| New Member | I've been slowly working my way through Nigel's PIC tutorials and i'm currently working on a project to make a code lock so i've wired up a 3x4 matric keypad the exact same way that's on the site and used the correct tutorial programme but it doesn't work as it should. I know for certain i've wired it all up the EXACT same way but when i press the keys i get the following results. 1,2,3 don't work Press 4 and it displays B Press 5 and it displays 9 Press 6 and it displays 6 Press 7 and it displays 0 Press 8 and it displays 8 Press 9 and it displays 5 Press 0 and it displays A Press * and it displays 7 Press # and it displays 4 so as you can imagine i'm a bit confused. Any help would be greatly appreciated. Last edited by GForce2010; 11th May 2008 at 10:43 PM. |
| Experienced Member | Nigel's Keypad is a 4x4 matrix and it not have the * and# |
| New Member | i know that so the code brings up A and B rather that * and #, that's something i would alter later but none of the keys are bringing up the right number. and i've done the alteration in the code that Nigel states to do if you're only using a 4x3 keypad. |
| Experienced Member | What No tutorial are you trying 9.? |
| New Member | 9.2, the code lock one |
| Experienced Member | Are the numbers on your keypad arranged just as Nigel's ? and is it a matrix keypad and not a decimal ? I think it may be a wiring problem, i'am just trying tut 9.2 here and everything works great. |
| Experienced Member | The 3x4 keypads have a rather strange pin out. Looking from the top it goes, C1, R0, C0, R3, C2, R2, R1. Mike. |
| Experienced Member | Maybee it is like this. |
| Super Moderator | If you check my tutorial, it uses a lookup table to allocate the correct code for each button - all you need to do is alter the table order to get the responses you want. |
| Experienced Member | plz check your keypad connections. Did u ground the all rows through 10k or more valued resistor , iwas face the same problem...........
__________________ |
| New Member | as i said i've wired it up exactly like Nigels schemetic. it is a matrix and i've worked out what each pin is. As Mike wrote it does have a strange pin layout due to the circuit tracks. Thanks for the help Nigel........i still find it confusing that although i've copied it exactly it's not working for me........ |
| Super Moderator | Quote:
| New Member | I've just been looking at the tutorial again and i think there might be a mistake in there. The actual schemitic for the keypad interface board shows the pull up resistors on the the Row lines but in the tutoriual itself it says the pull up resistors are on the Col lines. Which is the correct one?? |
| Experienced Member | Nigel seems to have his rows and columns switched around in the software. Wire the keypad as in Nigel's hardware and don't remove the two lines of code but do include the 4th pullup resistor. The table may need switching around but at least all keys will work. Mike. |
| New Member | i've just got it working by swapping all the interface connectors around. looks like in the diagram it's marked row 1 - 4 then col 1-4 but for it to work i had to connect it col 4-1 then col 4-1 anyway it's now working fine. Think you should have a look at the keypad interface diagram Nigel. Thanks for all the help |
| Keypad Scanning Problem with AN557 16F628A | johnnyquest | Micro Controllers | 3 | 24th November 2007 09:26 PM |
| keypad encoder | Mel_noypi | Datasheet/Parts Requests | 5 | 22nd February 2006 02:01 PM |
| using serial keypad in LAB-1 | Rosy | Micro Controllers | 1 | 7th May 2004 12:32 PM |
| PicBasic Keypad program | Sora | Micro Controllers | 0 | 20th April 2004 07:01 PM |
| LCD and 4x4 Keypad on the Same port & DTMF using PWM | lee_man_tbu | Micro Controllers | 0 | 9th December 2003 08:43 PM |
