Old 9th May 2008, 05:02 PM   #1 (permalink)
Experienced Member
SPDCHK has a spectacular aura about
Default Why does my 18F1320 take 33seconds to reset?
I'm using the 18F1320 that comes with the Junebug kit in a breadboard arrangement with Hitachi HD44780 LCD controller and programming it with Swordfish SE.
The Swordfish code is as follow... (From one of the forums)
Device = 18F1320
Clock = 8
// some LCD options...
#option LCD_DATA = PORTB.4
#option LCD_RS = PORTB.3
#option LCD_EN = PORTB.2
// import LCD library...
Include "LCD.bas"
Include "convert.bas"
Dim Variable As Word
// Start Of Program...
'Enable MCLR on Pin 4 (RA5)
Config MCLRE = ON
Config osc = INTIO2 // I had to add this to get the
OSCCON = $76       // one second timer to work correctly
DelayMS(150)                            // Let the LCD warm up
LCD.Cls                                 // Clear the LCD screen
LCD.WriteAt(1,1,"Hello World")          // Send some text to the LCD
Variable = 0                            // Clear the "Variable" register
While True
    Inc(Variable)                       // Decrement the "Var1" register
    // Convert to a string,
    //  and always display 5 characters
    LCD.WriteAt(2,1,Convert.DecToStr(Variable,5))
    DelayMS(1000)                       // Delay for 1 second
Wend
When I program the PIC, remove and re-connect the power or use the MCLR switch to reset the PIC, it takes roughly 33 seconds before anything happens. In this 33 second waiting time the LCD display has the typical display that a LCD has that is not configured.
Is it a 18F1320 problem or the way that Swordfish makes the HEX file?
SPDCHK is offline   Reply With Quote
Old 9th May 2008, 05:05 PM   #2 (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
You also should turn off the watchdog timer, I'm not sure if Swordfish takes care of this automatically but best to turn it off unless you're using it.
// Config MCLRE = ON Unnessary
Config OSC=INTIO2, LVP=OFF, WDT=OFF // I had to add this to get the
OSCCON = $72       // one second timer to work correctly
Bill
Smart Kits build Smart People
blueroomelectronics is online now   Reply With Quote
Old 9th May 2008, 05:10 PM   #3 (permalink)
Experienced Member
Bill, it makes no difference. It still takes 33-35 seconds from reload or power recycle to start operating. Once it goes it seems to work 100% fine, (well, as accurate as an RC clock can be?)
Old 9th May 2008, 05:13 PM   #4 (permalink)
Experienced Member
Also Swordfish can use the PK2CMD.EXE command line to program with the Junebug. Make sure you have the /R option to allow the device to come out of reset (RUN) automatically after programming.
/PPIC$target-device$ /F$long-hex-filename$ /M /R /H2
Bill
Old 9th May 2008, 05:36 PM   #5 (permalink)
Experienced Member
speakerguy79 is on a distinguished road
Send a message via AIM to speakerguy79 Send a message via MSN to speakerguy79
Are you running Windows?
speakerguy79 is offline   Reply With Quote
Old 9th May 2008, 06:01 PM   #6 (permalink)
Experienced Member
Yes. Windows XP Professional.
Bill helped me to get the Swordfish to program directly via the PICKit command line, but the 33s reset still persists.
Old 9th May 2008, 06:30 PM   #7 (permalink)
Experienced Member
ericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to behold
After pressing the RESET button, during the long delay period [33s] measure the voltage on pin 4 of the 18F1320, MCLR pin.
Lets know what you measure
Regards
Eric
"Good enough is Perfect"
PIC tutorials:
Nigel's site: http://www.winpicprog.co.uk/
Gramo's site: http://www.digital-diy.net/
Old 10th May 2008, 05:55 AM   #8 (permalink)
Experienced Member
Regards
Eric,
+5V Rail: 5.044V
MCLR before reset pressed: 5.040V
MCLR with reset pressed : 0V
MCLR again after reset pressed: 5.040V
When pressing the reset button, the LCD screen stays static with last displayed values and text, and then only after the aforementioned time delay does the PIC actually reset and resume from start.
Old 10th May 2008, 06:26 AM   #9 (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
It is because the initialization code for the LCD is run at 32kHz. Open LCD.bas and at the end you will find,
// initialise the module...
Initialize
Add OSCCON = $70 before the line with initialize on it. You will have to double click the little padlock in order to edit it.
Alternatively, make a module called init and include it before the LCD include. Init should contain,
Module init
OSCCON=$70
Pommie is online now   Reply With Quote
Old 10th May 2008, 08:33 AM   #10 (permalink)
Experienced Member
gramo is just really nicegramo is just really nicegramo is just really nicegramo is just really nice
Your using the internal oscillator, so you have to remember that your Include files will initializes first, and of course, the piece of code that sets up the internal oscillator for 8Mhz will not be executed until that occurs.
basically your PIC is running at 31Khz until it gets to your first piece of code in the main program outside of the "LCD.bas" initialisation.
Solution: Create a User Module called "IntOSC_1320.bas"
In the module, copy and paste this code;
Module IntOSC_1320
Clock = 8
Config OSC = INTIO2
OSCCON = %11110011
Save the module in the following directory ..\Swordfish\UserLibrary
Now, back in your main program remove the Clock, Config and OSCCON settings, and include "IntOSC_1320.bas" before any other includes.
Now your program will service the module's code first, and in return you will have an 8Mhz internal OSC from the get go
Spency.
How many PC programs are developed with assembler? Then why use it with PIC's?
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline   Reply With Quote
Old 10th May 2008, 08:41 AM   #11 (permalink)
Experienced Member
Stay away from the padlock lol Only use this if you know what your doing!
Just saying that as you do not want to know what happened when a newbie of SF learnt that little feature a little to early from me
Spency.
Old 10th May 2008, 12:40 PM   #12 (permalink)
Experienced Member
Gramo,
I suppose that's why they pay you the BIG BUCKS hey?
Super solution! Works like a charm. Thank you very much sir!
Old 10th May 2008, 02:44 PM   #13 (permalink)
Experienced Member
Originally Posted by SPDCHK
Gramo,
I guess you must have missed my earlier post then.
Old 10th May 2008, 04:13 PM   #14 (permalink)
Experienced Member
Sorry Pommie.
When I open the forum I usually go to the last post first. Saves me time scanning (paging down through it all again). I did notice your post, but with gramo's warning for NOOBS not to play with library code, I'd thought it best to heed the warning.
I'm now "playing" with the DS1820 1-wire temperature sensor chip, modifying the example code for the 18F1320, and not USART but LCD. So far I'm not having any luck. I don't read anything from the sensor. But, I'll first fiddle around as much as I can before posting another thread on that topic.
Old 10th May 2008, 04:15 PM   #15 (permalink)
Experienced Member
Is it an 18S20 or 18B20
There are libraries for both as part of Swordfish
Bill
Brown-out reset on LF PIC bananasiong Micro Controllers 10 17th May 2007 12:33 AM
74LS90 power-on auto reset Torben Electronic Projects Design/Ideas/Reviews 17 20th December 2006 04:18 AM
vx-5r reset problem tom muleady General Electronics Chat 2 5th July 2006 06:01 PM
uC 'network' reset circuitry rockin_rick Electronic Projects Design/Ideas/Reviews 8 30th May 2006 01:03 AM
How to reset SCR used for triggering camera flash shootfirst Electronic Projects Design/Ideas/Reviews 20 28th September 2005 08:40 PM
