Old 19th May 2008, 07:05 AM   (permalink)
Default how to detrmin the config bits
Im woundering how to determin wich configbits to use on a 18F4550.
Im using a SD card for storage (using mikroC compiler with libs for FAT16)
ADC (three of them)
and i got a 8 MHz Crystal
Im also ud\sing a DS1302 for timestamp on the file
I would be glad if someone could help me on how to choose the different config bits.
Simplicity rules
Good enought - its perfect ??
2 Gig of free online backup space
Are you a Chemist?
Kryten is offline   Reply With Quote
Old 19th May 2008, 07:09 AM   (permalink)
If you are using C18 then check out this document.
Pommie is online now   Reply With Quote
Old 19th May 2008, 07:17 AM   (permalink)
Thanks Mike,
I was going to prepare a summary of the 18F1320 CONFIG's for a project I am doing, saved me a job, IOU another beer.
Regards
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 19th May 2008, 10:29 AM   (permalink)
ADC (three of them)
You will have to read the data sheet. The mikroC keep the config bit's in the project (not in the C/H files like normal compilers). You have a list of bits so you select ones you want to use. The config bit's are named exactly like they are named in data sheet, so it is fairly simple. If there is some "special" bit you do not understand (what it does / what it is for) post a direct question. In 99% cases the "default" button on the edit project page will set up the config to some working condition
http://www.it4um.com
arhi is offline   Reply With Quote
Old 19th May 2008, 10:33 AM   (permalink)
Well i have looked in the datasheet and couldnt say i could find (a list) of config bits. All i did find was the OSC bit(s)
Simplicity rules
Are you a Chemist?
Old 19th May 2008, 11:03 AM   (permalink)
Do not get me wrong, I hate the whole "config bit" thing with uC's .. still struggle with some questions about it .. as for the 4550 .. pages 288-299 in pdf document explain every bit.
I also understand your confusion as MikroC keep the name of the config register, not the bit itself, it has "config words" that are "trouble" .. I personally go trough doc, set up the value of every bit and then "turn on the appropriate combo" in MikroC ... In my prev post I wrote mikroC keep "bit's" .. that is not true .. it keep the name of registers, and offer some "config words" that I actually do not get at all .. I only look at the hex values. So again, the only way to do it properly is trough datasheet, the way mikroC offer those words IMHO only confuses people .. but, I read that they are now thinking about making cli compiler (linux version too) so this might change...
Old 19th May 2008, 11:06 AM   (permalink)
Ahh ok thanks for that (im a bit blushed here im sitting and checking out pages 288 trough 299 in the datasheet)
Simplicity rules
Are you a Chemist?
Old 19th May 2008, 11:15 AM   (permalink)
no worries, btw, if you find a way to "directly" setup those config reg's (skipping the ugly config_word bs from mikroC), please share
Old 19th May 2008, 11:38 AM   (permalink)
You could always just look at:
"C:\Program Files\Microchip\MPASM Suite\P18F4550.INC"
I usually look there for a listing...
AtomSoft is offline   Reply With Quote
help programming 18f4431 thiru_electrifiers Micro Controllers 13 12th April 2008 06:11 AM
RS232 Converter e.chain Micro Controllers 0 6th October 2007 06:19 PM
Easiest/Cheapest way to snoop I2C traffic? toodles Micro Controllers 22 22nd August 2007 12:19 PM
need help modifying some pic ASM code justDIY Micro Controllers 17 16th July 2007 11:41 AM
Using a PIC to emulate a PSX controller toodles Micro Controllers 10 30th June 2007 08:17 AM
