Old 18th October 2003, 01:01 AM   (permalink)
Default monotone melody using buzzer
Mabuhay!
I have a PIC system and I am planning to integrate a monotone melody using a buzzer...
Can anyone help me? a code snippet will do....
Thnx
rrb011270 is offline
Old 18th October 2003, 11:33 AM   (permalink)
Default Mabuhay rin sa'yo
If your using a buzzer (like the sonalert ones from Alexan) all you do is apply a voltage across the leads. It already has a built in oscillator/drive circuit.
But if you all you have is a ceramic disk or a speaker and would want to use the PIC to pulsout a ceratin frequency. Here's some codes:
The easiest is to use PICBASIC. (Download it from sonsivri.com.)
All you do is use the FREQOUT command:
__________________________________
FREQOUT portb.1, 500, 528 ' Output to portb pin1, for 500 msec,
' 528hz, which is the note C.
Before, I actually did it in assembly, which is about ten times
more 'econimical' that the PICBASIC equivalent.
; Variable
d3 equ 0X0F ; Variable used to count the number of
; cycles in the duration the sound is
; played.
; d3 = 528 * duration of sound (sec)
; Play sound
MOVLW 0X108 ; Put the value 108h (decimal, 264)
MOVWF d3 ; to d3. A 528hz freq completes 264
; cycles in 500 msec.
Call C1
; C2 Subroutine
C2
BSF PORTB,1 ; High portb pin1.
Call C2_0 ; Call delay subroutine
BCF PORTB,1 ; Low portb pin1.
DECFSZ d3, f ; Decrement d3
goto C2 ; Goto to C2. If d3 is zero
RETURN ; end subroutin
; Delay routine for the on-off sequence
C2_0
MOVLW 0xBD
MOVWF d1
MOVLW 0x01
MOVWF d2
C2_1
DECFSZ d1, f
goto $+2
DECFSZ d2, f
goto C2_1
goto $+1
goto $+1
RETURN
______________________________________
Hope this helps.
trutan is offline
Old 18th October 2003, 02:01 PM   (permalink)
Do you mean it is easier in assembly or picBasic?
I've wanted to learn assembly but was lead to believe it wasn't easier to program in than basic.
\"Basically, I no longer work for anything but the sensation I have while working.\"
- Albert Giacometti
RonDumas is offline
Old 18th October 2003, 02:28 PM   (permalink)
I meant that a program in assembly, while more complicated to do,
typically uses up less program memory--economical.
But programming in PICBASIC is far easier. In fact now I program exclusively in PICBASIC and have cut my programming time a great deal.
I find that trading off some memory 'real estate' is worth the time savings.
/John
(I ckecked: In the examples above, the code in assembly saves 31 words.)
trutan is offline
Old 20th October 2003, 01:52 AM   (permalink)
Anyone have done using ANSI C or any C-Language?
/John
