Old 18th May 2008, 08:32 AM   #1
Default 18F2550 USB on VB Express 2008
Hi. I tried to control step motor over usb. I write program on VB Express 2008, for microchip on PBP 2.46.. I have a problem with sending data. If I send a byte which has value over 127, pic takes it always as 63 ( Ascii code of question mark ). I'm using CDC interface, endpoint 3. Is there any solution
serkanc is offline
Old 18th May 2008, 10:31 AM   #2
Send your data as ASCII, not as binary.
Old 18th May 2008, 12:16 PM   #3
Could you attach the vb source code?
digital-diy.com - Hobby microcontroller projects and tutorials. Assembly, PICBasic and C examples.
gramo is offline
Old 18th May 2008, 12:36 PM   #4
Talking
For Each sp As String In My.Computer.Ports.SerialPortNames
ComboBox1.Items.Add(sp)
Next
SerialPort1.Encoding = System.Text.Encoding.GetEncoding(28591)
SerialPort1.PortName = ComboBox1.SelectedItem
SerialPort1.Open()
SerialPort1.Write("M" & ChrW(Duty)
Thanks. It works. i have added this line to VB:
SerialPort1.Encoding = System.Text.Encoding.Default
serkanc is offline
Old 18th May 2008, 02:04 PM   #5
I have also one more problem to solve..
I tried to run a fan with pwm with ULN2003. Need I connect the PIC Ground to the ULN2003 or Fan Supply Ground is enough?
How can I read Fan Rpm on the third cable of Fan ? Is there any example.
serkanc is offline
2008, express, usb
interfacing ibutton to PC using USB konzen General Electronics Chat 26 13th May 2008 11:31 AM
How to modify a webcam to bypass USB? The_UnforgiveN Electronic Projects Design/Ideas/Reviews 6 4th May 2008 04:16 PM
USB Power hack with DC/DC Converter - am I crazy? chconnor Electronic Projects Design/Ideas/Reviews 14 8th March 2008 10:13 PM
Help needed developing USB peripheral using HID class Adester Micro Controllers 4 22nd November 2007 03:42 PM
usb interfacing problems for a waveform generator simonharvey Electronic Projects Design/Ideas/Reviews 0 27th September 2007 12:32 AM
