| Hello i have built the NOPPP to try to program my pic16F84(A) although i have no run into a problem! i have no power supply the only power supply i have is an OLD meccano transformer the information given on it is as follows A.C input 220/250 volts 50/60 cycles 12 Watts Outputs Alternative Continuous ratings A - 12 volts D.C 8 Watts B - 15 volts A.C 9 V.A i have used a multimeter and checked the output at A but the increments seem to go up from 7.8 - 11.6 - 15.3 - 18.5 although from earlier experiments with 555 timer circuits it seems i need a capacitor over the output otherwise they would never work! but with the capacitor over the outputs the voltage readings were as follows 11.2 - 17 - 22.8 - 27.9 if i were to use this for my NOPPP i would need a +5v and a +12v could i get these voltages from this supply by adding the appropriate resistor values on the input of the circuit? and how come there is a large difference with the capacitor over the outputs? :? Thanks Kane | |
| also what kind of amperage/current are we looking at for programming? | |
