The code below is a simple one to turn the LED on for 1 second and then off for 1 second. External crystal of 10MHz is used and the PLL is turned on which brings the FOSC up to 40MHz. However when I program and run the code, The LED appears to stay ON for only 1/4 of a second.
Am I missing something..? Thanks. Code:
#include <p18F4620.h>
#include <delays.h>
#include <stdio.h>
#pragma config WDT = OFF
#pragma config MCLRE = ON
#pragma config LVP = OFF
#pragma config OSC = HSPLL
#define CLOCK_FREQ (40000000ul) // Hz
void main()
TRISB = 0x00;
while(1)
PORTBbits.RB0 = 1;
Delay10KTCYx(1000);
PORTBbits.RB0 = 0;
Delay10KTCYx(1000);
I don't use C18. Is it because Delay10KTCYx works up to 255 only? I mean Delay10KTCYx(255). Use LAT registers for outputting as good practice, but it's okay here.
Superman returns..
What compiler are you using?
Spency. PIC Micro's - Your mind is the limit PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net |
Yes I got it! From MPLAB C18 Libraries page 143.
void Delay10KTCYx( unsigned char unit );
Superman returns..
Sorry for double post..
Refer to the post below.. Last edited by MrNobody; 29th April 2008 at 07:17 AM. |
Thanks..
In the code below, I have commented the PLL and change the FOSC to 10MHZ. Again, I use 10MHz crystal for the PIC. I have also changed the delay from 1000 to 250 so that it is within 8 bit. Again, the code is to turn the LED ON for 1 second and then OFF for 1 second. However, the problem still remain.. BTW, I am using C18 compiler. I have also attached the hex file and the asm code. Code:
#include <delays.h>
#include <stdio.h>
//#pragma config OSC = HSPLL
#define CLOCK_FREQ (10000000ul) // Hz
void main()
TRISB = 0x00;
while(1)
PORTBbits.RB0 = 1;
Delay10KTCYx(250);
PORTBbits.RB0 = 0;
Delay10KTCYx(250);
1: #include <p18F4620.h>
2: #include <delays.h>
3: #include <stdio.h>
4:
5: #pragma config WDT = OFF
6: #pragma config MCLRE = ON
7: #pragma config LVP = OFF
8: //#pragma config OSC = HSPLL
9: #define CLOCK_FREQ (10000000ul) // Hz
10:
11: void main()
12: {
13: TRISB = 0x00;
00F8 6A93 CLRF 0xf93, ACCESS
14: while(1)
0112 D7F3 BRA 0xfa
15: {
16: PORTBbits.RB0 = 1;
00FA 8081 BSF 0xf81, 0, ACCESS
17: Delay10KTCYx(250);
00FC 0EFA MOVLW 0xfa
00FE 6EE6 MOVWF 0xfe6, ACCESS
0100 EC65 CALL 0xca, 0
0102 F000 NOP
0104 52E5 MOVF 0xfe5, F, ACCESS
18: PORTBbits.RB0 = 0;
0106 9081 BCF 0xf81, 0, ACCESS
19: Delay10KTCYx(250);
0108 0EFA MOVLW 0xfa
010A 6EE6 MOVWF 0xfe6, ACCESS
010C EC65 CALL 0xca, 0
010E F000 NOP
0110 52E5 MOVF 0xfe5, F, ACCESS
20: }
21: }
0114 0012 RETURN 0
I had a problem on the PIC12F629 that the LEDs wouldnt flash. I solved it by putting :
GPIO = 0; // Turn off all pins Code:
PORTB = 0; // Turn off all pins
Simplicity rules Good enought - its perfect ?? 2 Gig of free online backup space Are you a Chemist? |
hi every one i have aproblem of this code , but i dont know what it is i need some one to help me please
void main() { PORTB=0; TRISB=0;//as output TRISD=1;//as input while(1) { if (PORTD.f1=1) PORTB.f7=1 ; else PORTB.f7=0; } } |
Try this Code:
void main()
PORTB=0;
TRISB=0;//as output
TRISD=2;//as input
while(1)
if (PORTD.f1=1)
PORTB.f7=1 ;
else
PORTB.f7=0;
try to use this:
void main()
PORTB=0;
TRISB=0;//as output
TRISD=1;//as input
PORTB=0; // turn off all pins
PORTD=0: // turn off all pins
while(1)
if (PORTD.f1=1){
PORTB.f7=1 ;
else
PORTB.f7=0;
Somehow (and i dont know why yet) you have turn off all ports or set all registers with all 0.
MedoLee: If you are using MikroC you have to set the config parameterse correctly ( that can be hard if its you first time)
Hi MrNobody,
Even the PLL is not enabled, HS oscillator should still be selected, shouldn't it?
Superman returns..
No you have to set everything in the project setup in MikroC compiler
And using
TRISD=2 // just plain stupid if you want to use pins 2 and 4 as inputs and the rest as inputs it would look like this binary 00101000 and hex it would be 0x28 Code:
TRISD= 00101000 // or in hex TRISD=0x28
TRISD=2 If you want to use pin 2 and 4 as inputs, Code:
TRISD = 0b00010100; TRISD = 0x14; TRISD = 20;
Superman returns..
| PIC pin to MOSFET gate problem | Futterama | Electronic Projects Design/Ideas/Reviews | 7 | 8th November 2007 05:30 PM |
| Simple switching/pulse project | dbtoutfit | Electronic Projects Design/Ideas/Reviews | 2 | 1st November 2007 01:46 PM |
| Simple Robot From Scratch Parts? | GreenAce92 | Robotics Chat | 7 | 27th October 2007 11:42 PM |
| Simple? op-amp problem... | jrz126 | Electronic Projects Design/Ideas/Reviews | 2 | 20th September 2007 09:52 PM |
| PIC16F628 ... VERY SIMPLE PROBLEM | micro571 | Micro Controllers | 14 | 30th December 2004 09:51 AM |
