3v0,
Hook the LCD backlight Anode to VCC and put the backlight Cathode on the unused connector pin where I can drive it with a sinking PWM signal and that adapter would be perfect... I have a similar manufactured adapter but they hard-wired the backlight to power pins (with appropriate dropping resistor) and the R/W pin to ground. It's got two unused pins on the 2x5 connector but I can't cut the backlight and R/W connections because they're buried. Bummer! Mike Last edited by Mike, K8LH; 5th June 2008 at 03:52 PM. |
Changed as requested. Also made the board a bit easier to etch and solder. The pdf fils is a foil pattern that can be printed and etched. The zip file contains the Eagle sch and brd files.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
3v0,
Very nice. "Perfect" does indeed apply. I'll take two (grin). I meant to edit my post to say it would be nice to have the backlight cathode available on the connector so that I could drive it with PWM or ground it but I couldn't edit my post. btw, I wouldn't be opposed to a installing a couple jumpers if those small traces between pads is a problem... Mike Last edited by Mike, K8LH; 5th June 2008 at 05:17 PM. |
The lines between traces should not be a problem with a decent setup. The thin lines here are .012 and I have used .001. The .012 is quite dependable but the .001 traces need to be verfied after etching. Most of the time they are good. ![]()
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 5th June 2008 at 06:01 PM. |
Yes, backlight anode to VCC and cathode to the connector. Sorry I didn't notice it in your first updated drawing.
Mike |
LCD backlight cathod is now connected to the 2x5 and the annode to +5.
The pdf fils is a foil pattern that can be printed and etched. The zip file contains the Eagle sch and brd files. ![]() ![]()
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 6th June 2008 at 12:14 AM. |
3v0,
Bravo! That looks very neat and clean. Mike |
Just out of curiosity, what is the purpose of the pullup on RS?
Also, would a pull down on RW make sense for code that uses delays rather than checking the busy flag. Mike. |
It has been a while. I think the pullup on RS is there because it connected to A4 (open collector output) on the original application. In general it makes more sense to place that pullup on the target. That way the pullup will be there regardless of how the signals are brought out to the connector.
Also the contrast resistor(s) may be muffed up or at least simplified. The documentation I am looking at shows a single variable resistor between pin 3 and GND. I have the pot wired up as a voltage divider splitting VCC and GND.
| 18F4620 Hlaf Bridge HPWM | kalaman | Micro Controllers | 0 | 30th October 2007 01:24 PM |
| Please suggest a microController with these features. | pkshima | Micro Controllers | 12 | 9th May 2005 12:06 PM |
| 18F452 to 18F4620 | Oznog | Micro Controllers | 0 | 8th March 2005 01:18 AM |
| Unused features? | MrMikey83 | Micro Controllers | 1 | 24th February 2005 06:11 PM |
| new revisions----new features please!!!! | urzalight | Electronic Projects Design/Ideas/Reviews | 3 | 23rd January 2005 04:54 PM |
