Old 23rd May 2008, 03:02 PM   (permalink)
Default Weird problem with 16f628
Hi there!
I have written a programme for a line follower robot ( though still not implemented), first I want to try it with LEDs, Here is the code :
list p=16f628
		#include<p16f628.inc>
		__CONFIG  _MCLRE_ON & _CP_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT
		ERRORLEVEL   -302
		cblock	0x20
			temp
			temp_s
  		endc
	org 0x00
	goto main
;***********************************INTERRUPT LOOP*****************
	org 0X04
inter:
		movwf temp
		swapf STATUS,w
		clrf  STATUS
		movwf	temp_s
		btfsc	PORTB,0x00
		goto	loop1
loop2:
		movlw b'00000101'
		movwf	PORTA
		btfsc	PORTB,0x05
		goto	loop2
		goto	loop_x
loop1:
		movlw b'10001000'
		movwf PORTA
		btfsc PORTB,0x00
		goto  loop1
loop_x
		bcf   INTCON,0x01
		bcf	  INTCON,0x00
		swapf temp_s,w
		movwf STATUS
		swapf temp,w
		retfie
main:
	bsf	INTCON,0x07			;Globel interrupt enable(we are using interr.)
	bsf INTCON,0x04
	bsf	INTCON,0x03			;RB4-RB7 interrupt on change is enabled/ in other words these pins will also work as
							;interrupts and interrupt will occur every time any of these pin changes state
							; i.e.:HIGH to LOW or LOW to HIGH, we can not set it to be on eather one state change
	bcf INTCON, 0x01
	bcf	INTCON,	0x00			;Clear RB4-RB7 interrupt flag so, that another interr. can occur.
;**********************************SET UP THE PORTS *****************
	bsf	STATUS,RP0			;switch to BANK 1
	movlw b'00100001'
	movwf TRISB				;set RB6 & RB5 as input
	movlw b'00000000'
	movwf TRISA				;setPORT A all output
	bcf OPTION_REG,0x07		; enable weak pull ups on port b/ pull ups mean internal resistors
	bcf STATUS,RP0			;back to BANK  0
	movlw 0x07				;turn comparators off, so HIGH will be simple
							; HIGH rather than +5V (compared to supply) so with the LOW
	movwf CMCON
Loop:
	movlw b'00001001'
	movwf PORTA				;set pin 0 of port a HIGH
	goto Loop
	END
Now let me explain you what this code supposed to do (which it does very well but only when the PIC is powered by PIC Kit 2):
First when the power turned on RA0 and RA3 goes HIGH lighting YELLOW and GREEN LEDs, and when I press switch 1, RB0 goes high and an interrupt occur and YELLOW LED switched off and BLUE LED lights up and same sequance is applicable to RED and GREEN LEDs when I press switch 2 which causes interrupt at RB5
Again let me tell you that the PIC runs this programme very well BUT ONLY WHEN IT IS POWERED BY PIC KIT 2 AND NOT WHEN CONNECTED EXTERNALLY AS SOWN IN CKT.
PLEASE, don't check that this code is o.k. for a line follower or not or don't tell me that there is a better code for that I know ther are many, I'm a layman (see how I learned PIC programming on thread titled" setup an interrupt in 16f690") , I JUST WANT TO ASK THAT WHY IT IS NOT WORKING WHILE POWERED EXTERNALLY ?
By not working I mean :
When I turn on the power YELLOW and GREEN LEDs lights up as it should be but, on either interrupt both LEDs goes off lightning NO OTHER LED, I tried tieing MCLRE high and even LOW but nothing work.
PLEASE HELP ME !!
Edit: Kindly see the circuit that is exactly how I connect it, nothing more nothing less
CHRIS
c36041254 is offline   Reply With Quote
Old 23rd May 2008, 03:11 PM   (permalink)
You don't have any capacitors on your power supply.
Also, it's not a good idea to drive LEDs straight from a pic without resistors.
House0Fwax is offline   Reply With Quote
Old 23rd May 2008, 03:22 PM   (permalink)
PLEASE HELP ME !!
To run properly without a programmer attached, MCLR must be pulled high with a pullup resistor. Use any value from 10K to 33K (I always use 33K). Pulling it low just puts the chip in reset - nothing happens till it goes high again.
You should have a 0.1uF ceramic capacitor close to the chip from VDD to VSS, and a 10uF electrolytic (or bigger) is a good idea somewhere near the chip from VDD to VSS (observe polarity).
As House0Fwax says, put (typically) 330 ohm current limiting resistors in series with each LED. 180 ohm to 470 ohm is the typical range for current limiting resistors on LEDs. Depends on your LEDs and how bright you want them.
futz is online now   Reply With Quote
Old 23rd May 2008, 03:23 PM   (permalink)
That's true, and you need a pullup 22K is good on MCLR.
As for the caps 100uF and 0.1uF would be a nice start.
Bill
Smart Kits build Smart People
Old 24th May 2008, 03:07 AM   (permalink)
Exclamation
I understand that I need to couple the AC and so I tried this (see the ckt), but that is not working infact LEDs are now start blinking (red and yellow ). I don't get what do you mean by "...somewhare near the chip....", I mean whether it is near the chip or even at long distance , should not make any difference as far as the caps are across the Vdd and Vss.
CHRIS
Old 24th May 2008, 03:56 AM   (permalink)
You definitely need a resistor from MCLR to 5V for the pic to run, if this is missing the pic may run intermittently and produce flashing LEDs. This is normally taken care of by the Pickit2 but once you remove it, you have to supply the resistor.
Also, if your 9V supply is a wall wart then you may need an electrolytic on the 9V side. You should also have a 0.1uF capacitor on both sides of the regulator and a small electrolytic on the 5V side. The 104pF capacitor is probably a 0.1uF anyway - 0.1uF capacitors are marked 104, that is 10 + 4*zeros after = 100,000pF = 0.1uF. It is important that the 0.1uF cap is near to the pic pins, this is to suppress fast switching currents. I'm sure you have checked it anyway but have you checked the obvious things like the voltage on the actual pic chip, many problems here have been solved with a new battery.
Pommie is online now   Reply With Quote
Old 24th May 2008, 04:00 AM   (permalink)
Another thing is R1 & R2 are pretty strong pull downs, PORTB has weak pullups FYI.
Bill
Old 24th May 2008, 04:18 AM   (permalink)
Mike I have attached a 10k resistor as pull up for MCLRE but, haven't apply any cap. on 9v side so I'll try that. Thanks for help !
CHRIS
Old 24th May 2008, 04:21 AM   (permalink)
Physically and electrically (same thing) as close to the chip as possible. See the tiny light brown/orangish 0.1uF caps across VDD/VSS on both sides of this chip. This breadboard is controlling a motor controller and there are motors about 1/2" away too, and the whole thing runs off the same battery pack (breadboard has its own regulator) so there are a few extra electrolytics to smooth out any buzz and/or dips in the power.
At the bottom left you can see the 33K MCLR pullup resistor right beside the power LED's current limiting resistor.
Old 24th May 2008, 08:29 AM   (permalink)
O.K. Ihave done the caps and attached the resistors to LEDs but, still only one switch (RB0 interr.) is working and that too when I have my fingure on the polar acp connected across Vss and Vdd. I have attached a pull down resistor of 10k on RB0, doing the same at RB5 stops the PIC and all LEDs goes off
CHRIS
Old 24th May 2008, 02:57 PM   (permalink)
Sounds like a poor connection somewhere, if it's a solderless breadboard they are not uncommon.
Bill
Old 24th May 2008, 03:46 PM   (permalink)
Exclamation
I spent a whole day on that and found this:
When I ground the RB0 the RB5 interr. works fine and when ground the RB5 the RB0 works fine, with pull down resistors connected to both it should not be necessary to ground the interr. manualy but that's not happening. Is thare any way (except transistors) by which RB0 automatically gets grounded while giving high to RB5 and vice versa. When these interr. will be connected with phototransistors I think this will be resolved. Let me know if there is any other solution to this.
CHRIS
Old 24th May 2008, 10:51 PM   (permalink)
I spent an hour or so and found this: Your code needs those pulldown resistors you have in your schematic. Turning on the weak pullups in the chip just screws things up.
I made some minor corrections to the code, but nothing that changes the fundamentals of how you were doing things:
	list p=16f628
	#include <p16f628.inc>
	__CONFIG  _MCLRE_ON & _LVP_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT
	ERRORLEVEL   -302
	cblock	0x20
	w_temp,status_temp
  	endc
	org	0x00
	goto	main
	org	0X04
inter	movwf	w_temp		;preserve regs
	swapf	STATUS,w
	bcf	STATUS,RP0
	movwf	status_temp
	btfsc	PORTB,0		;RB0 switch pressed?
	goto	loop1		;yes, go handle it
loop2	movlw	b'00000101'	;RB5 switch pressed, red & yellow LED on
	movwf	PORTA
	btfsc	PORTB,5		;keep them lit till switch released
	goto	loop2
	goto	loop_x		;RB5 switch released, go return
loop1	movlw	b'10001000'	;green & blue LED on
	movwf	PORTA
	btfsc	PORTB,0		;keep them lit till switch released
	goto	loop1
loop_x	bcf	INTCON,INTF	;clear interrupt flags
	bcf	INTCON,RBIF
	swapf	status_temp,w	;restore regs & return
	movwf	STATUS
	swapf	w_temp,f
	swapf	w_temp,w
	retfie
main
	banksel	TRISB		;bank 1
	clrf	TRISA		;PortA all outs
	movlw	b'00100001'	;RB0 & RB5 inputs
	movwf	TRISB
	banksel	PORTA		;bank 0
	movlw	0x07		;comparators off
	movwf	CMCON
	movlw	b'10011000'	;set interrupts
	movwf	INTCON
Loop	movlw	b'00001001'
	movwf	PORTA		;RA0 & RA3 high
	goto	Loop
	end
Here's a YouTube movie of it in action:
And here are some pics of the circuit for you to compare with yours. Those are 330hm: current limiting resistors on the LEDs. The MCLR pullup is 22Khm:. The power LED has a 180hm: resistor. The switch pulldowns are 10Khm::
My power supply is a wall wart plugged into one of these, so the capacitors on the breadboard are really redundant and unnecessary for me. I put them there for your benefit. There are a 100uF and 10uF electrolytic and a 0.1uF ceramic on there.
Old 25th May 2008, 12:12 AM   (permalink)
I even made a schematic
Old 25th May 2008, 02:47 AM   (permalink)
Thumbs up
Thank you ! futz turning off the WPUs work !, why they were causing the problem ?. Now, this may suitable for general topic but, still I'm puting it here.....
I have just finished my diploma in electronics and telecommunication (Bachlor's running) so, I was wondering that at this stage, is it normal to have this much knowledge (whatever you can make out of this discussion ), I am very nervous about all this, it was just a very simple programme and still took so long for me ! and there was Mike who explained me what was 104pF (104pF = 0.1uF), after having a diploma I'm making an impression that I even don't know how to read 104pF, I'm sure Mike was just helping me but, all these makes me realy nervous, Does this usually happens or I'm a dumb elcectronics hobbiest and need to study hard ?, though in my class I am the smartest one (trust me my teachers say so ) (don't be polite in responding)
CHRIS
weird garage door problem lukasz General Electronics Chat 33 26th January 2007 08:50 PM
Weird 74LS90 counter problem Torben Electronic Projects Design/Ideas/Reviews 11 8th December 2006 09:07 AM
Weird DVD Problem ThermalRunaway General Electronics Chat 15 17th August 2005 06:32 PM
weird pic code problem Fletcher Micro Controllers 9 13th October 2004 02:39 PM
wierd problem with 16f628 eeanma Micro Controllers 2 1st November 2003 11:42 AM
