Old 28th April 2008, 10:56 AM   (permalink)
Post there is aproblem
hi every one , i have problem with 16f877a microcontroller , the problem is how to deteminig the input and output ports
i need some helps please
MedoLee is offline   Reply With Quote
Old 28th April 2008, 10:58 AM   (permalink)
Did you downloaded the data sheet?It has all the stuff regarding to that micro controller.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline   Reply With Quote
Old 28th April 2008, 11:09 AM   (permalink)
[quote=MedoLee]hi every one , i have problem with 16f877a microcontroller , the problem is how to deteminig the input and output ports
thak you very much Gayan Soyza but my problem is how can dieal with these input and out out ports
MedoLee
Inputs and outputs port are those that begins with RA, RB, RC, RD and RE which is 33 pins all together.
You set the port input or output by setting the respective TRIS register, eg, TRISA, TRISB, TRISC, TRISD and TRISE. 1 for input and 0 for output..
Download the datasheet if u want to know more..
MrNobody is offline   Reply With Quote
Old 28th April 2008, 11:21 AM   (permalink)
thanx alot
MrNobody but my problem is :
if you choose Port d as input in my programm is definded as
(PORTD.??) dot what
and thax alot again
Old 28th April 2008, 11:24 AM   (permalink)
Originally Posted by MedoLee
thanx alot
(PORTD.??) dot what
and thax alot again
If I understand you correctly, are you asking HOW to configure the PIC ports as either INPUTS or OUTPUTS, when writing the program.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now   Reply With Quote
Old 28th April 2008, 11:37 AM   (permalink)
the problem is how can i dieal with this input port and assign the value of input port
Old 28th April 2008, 11:45 AM   (permalink)
Look at Nigels tutorials, they will explain.
This link:
http://www.winpicprog.co.uk/
Eric
PIC tutorials:
Old 29th April 2008, 06:00 AM   (permalink)
Pulling my hair out in chunks!!
donniedj is offline   Reply With Quote
Old 29th April 2008, 08:48 AM   (permalink)
Hey, why don't you tell us what you are trying to do..? I mean, what you are trying to achieve as in, the end result.. Are you trying to use a switch or something.. Tell us clearly and also include information like which pin you are using, and which pin is connected to what etc, coz we are struggling to understand what u mean..
Old 29th April 2008, 09:13 AM   (permalink)
hi Mr N,
I think the problem is, that English is not his first language.
It must be difficult asking technical questions in a 'foreign' language.
Reading between the lines, I think he is asking how to configure the Port pins as I/O.
Nigels tutorials give examples on how to do just that.
Eric
PIC tutorials:
Old 29th April 2008, 09:20 AM   (permalink)
hi my friend my code is to recieve asignal from PORTD pin 1 (as input)and blinking a led in PORTB pin1 as output
for example
void main()
PORTB=0;
TRISB=0;//as output
TRISD=1;//as input
while(1)
if (PORTD.f1=1)
PORTB.f7=1 ;
else
PORTB.f7=0;
Old 29th April 2008, 11:24 AM   (permalink)
MedoLee:
Refer here, I have already answered ur question there.
Anyway, you wanted to use RD1 as input but you are setting RD0 as input instead.
You wrote:
TRISD = 1 --> TRISD = 0b00000001 --> Port D pin 0 as input but the rest as output
Instead, you should use
TRISD = 2 --> TRISD = 0b00000010 --> Port D pin 1 as input but the rest is output
As what Eric has said, go to Nigel's Tutorials if you want to know more about it.
