Old 5th May 2008, 04:03 AM   #1 (permalink)
Experienced Member
sachin.kolkar is infamous around these parts
Default problem with key pad matrix interfacing
i m facing problem with 4X4 keypad matrix interfacing with PIC16F72 uc
When i run the program with simulator it works fine... one port is i am using for the key value using LED display .
when i connect the led & key board matrix , LED's are toggles continuesly in random manner
here is my code
#define keyport PORTB           //Keypad Port
#define keyportddr TRISB      //Data Direction Register
static char keytab[17]={0,1,2,3,10,4,5,6,11,7,8,9,12,13,0,14,15};
unsigned char keyval;   //A variable
void key_init();
unsigned char get_key();
 unsigned char i,key=1,j;
 void compare();
int main()
 DDRD=0x00;
 PORTD=0x00;
 DDRA=0xC0;
 PORTA=0xFF;
while(1)
 key_init();
get_key();
| Prototype: void key_init(void);       |
| Return Type: void                     |
| Arguments: None                       |
| Description: Initialize ports and     |
|              Keypad.                  |
void key_init(){
        keyportddr = 0xF0;
        keyport = 0xFF;
| Prototype: unsigned char get_key(void);       |
| Return Type: unsigned char                    |
| Arguments: None                               |
| Description: To read key from the keypad      |
unsigned char get_key(){
       key=1;
        for(i=0;i<4;i++){               //Loop for 4 rows
                keyport &=~(0x01<<i);   //Make rows low one by one
                        if(PORTB.F4==0){
                         //check COL1
                                while(!(keyportpin & (1<<col1)));
                                //wait for release
                                PORTD=keytab[key];
                                return key;
                                //return pressed key value
                        if((PORTB.F5==0))){
                         //Check COL2
                                key += 1;
                                //Second key pressed
                                while(!(keyportpin & (1<<col2)));
                                //wait for release
								PORTD=keytab[key];
                                return key;
                                //return key value
                        if(PORTB.F6==0){
                         //Check COL3
                                key += 2;
                                //Third key pressed
                                while(!(keyportpin & (1<<col3)));
                                //Wait for release
								               PORTD=keytab[key];
                                return key;
                                //Return value
                        if(PORTB.F7==0){
                         //check COL4
                                key += 3;
                                //Fourth key pressed
                                while(!(keyportpin & (1<<col4)));
                                //Wait for release
								PORTD=keytab[key];
                                return key;
                                //Return key value
                key +=4;        //Next row
                keyport |= 0x01<<i;
                //make read row high again
        return 0;   //return false if no key pressed
PLZ help me guys......
sachin.kolkar is offline   Reply With Quote
Old 5th May 2008, 04:30 AM   #2 (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
A quick look at your code suggests you have only posted part of it. There are no definitions for col1, col2, ddrd(???) etc. I also have no idea if you are including the right files and setting the config value. Could you also post which compiler you are using.
Pommie is online now   Reply With Quote
Old 5th May 2008, 07:29 AM   #3 (permalink)
Experienced Member
Question
sorry, here is the code
void key_init();
 void compare();
int main()
 TRISC=0x00;
 PORTC=0x00;
 while(1)
 key_init();
get_key();
| Return Type: void                     |
| Arguments: None                       |
|              Keypad.                  |
void key_init(){
        keyportddr = 0x0F;
        keyport = 0xFF;
| Arguments: None                               |
       key=1;
                        if(PORTB.F4==0){
                         //check COL1
                                //wait for release
                                PORTD=keytab[key];
                                return key;
                        if((PORTB.F5==0))){
                         //Check COL2
                                key += 1;
                                //wait for release
								PORTD=keytab[key];
                                return key;
                                //return key value
                        if(PORTB.F6==0){
                         //Check COL3
                                key += 2;
                                //Third key pressed
                                //Wait for release
								               PORTD=keytab[key];
                                return key;
                                //Return value
                        if(PORTB.F7==0){
                         //check COL4
                                key += 3;
                                //Wait for release
								PORTD=keytab[key];
                                return key;
                                //Return key value
                key +=4;        //Next row
                keyport |= 0x01<<i;
Old 5th May 2008, 07:33 AM   #4 (permalink)
Experienced Member
i m using mikro C compiler......
Old 5th May 2008, 07:23 PM   #5 (permalink)
Experienced Member
mister_e is on a distinguished road
why not using the built-in Keypad library?
If you have erratic results, to me, it sounds like you forgot to add some pull-up resistors.
HTH
Steve
______________________
info@mister-e.org
www.mister-e.org
mister_e is offline   Reply With Quote
Old 5th May 2008, 10:59 PM   #6 (permalink)
Experienced Member
arhi is just really nicearhi is just really nicearhi is just really nice
Why don't you check out the:
http://www.mikroe.com/pdf/keypad_board_schematic.pdf
http://www.mikroe.com/zip/keypad_board_examples.zip
you have there everything you need to make the keypad work
http://www.it4um.com
arhi is offline   Reply With Quote
Old 6th May 2008, 09:22 AM   #7 (permalink)
Experienced Member
Question
i was use that built in keypad library...........but led's toggles without pressing any key.....
HTH
i did it boss u can see this in my code,
if i m using key pad library i can't do this.....
Old 6th May 2008, 09:36 AM   #8 (permalink)
Experienced Member
I can't see where in your code you are turning on the WPUs. I can't see where you write to a port to light LEDs.
Old 7th May 2008, 08:55 AM   #9 (permalink)
Experienced Member
Question
i m initialize PORTC for the LED light....
Old 7th May 2008, 09:01 AM   #10 (permalink)
Experienced Member
You set port C to output and set all pins low but then you write the keyboard value to Port D. The 16F72 doesn't even have a Port D.
Old 7th May 2008, 09:47 AM   #11 (permalink)
Experienced Member
void key_init();
 void compare();
int main()
 TRISC=0x00;
 PORTC=0x00;
 while(1)
 key_init();
get_key();
| Return Type: void                     |
| Arguments: None                       |
|              Keypad.                  |
void key_init(){
        keyportddr = 0xF0;
        keyport = 0xFF;
| Arguments: None                               |
       key=1;
                        if(PORTB.F4==0){
                         //check COL1
                                //wait for release
                                PORTC=keytab[key];
                                return key;
                        if((PORTB.F5==0))){
                         //Check COL2
                                key += 1;
                                //wait for release
								PORTC=keytab[key];
                                return key;
                                //return key value
                        if(PORTB.F6==0){
                         //Check COL3
                                key += 2;
                                //Third key pressed
                                //Wait for release
								               PORTC=keytab[key];
                                return key;
                                //Return value
                        if(PORTB.F7==0){
                         //check COL4
                                key += 3;
                                //Wait for release
								PORTC=keytab[key];
                                return key;
                                //Return key value
                key +=4;        //Next row
                keyport |= 0x01<<i;
i corrected it ....
another problem is when i connect the RB4-RB7,
all portc leds start toggling..
Old 7th May 2008, 09:54 AM   #12 (permalink)
Experienced Member
This suggests that you have not even managed to get this code to compile. As I said in my initial reply col1, col2 etc weren't defined, and they still aren't.
Are you posting all your code?
Old 7th May 2008, 10:00 AM   #13 (permalink)
Experienced Member
Question
yes, i posted complete code , compiled & run the code, it works fine in simulator.....
while i m using the mikroC keypad library.....same problem encountering...
Old 7th May 2008, 10:02 AM   #14 (permalink)
Experienced Member
i m using the same code for the atmel ATTINY2313
Old 7th May 2008, 10:11 AM   #15 (permalink)
Experienced Member
when i initialise any port as input port & pull up resistors high..
but when i connect my DMM across that port pins it shows the low at that pins.....
Ex:
TRISB=0xFF;
PORTB=0xFF;
problem with serial port interfacing froten Micro Controllers 1 2nd January 2007 06:07 PM
Problem Interfacing Basic Stamp BS2px24 with LM629 kwang General Electronics Chat 4 25th December 2006 09:07 AM
problem in interfacing msm6242b with at89c52 esconele Micro Controllers 21 18th May 2006 10:46 AM
Problem when interfacing servo motors with PIC18F452 MCU! A_D_G Micro Controllers 2 14th February 2006 09:50 AM
pc keyboard interfacing problem econsyst Micro Controllers 0 8th November 2003 08:28 PM
