Old 12th May 2008, 02:18 PM   (permalink)
I should have put some notes out to the side of the program. When I fix it later I'll write a lot of side notes. Here's my logic
transmitter:
Do ADC. Send a fixed IR signal followed by a minimum gap for whenever you send a value close to zero. (if not the IR receiver will turn up the gain and stop receiving)
wait an amount of time based on the ADC, then send another IRpulse to tell the receiver to stop counting.
receiver:
listen for the IR receptor to drive the pin low, wait for pin to be high again and start counting. First count the minimum gap time, then start counting the value to be used in the main program. When the pin is driven low again stop counting. Do PWM.
So I hope that helps this to be clearer. Now I'm doing two channels...send a pulse then data1 then a pulse then data2 then a pulse.....but now I need some kind of really long pulse to lead the data to let the receiver know to start counting data1 then data2.
jeremy
jeremygaughan is offline
Old 15th May 2008, 04:03 AM   (permalink)
Hi jeremy are you with me?
Yes I think you are with me.I have written a code for you specially the transmitter part.But I haven't checked it yet.
I'm sending a data packet through IR LED.Don't know whether you like it or not but I have to do.Just go through it.
GP0=button (active low)
GP1=IR TX LED
;Che_But - sends one packet at a time
Che_But	btfss	GPIO,GP0	;has the button pressed?
	goto	$+2		;yes,
	goto	Che_But		;no,then wait until press
	call	Transmit	;transmit the packet
	btfss	GPIO,GP0	;button still pressed?
	goto	$-1		;yes,
	goto	Che_But		;no,has released,
;Transmit - routine sends data in the packet (brightness)
Transmit
	call	Check_AD
	movlw	.8
	movwf	Counter		;makes counter for 8 bit
Loop3	bcf	STATUS,C
	rlf	Brightness,F
	btfss	STATUS,C
	goto	Do_Zero
	goto	Do_Ones
Do_Ones	movlw	d'22'
	movwf	Highpulse	;makes 600uS high time
	goto	$+3
Do_Zero	movlw	d'12'		;makes 300 + low time
	movwf	Highpulse
	call	Do_Logic	;transfer the logic
	call	Do_Gap		;transfer fix gap time
	decfsz	Counter,F	;repeat for other bits
	goto	Loop3
	return
;Check_AD returns the brightness value
Check_AD
	bsf	ADCON0,GO
	btfsc	ADCON0,GO
	goto	$-1
	movf	ADRESH,W
	movwf	Brightness	;brightness contains dim level
	return
;Do_Logic - logic high time > logic low time
Do_Logic
Loop1	BSF	GPIO,1		;27 commands makes 38khz
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	BCF	GPIO,1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	decfsz	Highpulse,F
	goto	Loop1
	return
;Do_Gap - a fix gap time min 300us needed
Do_Gap
	movlw	D'12'		;makes a fix gap after burst = 300uS
	movwf	Lowpulse
Loop2	nop			;27 commands makes 38khz
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	nop
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	decfsz	Lowpulse,F
	goto	Loop2
	return
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 15th May 2008, 05:20 AM   (permalink)
very nice. I like the roll folder left to transmit exactly the value you want. Looks like a good way to get a precise number. I'm just counting the gap, whereas you are sending the 8 bit number one bit at a time. One thing I see is that you need to send a unique pulse before the whole thing so the receiver knows that it's the beginning of the packet being sent. I see that you have the button so that it only sends one packet at a time, but if it catches it in the middle or gets the first bit of interference from a light in the house it will be out of sequence. I'm crazy busy at work lately, but I'm going to build your code and try it when I get a moment. Also, I've almost got my two channel code going. Big long IR pulse to mark the start of the packet then gap, small pulse, gap, small pulse. Then I'm going to use a lightened micro servo to turn it. Soon I'll have control of this foam, pager motor pulling, scotch tape, toothpick braced junker.
jeremy
Old 15th May 2008, 05:33 AM   (permalink)
Oh you have stolen my packet transferring codes
A similar technic that I used in my IR projects.Thats a clever technic.So you no need to worry about the resolution or time takes to transfer.
8 bit resolution is more than enouth to dim a LED smoothly or to speed control a DC motor.
Gayan
My Website
Old 2nd August 2008, 12:23 AM   (permalink)
Default IR with interrupts
it's been a while since I could work on this, but now it works pretty well. It was really difficult to figure out the pwm to run two motors with varying speeds at the same time. Maybe there is a better way that someone knows. Please feel free to criticize if you know about that. The problem I'm having now is that the motor pulses about 5 times per second. Which as far as I can tell doesn't coincide with my interrupt timing. Right now that is my biggest problem, Any ideas?
The goal eventually with the second channel is to run an actuator. I only know a little about them so it's going to be a while before I figure them out. Here are the codes for the transmitter and the receiver. The receiver is 12f629 because I only had one 12f675 in my collection. It doesn't need to do adc so I went with it on the receiver. Cool thing is it runs with the 12f675's code so I didn't have to do anything to it. There is some redundancy that can be removed from the code and I'm on that right now, but I'm really interested in making it stop pulsing the motor.
;1 channel receiver using IR and ADC on a 12f629
	list P=12f629
#include <p12f629.inc>
	__config _INTRC_OSC_NOCLKOUT & _BODEN_OFF & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CPD_OFF & _CP_OFF
	ERRORLEVEL -302
	cblock		20h
	longpulse, pause, pulseontime, pulsegap, pulsegap2, pwmhighcounter, pwmlowcounter, pwmhighcounter2, pwmlowcounter2, pwmtimer
	endc
	ORG		0000h
	goto	start1
	ORG		0004h
	call	readpulsegap
	BCF		PIR1,0
	RETFIE
start1
	bsf		STATUS,RP0		;bank 1
	movlw	0x08
	movwf	TRISIO		;set I/O
	BSF		PIE1,0		;something for interrupts
	bcf		STATUS,RP0
	movlw	0x07		;turn off comparitors
	movwf	CMCON
	movlw	0xc0
	movwf	INTCON		;set interrupt time
	movlw	0x21
	movwf	T1CON
start
	call	pwm			;runs motor the whole time while waiting for the interrupt
	call	pwm			;that will read the IR signal
	call	pwm
	call	pwm
	call	pwm
	call	pwm
	goto	start
pwm
	movlw	0xff		;sets the length of pwm interval
	movwf	pwmtimer
pwm2
	movf	pulsegap,0	;takes the pulse gap read in the interrupt and puts in in the pwm counter
	movwf	pwmhighcounter
	movf	pulsegap2,0
	movwf	pwmhighcounter2
pwmrun
	bsf		GPIO,1		;turn pwm on
	bsf		GPIO,0
	decfsz	pwmhighcounter,1
	goto	$+2			;count dowm channel 1 if still counting skip turning it off
	bcf		GPIO,1		;if done counting turn off channel 1
	decfsz	pwmhighcounter2,1
	goto	$+2			;count down channel 2 if still counting skip turning it off
	bcf		GPIO,0		;if done counting turn off channel2
	decfsz	pwmtimer,1	;count down rest of time to make 256 cycles total
	goto	pwmrun
	return
readpulsegap			;start reading pulse gap
	clrf	pulsegap
	movlw	0x28		;sets value that counts IR pulse length that makes sure the
	movwf	longpulse	;pulse length is the long one that signals start of data
readpulsegap1
	goto	$+1			;wait at least 29 commands
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	btfsc	GPIO,3		;keep testing the IR reveiver to make sure it is constantly reading a pulse
	goto	readpulsegap;if the pulse isn't long enough start counting the next pulse
	decfsz	longpulse,1
	goto	readpulsegap1
wait
	btfss	GPIO,3		;wait for pulse to stop being sent
	goto	$-1
	movlw	0x0e
	movwf	pause
leadpause
	NOP					;27 commands makes 38khz
	goto	$+1			;count off minimum pause
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	NOP
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	decfsz	pause,1
	goto	leadpause
wait2
	btfss	GPIO,3		;if still no pulse then start counting the length of the pulse gap
	goto	betweenchannels
	goto	$+1			;keep counting until pulse starts again
	goto	$+1
	goto	$+1			;goto commands used to recompress the long pause into an 8 bit number
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	incf	pulsegap,1
	goto	wait2
betweenchannels			;wait until pulse stops to continue
	btfss	GPIO,3
	goto	$-1
	nop
	nop
wait3					;count second pulse same as counting the first pulse
	btfss	GPIO,3
	return
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	incf	pulsegap2,1
	goto	wait3
	return
	end
;1 channel transmitter using IR and ADC on a 12f675
	list P=12f675
#include <p12f675.inc>
	ERRORLEVEL -302
	cblock		20h
	datauno, datados, temp, irpulse, datagap, datagap2, min, trimpwm, trimpwm2, pwmcounter
	endc
	ORG		0000h
	goto	start1
	ORG		0004h
	call	adc
	BCF		PIR1,0
	RETFIE
start1
	movlw	0x34
	movwf	ANSEL
	movlw	0x1c
	BSF		PIE1,0
	bcf	STATUS,RP0
	movwf	CMCON
	movlw	0x09
	movwf	ADCON0		;set to read first pot of controller
	movlw	0xc0
	movwf	INTCON		;set interrupt timers
	movlw	0x21
	movwf	T1CON		;set interrupt timers
	call	adc
start
	btfss	GPIO,3		;check if test button is pushed
	call	trim
	call	leadIRpulse	;send long pulse to let receiver know code is starting
	call	data1		;make a gap in the pulse to be counted by receiver for channel 1
	call	IRpulse		;send normal length pulse to to tell receiver data for first channel has ended
	call	data2		;make a gap in the pulse to be counted by receiver for channel 2
	call	leadIRpulse	;tells receiver that data for the second channel has ended and new data is coming
	call	data1		;repeats same stuff as before
	call	IRpulse
	call	data2
	call 	leadIRpulse
	call	data1
	call	IRpulse
	call	data2
	call	IRpulse		;send normal pulse this time to only tell the receiver that data for channel 2 has ended
	goto	start
adc
	movlw	0x09		;set to read channel 1 potentiometer
	movwf	ADCON0
	bsf		ADCON0,1	;start adc
waiting
	btfsc	ADCON0,1	;wait for adc to finish
	goto	waiting
	movf	ADRESH,0	;move adc reading to a file to use later
	movwf	datauno
	goto	$+1			;give time to let adc charge for channel 2
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	movlw	0x0d		;change to read channel 2 potentiometer
	movwf	ADCON0
	bsf	ADCON0,1
waiting2
	btfsc	ADCON0,1	;waiting for adc
	goto	waiting2
	movf	ADRESH,0
	movwf	datados		;move data to second channel
	return
IRpulse					;set value for length of minimum gap time
	movlw	0x0f		;this way there is always a gap even if the
	movwf	min			;data being sent is zero
	movlw	0x1e		;set time for the IR pulse length
	movwf	irpulse
IRpulse2
	BSF		GPIO,1		;27 commands makes aprox. 38khz
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	BCF		GPIO,1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	decfsz	irpulse,1	;count down pulse length
	goto	IRpulse2
minpause
	goto	$+1			;this is the pause that precedes every data pause or pulse gap
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	NOP
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	decfsz	min,1		;count down minimum gap time
	goto	minpause
	return
leadIRpulse				;set length of unique lead IR pulse to let receiver know that
	movlw	0x0f		;the data is about to start
	movwf	min
	movlw	0x28
	movwf	irpulse
leadIRpulse2
	goto	$+1			;same IR pulse deal as before
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	BCF		GPIO,1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	decfsz	irpulse,1
	goto	leadIRpulse2
minpause2
	goto	$+1			;same minimum gap deal as before
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	NOP
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	decfsz	min,1
	goto	minpause2
	return
data1
	movf	datauno,0	;move the adc information from the channel one potentiometer to
	movwf	datagap		;a counter to send the gap between pulses which will be counted by the receiver
dataa
	goto	$+1			;goto commands used to make gap much longer than just the 8 bit adc value would
	goto	$+1			;if it were counted down by it self
	goto	$+1
	goto	$+1
	goto	$+1
	decfsz	datagap,1
	goto	dataa
	return
data2
	movf	datados,0	;data gap being sent for channel 2
	movwf	datagap2
datab
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	goto	$+1
	decfsz	datagap2,1
	goto	datab
	return
trim					;there is a switch in the circut that can be pushed to allow
	call	adc			;the adc to be trimed using extra 5k pots
	movlw	0x20		;note only trims channel one
	movwf	pwmcounter
pwmstart
	movf	datauno,0
	movwf	trimpwm
	movwf	trimpwm2
pwm
	bsf		GPIO,5
	decfsz	trimpwm,1
	goto	$-1
	bcf		GPIO,5
	incfsz	trimpwm2,1
	goto	$-1
	decfsz	pwmcounter,1
	goto	pwmstart
	btfss	GPIO,3
	goto	trim
	return
	end
jeremy
Old 2nd August 2008, 01:19 AM   (permalink)
I received my free helicopter (promo from Energizer battery company) about a week ago.
What a riot!
It uses IR remote control for up, down, left and right.
It speeds up when turning right and slows down when turning left so it is tricky to make it hover.
It is more convenient than my RC airplane because it flies in the house and in the yard in the evenings when the wind is low. It flies for about 6 minutes per charge. It cools for 10 minutes after a flight then charges for 20 minutes.
It is a Spinmaster Air Hogs Havoc Heli available at Wal-Mart. It is made in China so it is very inexpensive.
I bought one for my son. It was dead but Wal-Mart replaced it for a good one.
audioguru is offline
Old 2nd August 2008, 01:29 AM   (permalink)
AG,
Those are always great fun. I managed to find an inexpensive (used) Air Hogs Aerosoar (which isn't the best micro plane, unlike the Aero Ace which is quite excellent) and I plan to use the parts in my own scratch-built planes.
You should see some of the stuff people have designed using Air Hogs parts!
-Omar
Omar.M is offline
Old 2nd August 2008, 01:46 AM   (permalink)
Default Any links?
Originally Posted by Omar.M View Post
AG,
You should see some of the stuff people have designed using Air Hogs parts! Omar
Any links, Omar?
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
atferrari is offline
Old 2nd August 2008, 01:47 AM   (permalink)
That's an awesome little chopper. I got a set of two that have IR leds on them and you can shoot the other chopper and it's tail will stop working for about 3 seconds. It's a lot of fun for 5 minutes. I got another one and that is what I'm destroying to take the battery and motor. Here is a picture of my test setup it's pretty disgusting. I've got the guts of a playstation controller hooked to a pic and some IR leds then hooked to the second board with the receiver and a mosfet and motor just to suck all the power form a USB wire. There are wires connecting them but it's just for power. It's been a lot of fun to put it together.
jeremy
Old 2nd August 2008, 01:49 AM   (permalink)
At a hobby show I saw the home-made indoor gym airplanes controlled with the parts from those cheap micro RC cars.
The Air Hogs airplanes are flying on the edge of a stall with the nose pointing up. They are probably extremely fragile since you can't pick them up without reading the warnings in the instructions.
My helicopter is strong. It has crashed into the ceiling, walls, furniture, my wife, other things, my son's helicopter, my car. the driveway, a couple of trees and the eavestrough on my home. It is still like new.
Old 2nd August 2008, 01:54 AM   (permalink)
Originally Posted by atferrari View Post
Any links, Omar?
Sure, there are tons on RC Groups, a rather popular RC forum (check the micro section).
Here is a link to a thread regarding building with Aeroace (Air Hogs) guts:
http://www.rcgroups.com/forums/showthread.php?t=535921
One favourite micro plane that is the standard beginner plane is the "BUMP"-- RCG has the plans up in the sticky. Once I get my Aerosoar (and I convert the battery to a smaller LiPo), I'll build a BUMP.
Another fun design is the traditional IFO plane(shaped like a tiny flying disk-- really fun to fly!)
-Omar
Omar.M is offline
Old 2nd August 2008, 01:55 AM   (permalink)
My son bought 3 no-name-brand helicopters because he couldn't find a Wal-Mart store that had the Air Hogs one. They were all defective.
The Wal-Mart store near me had about 30 of the Air-Hogs one. Maybe half of them work properly.
Old 2nd August 2008, 01:59 AM   (permalink)
Oh yeah, at RCGroups, you can find pages upon pages of discussion regarding the "Bit Char-G" conversions (or something of the like... name slips me).
The conversion requires a range increase and some sort of gearbox but otherwise it is quite possible.
Ah yes, midway through this reply I went through my old favourites and here is the website:
http://members.aol.com/rchelicam/microszr/microszr.htm
-Omar
Omar.M is offline
Old 2nd August 2008, 02:00 AM   (permalink)
I've seen those airplanes built form small cars. They can be fun but the control is what we can "bang bang" full on or full off for the left and right rudder. Like you said they are so fragile that it's more frustrating than fun (for me) to fly them. What I'm trying to do now is build an airplane that you can slam like a airhogs chopper.
I had the same problem with the choppers not working it was my third one that finally worked well.
For me the carbon butterfly design for microflyers is the toughest micro. However it's a little expensive to buy the carbon.
jeremy
Old 2nd August 2008, 03:11 AM   (permalink)
My son found a hobby store where the owner was flying an RC "butterfly" airplane inside. It was $120.00.
My much bigger and faster Chinese RC airplane was $70.00.
My Air Hogs was free but Wal-Mart sells them for $29.92.
where to buy test equipment notwist General Electronics Chat 5 30th March 2008 09:37 PM
Test Equipment abbarue General Electronics Chat 3 10th November 2007 04:59 AM
Good Electronic Supply's Sites, Everyone Come On In! :P Electric Rain General Electronics Chat 44 27th August 2007 11:05 PM
more test equipment! HiTech Chit-Chat 5 15th September 2006 05:41 PM
High speed switch in psu..I have better test equipment now heathtech General Electronics Chat 26 11th July 2005 05:15 PM
