oh one more thing, when i declare variables as byte, it doesn't turn blue the way int, for, if and while turns blue. i'm starting to believe that byte is not the correct choice of variable type. perhaps i'll try unsigned char.
Do you realise that your code is waiting until the button is missing?
I indented and commented your code, Code:
void main()
BYTE buffer[8];
BYTE i;
while(TRUE){
//printf("\r\nWaiting for a touch device...\r\n");
while(!touch_present()); //wait for button to be missing
output_high(PIN_B4); //light LED
delay_ms(200);
if(touch_present()) { //if button is present
output_low(PIN_B4); //extinguish LED
touch_write_byte(0x33); //write command ReadRom
for(i=0;i<8;++i) //read the 8 byte ID
buffer[i]=touch_read_byte();
for(i=0; i<8; i++)
putc(buffer[i]);
Mike. Last edited by Pommie; 24th May 2008 at 05:22 AM. |
Try putting BYTE in lower case.
Mike. |
Really?
Isn't that line saying 'as long as the ibutton is missing?' Code:
void main()
BYTE buffer[8];
BYTE i;
while(TRUE){
while(!touch_present()); //wait for button to be missing...'as long as ibutton is
missing'
delay_ms(200);
for(i=0; i<8; i++)
putc(buffer[i]);
haha lol,
So far when I touch the ibutton to the reader, fluctuations between 5V and 0 V were observed. This is rather good news. However, my MAX232 circuit is having a couple of problems so I can't transmit via RS232 to the PC. I've tried the read function on the compiler to read the contents of the PIC but to no avail. Any ideas? in the meantime I'll be working on the MAX232 circuit |
A good way to test if your MAX232 circuit is working is to remove the pic from it's socket and connect the RX and TX pins (7 & 8) together. If you then run Hyperterminal and select flow control = none, you should see what you type echoed back.
As for storing the ID in the EEPROM, you should be able to read the EEPROM with your programmer. What programmer are you using? Mike. |
I see. Will try it. I'm using MPLAB IDE v7.60 which is readily available on the terminal I'm working on in uni.
I've tested my max232 circuit and its working fine. tried with the ibutton in place but nothing happens. I've tried just sending fixed hex values from the PIC but still nothing works.
example : putc(0x11) I've defined #use RS232 in the header and all the relevant options such as baudrate, xmit and and rcv pin. Will continue tmrw |
Hey,
new update: the max232 circuit works good. I can send values from the PIC to the PC with no problems now. however, I still can't get the PIC to read the ibutton. the PIC always seems to loop in the wait state. No matter what I tried, I can't get it to respond to an ibutton touch. I suspect that I did not define whether the pin i'm using to serve as an output or input that's being the cause to this. however, since the bus is 1-wire, the pin is required to serve as both input and output. how do i do this? btw i've also found out that byte and boolean are predefined variable types in the PIC header file so even though they don't turn blue when I type them there is nothing wrong. And can you explain this area of code to me? Code:
#ifndef TOUCH_PIN #define TOUCH_PIN PIN_B0 #if defined(__PCH__) #bit TOUCH_PIN_BIT = 0xF8A.0 #else #bit TOUCH_PIN_BIT = 6.0 #endif #endif |
| interfacing ibutton to PC using USB | konzen | General Electronics Chat | 26 | 13th May 2008 10:31 AM |
| 8051 microcontroller reading data from serial port | godatguitar | Micro Controllers | 11 | 17th February 2004 08:03 PM |
| Specifications Applied | Caltech | General Electronics Chat | 1 | 25th December 2003 05:00 PM |
