+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
Results 16 to 30 of 31
Thread: Strange PICkit 2 problem - can't program
  1. #16
    futz Excellent futz Excellent futz Excellent futz Excellent futz Excellent futz Excellent futz Excellent
    Join Date
    Sep 2007
    Location
    Vancouver, B.C.
    Posts
    1,980
    Quote Originally Posted by nickelflippr View Post
    You did run the Pickit 2 ->Tools->Troubleshoot right?
    I hadn't done that. Just did it and it passed every test perfectly. My new multimeter even has Hz measurement, so I could confirm the 30kHz thing.
    When I started up the software and did a comm check, it did just what was happening before - with target power on, the chip was not detected. With target power off, it was.
    While tinkering with the PICkit software I did a full erase of the chip. I also looked at every other available thing in there just in case there was something that would fix my problem.
    I shut that off and went back to MPLAB and now it works fine! Maybe the erase fixed it? I don't know exactly what cured it, but it seems good now... Wonder what all that was about? Weird.
    EDIT: False alarm. It's still screwed up.
  2. #17
    Join Date
    Sep 2007
    Location
    Vancouver, B.C.
    Posts
    1,980
    OK, it's my program. Must have made a change to the config bits, though I don't remember doing so. I don't see anything wrong with them, but I erase the chip with the PICkit software and can then detect the chip both with and without target power.
    But after reprogramming the chip with my program I can't detect the chip with target power on, but CAN detect it with target power off.
    Here's my program's config line:
    #pragma DATA _CONFIG, _WDT_OFF & _INTRC_IO & _LVP_OFF & _MCLR_ON
  3. #18
    Join Date
    Sep 2007
    Location
    Vancouver, B.C.
    Posts
    1,980
    And I narrowed it further. It wasn't config bits. I had been messing with Timer1. I had previously set it to expect a clock source on the PGD/PGC pins (I knew it couldn't be programmed with the crystal plugged in, and it had been removed), but I was sure I had disabled that. Guess I was mistaken, because when I comment all Timer1 code out, I can program the PIC and everything still works.
  4. #19
    Join Date
    Sep 2007
    Location
    Vancouver, B.C.
    Posts
    1,980
    Well that was a good (but horribly time consuming) lesson. The details are on my site if you want to see.
    Who'd of thunk that once you set Timer1 to use a crystal you can't reprogram the chip without erasing it first. And you can't erase it with MPLAB. Weird!
    EDIT: My 1000th post!
  5. #20
    Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,805
    This came up a while ago. A poster thought his code somehow broke the 88 and it turned out he was enabling the timer1 crystal. One to keep in mind. I found a similar thread but the consensus was that this couldn't happen. clicky
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    Quote Originally Posted by futz View Post
    If you connect to a working chip then swap in the bad one you can erase it from MPLAB. We ran into the same problem in class but noticed the problem followed the chip. You could have seen this if you had switched to a simple program to test your chips and PICkits.
    Live and learn.
    BCHS/3v0's Tutorials
  7. #22
    Join Date
    Sep 2007
    Location
    Vancouver, B.C.
    Posts
    1,980
    Quote Originally Posted by Pommie View Post
    Well I beg to differ! I put in the hours to debug the stupid thing. It was interesting though, and I don't mind wasting hours as long as I learn something good out of it.
  8. #23
    Join Date
    Sep 2007
    Location
    Vancouver, B.C.
    Posts
    1,980
    Quote Originally Posted by 3v0 View Post
    Great idea, but by the time I got this even partly figured out I had screwed up all three 16F88's that I have here. I just had no idea it was the program. The problem looked so much like hardware.
  9. #24
    3v0
    3v0 is offline
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    I agree that it does look like a hardware problem. The lesson here is not to jump to that conclusion. When things go wrong step back to a known good working setup for test. As you found out the code under development, should not be used as a part of that test.
  10. #25
    Sputnik Newbie
    Join Date
    Sep 2005
    Posts
    20
    I think it has to do with the 16F88!!
    I had the same problem when trying to program an F88.
    I thought I accidentally connected power wrong and fried the programmer so Ichecked wiring and tried my backup PK2 that I use as UART and analyzer and it didnt work either. Tried a new F88, notta, zilch, nothing!!!
    Then I thought It was my compiler, but after trying for hours to fix it I tried a 628A, 18F4525 and a few others and got nothing out of 2 different PicKit2's using V2.5.
    The next day I tried it on my 18F4525 dev board and it worked fine. I did nothing that I know of to fix the issue. Tried an F88 and it identified the chip the first time, thought everything was OK until I went to program the F88 and boom, back to nothing.
    Fiddled around for a wile and it started working again.
    I think the F88 is messing up the PicKit 2 driver somehow.
    It works fine on all other chips I use.
    I will try an F88 again in the next few days to see if it does it again to confirm.
  11. #26
    Join Date
    Sep 2007
    Location
    Vancouver, B.C.
    Posts
    1,980
    Quote Originally Posted by Sputnik View Post
    I've solved the problem. It was caused by me enabling Timer1 to use a crystal on the PGD/PGC pins. Once that's programmed into the chip and running, the programmer can no longer identify the chip (I assume) because the pulses Timer0 is outputting on PGD/PGC interfere with the programmer trying to use the same pins.
    The cure is to use the PICkit 2 software (with target power off) to ID and erase the chip. It won't ID it with target power on (pulses too strong??). Then I shut that off and can ID and program normally from MPLAB.
  12. #27
    mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent
    Join Date
    Oct 2006
    Location
    Hyderabad, India.
    Posts
    2,475
    Blog Entries
    1
    Great Futz,
    At last you came out of the riddle and now things are normal
    a good experience of how not....
    Regards,
    Sarma.
  13. #28
    Join Date
    Sep 2007
    Location
    Vancouver, B.C.
    Posts
    1,980
    I just read an article that explains the perfect cure for the problem I was having. Simply put a delay at the beginning of the code so it doesn't start the crystal up right away. That allows the programmer to get control before the clock starts up and prevents it. Knowing that would have saved me a bunch of time.
  14. #29
    dipmicro Okay
    Join Date
    Dec 2006
    Location
    Canada
    Posts
    68
    There is one more thing to watch for which I stumbled upon recently.
    When I power target from PICkit2 and target has a Vdd filter cap (I was using 330uF), it locks the PICkit2 application. I believe it is because it temporarily drops the USB voltage (if you look in PICkit2 schematic, you see there is no protection against that) and resets PICkit2.
    The cure was to power target from it's own supply.
  15. #30
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,709
    Blog Entries
    5
    I've noticed the same thing with the Junebug, the PICkit2 pulls target VDD to GND (5mA) if the target sags it assumes the target is not powered. Then it turns on a P-Channel FET pulls it to VDD, if the VDD rises too slowly it'll stop applying VDD to keep from killing the P-FET.
    Bill
    Smart Kits build Smart People
+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
  1. Replies: 6
    Latest: 15th May 2009, 12:43 AM
  2. Swordfish BASIC and PICkit 2 integration (one button compile & program)
    By blueroomelectronics in forum Micro Controllers
    Latest: 20th December 2007, 05:15 AM
  3. Strange Hardware Problem.
    By tkvenki in forum Micro Controllers
    Latest: 13th June 2007, 09:28 AM
  4. Strange problem
    Latest: 3rd May 2007, 11:40 AM
  5. Strange WPU problem.
    By 2camjohn in forum Micro Controllers
    Latest: 10th April 2006, 02:05 AM
Tags for this Thread
