so your saying that it might not work at all
Simplicity rules Good enought - its perfect ?? 2 Gig of free online backup space Are you a Chemist? |
Or buy the USB based PICkit2 or Junebug that will work with your laptop.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
Well its part of my final project so Im going to have to get it working.
I allready hav a PICKit2 to run from my laptop (school bought it for me And as far as i know i can program tha 18f4550 from the PICKit2 som im actually ok there. Just need to get the ICD2 Clone working so I can write about it...
When you find the box you still have to debug the ICD2. We have been over this many times in the days prior to PICkit2. As said earlier, do the loopback test without a processor first. Do it at the RX TX processor pins to check the wiring all the way to the processor. That with a working processor/crystal should allow the ICD2 connect even if other things are not quite right. In general ICD2s are not too difficult to get working. I have an assortment of them including several powered by a single 1 amp voltage regulator set to 13V, I did not have to generate VPP from RS232. Bill got me started with his Junebug and the ICD2s are mostly paperweights.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 8th May 2008 at 11:35 AM. |
The loopback test without the PIC (read loop in the socket for PIC) works but im not able to connect to ICD2 (Im using bills Bootlader and have a external power on the ICD2)
But at my school they sell out the old computers that they er changing to teachers only ( i have tried to get one without any luck) edit: But thinking of it it might be the crystal that are not working properly. Is there any way to check it? or it might be an ide to actually connect it !?!?!?!
Simplicity rules Good enought - its perfect ?? 2 Gig of free online backup space Are you a Chemist? Last edited by Kryten; 8th May 2008 at 12:00 PM. |
The crystals a good guess, try using 18pf thru 22pf. Does your school have an oscillioscope?
No I dont have a ocillioscope but making the connection between the PIC and Crystal seems to have made it work (Im so stupid at times)
After checking everyother connection but the crystals i couldnt see any faults but it works now so: Im happy (as Droopy says) Eidt: But school has and they ar currently rebuilding the electronics deparment so no luck there
Simplicity rules Good enought - its perfect ?? 2 Gig of free online backup space Are you a Chemist? Last edited by Kryten; 8th May 2008 at 04:02 PM. |
![]() Pin 4 on the RS232 is connected to MCLR/RESET on the PIC. If your USB->RS232 does not handle this line correctly the PIC will never come out of reset or never be reset. The loopback has to work but with a broken RESET it the ICD2 will not function.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 8th May 2008 at 12:49 PM. |
Well it works fine now. I just need a 47k (or 50k) Pot to set the pic that are beeing programmeds MCLR everything else works fine just now
The pots a bit of mystery for me too.
Blueroom Bill,
Did you get the email I sent you the other day about a JuneBug board?
August Treubig AG5AT |
The Pot is for using a OPAmp for targets MCLR instead ot transistors (had to improvise as the school is beeing rebuildt/upgraded and I got the wrong transistors). Its a option on stoltz schematics, but i was planning on using the orginal with transistors..
Simplicity rules Good enought - its perfect ?? 2 Gig of free online backup space Are you a Chemist? Last edited by Kryten; 9th May 2008 at 08:37 AM. |
| Help with ICD2 clone!!!!!!!!!!!! | juanbbv | Micro Controllers | 17 | 5th April 2008 05:07 AM |
| Debugging 877A with MPLAB | williB | Micro Controllers | 10 | 7th May 2007 03:53 PM |
| Need help badly on Inchworm and MPLAB | thushy | Micro Controllers | 14 | 11th March 2007 06:05 PM |
| Some Question About Inchworm | Ayne | Micro Controllers | 29 | 7th March 2007 03:07 AM |
| Inchworm project started | williB | Micro Controllers | 69 | 5th March 2007 06:55 PM |
