Old 1st May 2008, 01:15 PM   (permalink)
Default Do i need 8051???
Hi im using an 8051 in a transmitter circuit, the MCU just continuously outputs an 8bit code which is connected to an rf transmitter. My question is do i need an 8051 for such a simple task? I am only thinking about an 8051 because i have used it before but is there a simpler alternative? size of the board is a factor. smaller the better as a person will have to carry around the board.
05438560 is offline   Reply With Quote
Old 1st May 2008, 01:24 PM   (permalink)
You need the microcontroller to perform Manchester coding for the RF module. Or else you'll need a pair of encoder and decoder chip.
Superman returns..
bananasiong is offline   Reply With Quote
Old 1st May 2008, 01:31 PM   (permalink)
I think you are outputting this.
(10010100)00000000000000000000000000000(10010100)0 0000
There is an 8 bit serial number then 100mS of “0” then the 8 bit again.
A 40 pin 8051 is too big. There are some very small 8051s. I have used 8051s form SiLabs with 10 pins. NXP has parts with 8 pins.
On a different note MicroChip has parts with only 6 pins. You will have to bit bank to make a serial port.
If size is important then look for parts with internal OSC and internal POR. If you cannot do surface mount then use an 8 pin dip + 1 bypass cap. (no crystal OSC)
ronsimpson is offline   Reply With Quote
Old 2nd May 2008, 12:00 AM   (permalink)
go to futurlec.com and search for Holtek HT12E and Holtek HT12D.
These are an encoder/decoder pair normally found in keyfob remotes.
I used a couple of these units, very easy and they work great!
johnsmith123 is offline   Reply With Quote
hyperterminal communication w/ 8051 spyghost Micro Controllers 8 22nd May 2008 10:54 AM
8051 Microcontroller (Urgent Help) UAE_Engineer Micro Controllers 5 22nd March 2007 11:13 AM
Could I get away with this? (8051 + AM29F010B) mstechca Micro Controllers 0 9th March 2006 02:04 AM
interfacing 16*16 matrix display with 8051 pmphilip Micro Controllers 0 1st February 2005 03:47 AM
8051 "data" storage within program memory - how? L0D|Mr_B Micro Controllers 1 11th January 2004 02:56 PM
