Old 6th May 2008, 08:28 AM   #16 (permalink)
Experienced Member
Kryten is on a distinguished road
That wont help. Mplab somethimes has only USB option for ICD2 in settings-> com. I have tried everything i can think of but nothing seems to help (yeh i have just reinstalled Mplab 8.10)
Simplicity rules
Good enought - its perfect
My virtual city
Are you a Chemist?
Kryten is offline   Reply With Quote
Old 6th May 2008, 08:50 AM   #17 (permalink)
Super Moderator
That's because you don't have any COM ports, reassign it to COM1 and reboot the computer, then check COM1 exists in control panel.
Old 6th May 2008, 08:53 AM   #18 (permalink)
Experienced Member
well i have don it but will try again (as it is part of my final project to become an electronics enginner)
Simplicity rules
My virtual city
Are you a Chemist?
Old 6th May 2008, 10:17 AM   #19 (permalink)
3v0
Moderator
3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all
So little update from me.
Mplab cant "see" my rs232 serial usb adaptor (strange) so it cant open the correct port (com1)
Anyone got any ide what i can do?
What do you see in the device manager under
Ports(COM & LPT)?
To control the world from your PC with USB I suggest USB Bit Wacker
3v0's Tutorials for ABSOLUTE BEGINNER
C, PIC 18F, MPLABŪ and MCC18 Compiler
3v0 is offline   Reply With Quote
Old 6th May 2008, 11:53 AM   #20 (permalink)
Experienced Member
I see
Prolific USB-to-Serial Comm Port (com1)
And when i try to connect now i get just:
ICD0021: Unable to connect with MPLAB ICD 2
MPLAB ICD 2 Ready
So i guess i need to use Bill's BL and try to see if it helps
Edit:
It also helps connecting the D-sub9 the correct way
Simplicity rules
My virtual city
Are you a Chemist?
Old 6th May 2008, 12:06 PM   #21 (permalink)
3v0
Moderator
Given that this has gone away
ICDWarn0027: The selected baud rate is not supported by your system. Chances are it will work anyway, but if persistent communications occur, consider switching to a lower baud rate.
ICD0019: Communications: Failed to open port: (Windows::GetLastError() = 0x2, 'Systemet finner ikke angitt fil.
It seems you are making progress.
Before you reprogram the chip see if you can get MPLAB to reprogram it. Under debugger or programer in the main menu "Download New OS" or similar.
Old 6th May 2008, 12:22 PM   #22 (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
The PL2303 is common but can be tough to get running with the ICD2. Try different drivers (I have one in my downloads section that may work)
Bill
Smart Kits build Smart People
blueroomelectronics is online now   Reply With Quote
Old 6th May 2008, 12:37 PM   #23 (permalink)
Experienced Member
I will try that.
I have just spent some time checking that everything is wiredup correctly and it is according to the schematics that Lothar Stoltz has made... Im using a MAX232A with 0.1uF caps...
It looks like crap but it should work (based on the schematics)
Simplicity rules
My virtual city
Are you a Chemist?
Old 7th May 2008, 07:26 AM   #24 (permalink)
Experienced Member
Does anyone know wehter its possibel to check ansd see if my MAX232A is faulty?
I dont have acesse to a scope only a DMM
Simplicity rules
My virtual city
Are you a Chemist?
Old 7th May 2008, 08:02 AM   #25 (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
If you remove your 876A and short pins 17 & 18 of the socket, you should be able to run hyperterminal and see what you type in the window. Make sure you select the right com port and set flow control to "none". If you can see what you type then you max232 is working fine.
Pommie is online now   Reply With Quote
Old 7th May 2008, 08:04 AM   #26 (permalink)
Experienced Member
ericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to behold
hi Kryten,
Look at this jpg.
I have indicated the states on the drawing.
On the loop back test link [bottom of MAX] the two states are shown one above the other.
Disconnect from thePIC while testing.!
Any questions, ask..
Eric
"Good enough is Perfect"
PIC tutorials:
Nigel's site: http://www.winpicprog.co.uk/
Gramo's site: http://www.digital-diy.net/
Old 7th May 2008, 09:59 AM   #27 (permalink)
Experienced Member
Hmm i think i must test both versions today (need only a hyperterminal cous there isnt one i Vista )
Simplicity rules
My virtual city
Are you a Chemist?
Old 7th May 2008, 10:12 AM   #28 (permalink)
Experienced Member
Look here:
http://www.bb-elec.com/tech_articles...2_loopback.asp
Eric
PIC tutorials:
Old 7th May 2008, 11:38 AM   #29 (permalink)
Experienced Member
have a look at the first page here and see that i have been there in order to test my USB-to-series-adaptor.
But i vill try it again (maybe only the software to check the max232)
And i found a HyperTerminal for download.. so i think it will work..
Simplicity rules
My virtual city
Are you a Chemist?
Old 7th May 2008, 02:39 PM   #30 (permalink)
Experienced Member
A loopback test will only check the connections, the timing or latency is not checked. USB to RS232 is only an emulation and as such may not be 100%
In my experience only one USB to RS232 adapter works perfectly and that's the expensive Digi (I/O networks) ones.
Bill
Help with ICD2 clone!!!!!!!!!!!! juanbbv Micro Controllers 17 5th April 2008 05:08 AM
Debugging 877A with MPLAB williB Micro Controllers 10 7th May 2007 03:53 PM
Need help badly on Inchworm and MPLAB thushy Micro Controllers 14 11th March 2007 06:05 PM
Some Question About Inchworm Ayne Micro Controllers 29 7th March 2007 03:08 AM
Inchworm project started williB Micro Controllers 69 5th March 2007 06:56 PM
