Old 12th May 2008, 07:46 AM   #1
Default spi to rs232 coverter
hi! we have an ADIS16350 sensor which has a SPI compatible interface. we want to convert the sensor output to rs232 interface because we will be using rs232 in our own GUI in visual basic 6.0. does anybody know how can this be done? thanks
nikolai_dlsu is offline
Old 12th May 2008, 09:22 AM   #2
Use a small PIC to read the sensor and send the data out via RS232 as ASCII.
Old 12th May 2008, 03:53 PM   #3
You can also use the PC serial port to bit bang SPI in VB by using the handshake lines. As long as your comfortable with the windows API then have a read of these articles.
Pommie is offline
Old 15th May 2008, 03:35 PM   #4
Default vb6 experts
Is there anyone here, from the philippines who can help us in the visual basic part of our thesis? We really need help!!! Thanks a lot!!!
Old 15th May 2008, 03:50 PM   #5
You could bit bash the SPI device using your PCs parallel port, if you're using XP you need a special DLL to get access to the port though.
Else like the other posts said you'll need something to make the SPI data RS232 compatible. Any small microcontroller could do it.
Bill
Smart Kits build Smart People
Old 15th May 2008, 03:53 PM   #6
hi Mike,
I use Visual Basic 5 programs to emulate 'SPI' on the PC's parallel port to work with SPI external devices.
The MCP3202/04 12bit ADC works OK, with a couple of LM35 makes a nice and simple dual temperature measurement system.
Regards
ericgibbs is offline
Old 15th May 2008, 04:11 PM   #7
hi nikolai_dlsu,
Extracted from my program, the working parts of the VB5 SPI code.
You should be able to paste the routines into VB6 OK.
'PC parallel port working with MCP3302 SPI device
option explicit
Dim CmdStr0, CmdStr1 As String
Dim Ary(24) As Long
'port addresses
Const Po378 = &H378, Pi379 = &H379, P37A = &H37A, P37B = &H37B
'command string for MCP3302 SPI
CmdStr0 = Trim("000000011000000000000000") ' chn0
CmdStr1 = Trim("000000011100000000000000") ' chn1
Const EhDhCh = 7 'cs hi, do hi, clk hi'' ready state
Const ElDhCh = 3 'cs lo, do hi, clk hi
Const ElDhCl = 2 'cs lo, do hi, clk lo
Const ElDlCh = 1 'cs lo, do lo, clk hi
Const ElDlCl = 0 'cs lo, do lo, clk lo
Const Dinp = &H80 '' '0000,0001_1000,0000_0000,0000
Private Sub Form_Load()
Form1.Show
MakePwrAry
End Sub
Private Sub ReadSPI()
DoEvents
Out Po378, ElDhCh
'send  data bits to ADC msb 1st
For p = 1 To 24
If Mid$(CmdStr0, p, 1) = "1" Then
Out Po378, ElDhCh
Out Po378, ElDhCl '''ClDh
Out Po378, ElDhCh ''ChDh
Else ' lo
Out Po378, ElDlCh
Out Po378, ElDlCl ''ClDl
Out Po378, ElDlCh ''''ChDl
End If
V = Inp(Pi379) And Dinp
     If V <> Dinp Then
     ADCValue1 = ADCValue1 + Ary(p)
     End If
Next p
Out Po378, EhDhCh
End Sub
Private Sub MakePwrAry()
'precalculate weighting for array when ADC is read,
Dim p As Long
p = 1
For z = 24 To 13 Step -1
Ary(z) = p
p = p * 2
Next z
For z = 12 To 1 Step -1
Ary(z) = 0
Next z
End Sub
EDIT:
Added a zip file, shows port connections.
Place the DLL's in the Windows\System folder.
Old 16th May 2008, 12:59 AM   #8
You're best off simply having a microcontroller receive the data and immediately output the same data using the UART peripheral. This will take advantage of hardware peripherals to remove any need for bit banging, which will make the job simpler.
www.salgat.net
Salgat is offline
Old 7th February 2009, 09:05 PM   #9
Default SPI to RS232 convertor
Dear ericgibbs
The code giving me error "invalid outside procedure" when i m trying ro run the ur code..as i m very new to VB6.0 and very urgent need the SPI to RS232 convector as i have one 24-bit ADC ADS1240E which has SPI interface.
Kindly guide me to communicate this ADC..Advance 100000++ thanks..please prove me solution , i will be very thankful to u or anybody can guide me ..please.
ansarirahim is offline
coverter, rs232, spi
PCMCIA to RS232 for ICD2 clone clockdoctor Micro Controllers 6 7th April 2008 11:10 PM
SPI Testing with ENC28J60 mikesmixes777 Micro Controllers 9 17th January 2008 08:41 AM
AVR DDS ~ RS232 problem... krazatchu AVR 15 13th December 2007 05:44 AM
RS232 Converter e.chain Micro Controllers 0 6th October 2007 07:19 PM
RS232 buffer TDY General Electronics Chat 3 18th March 2005 09:36 PM
