pictures.
Old 5th June 2008, 02:48 PM   (permalink)
3v0
I made a few LCD adaptor boards. It allows you to connect a 1x14/16 LCD to a standard 2x5 port in the 4 bit mode. No need to dedicate pins to the LCD if it is only used during debug.
It is single sided. The red line above R1 is a jumper.
I can post pdf's of the foil or the eagle files if anyone wants them. Not a difficult board to layout.
EDIT: R2_OPT and R3_OPT can be used in place of the 5K pot.
18F4620 Hlaf Bridge HPWM kalaman Micro Controllers 0 30th October 2007 01:24 PM
Please suggest a microController with these features. pkshima Micro Controllers 12 9th May 2005 12:06 PM
18F452 to 18F4620 Oznog Micro Controllers 0 8th March 2005 01:18 AM
Unused features? MrMikey83 Micro Controllers 1 24th February 2005 06:11 PM
new revisions----new features please!!!! urzalight Electronic Projects Design/Ideas/Reviews 3 23rd January 2005 04:54 PM
