Old 8th May 2008, 06:55 AM   (permalink)
Experienced Member
loup-garou is on a distinguished road
Talking Programming the PIC18F4525
hi everybody,
I started programming the PIC18F4525 (same us PIC18F2525/2620/4620)using C18 compiler in MPLAB (C language),I compiled and simulated some simple codes (LED blinking in portB) , but when I tried to use the PORTA as an input, i got problems with simulation, cause the PORTA pins should be configurated as digitals or analogs, despite many attempts, i wasn't able to put them in digital.
I used codes that I found in the datasheet :
ADCON1<3:1>=1111 , ADCON1=6 and PCFG<3:0> = 1111
they are ignored by my compiler (syntax error) hence, I still have the problem, how can I figure it out please?
thanks in advance.
Rq: PORTB has aslo AN I/O but I disable it in the Configuration bits menu of MPLAB (those of PORTA aren't there) i solved also the PORTB problem with using LATB insted of PORTB, I know I can use LATA and the simulation will work, but I think I'd better write a code that clearly mention that the Anlog I/O are disabled (Digitals are enabled). take a look at the pin diagrams that I joined-my PIC is the 18F4525
loup-garou is offline   Reply With Quote
Old 8th May 2008, 07:33 AM   (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
ADCON1=0x0f should set all ports to digital.
Pommie is online now   Reply With Quote
Old 8th May 2008, 12:57 PM   (permalink)
Experienced Member
thank you Pommie.
Errors while programming a PIC16F874A Kitt0s Micro Controllers 17 8th March 2008 07:12 PM
Question about Inchworm+ Quan Micro Controllers 54 28th October 2007 12:20 AM
UNIT Committment solution using Dynamic programming arijit18 Electronic Projects 1 18th October 2007 08:27 PM
Programming languages sram General Electronics Chat 9 2nd March 2007 04:14 PM
Good Computer Programming Book ThermalRunaway Chit-Chat 21 16th September 2005 10:05 PM
