Thanks, Ive managed to get some useful info out of them
What I've discovered "so far" is that the DCF signal output THIS:
Bit Name Description Comment
0-14 Reserved Coding to requirement
15 R Send antenna 0 = Standard antenna / 1 = Reserve antenna
16 A1 Announcement 1 1 = Next hour a Daylight Saving Time (DST) change occurs
17 Z1 Time Zone bit 1 0 = Winter / 1 = Summer (DST)
18 Z2 Time Zone bit 2 0 = Summer / 1 = Winter (usually the opposite of Z1)
19 A2 Announcement 2 1 = Next hour an extra second is inserted (leap-second)
20 S Startbit Always 1, startbit coded time information
21-27 Minutes 7 bit, BCD, LSB first (00...59)
28 P1 Parity bit 1 Even parity for all received bits from the minutes
29-34 Hours 6 bit,BCD, LSB first (00...23)
35 P2 Parity bit 2 Even parity for all received bits from the hours
36-41 Day of the month 6 bit, BCD, LSB first (01...31)
42-44 Day of the week 3 bit, BCD, LSB first (1 = Monday...7 = Sunday)
45-49 Month 5 bit, BCD, LSB first (01...12)
50-57 Year 8 bit, BCD, LSB first (00...99)
58 P3 Parity bit 3 Even parity for all received bits from the date
i'm guessing the bit numbers above are whats transmitted in those actual seconds?
While the MSF receiver module I have (and want to use) the only info I have to the outputs are: Code:
Taken from the PDF file the ONLY info relating to the data output pins:
Serial Output
This port can be used for connecting external units, like. digital displays.
Available information:
Actual year
Actual month
Actual day
Actual day of the week
Actual hour [12h]
Actual AM/PM
Actual minute
Actual second
The transmition always happens on the begining of every hour, at
HH:00.00,500 and takes 44 ms.
Additional transmitions will happen after „first receive“, „forced receive“ und „auto
receive“ and after any correction of the hands was necessary.
Specification Date: 09.03.2005
MSF RC_wallclockDO_Specification
2.7.1. Format of data
Nr. Describtion Format Numbers Explanation
1 daylow BCD 00 - 31 Lower byte of actual day
2 dayhigh BCD 00 - 31 High byte of actual day
3 dayofweek HEX 1 - 7 Day of the week, 1 = monday
4 month HEX 1 - 12 Actual month, 1 = January
5 yearlow HEX 00 - 63 Actual year, 14H = xx20
6 yearhigh HEX 00 - 63 Actual year, 14H = xx20
7 minutelow BCD 0 - 9 Actual minute, 0 - 9
8 minutehigh BCD 0 - 5 Actual minute, 10 -50, 0xxx = AM, 1xxx = PM
9 hour HEX 0 - 11 Actual hour
10 secondlow BCD 0 - 9 Actual second, 0 - 9
11 secondhigh BCD 0 - 5 Actual second, 10 -50
The transmition is serial, sychronized to a clock-frequency of 1 kHz. The clock frequency is
also available on the port.
Timing diagram:
clock pin … 1
data pin ... 2
First nibble Second nibble Third nibble Fourth nibble ...
daylow = 0101B =5 dayhigh = 0010H =2 dayofw. = 0011H =3 month = 1011H =11 ...
Beispiel: 25. Nov. Mittwoch
Example: Nov. 25th Wednesday
I've got an example of a basic program to decode the German DCF signal but it's in proton basic while I'll be using picbasic pro, which isn't a problem I can figure out how to convert it ok
What i could do with some help on is, any ideas what bits I need to change in the code to get the msf module decoding?
i.e the main differences I need to look out for or work on changing
I've never done anything with clocks before, and never used a serial input to a pic either so any ideas are welcome
