Old 19th April 2008, 02:51 PM   (permalink)
Experienced Member
ahmedragia21 is an unknown quantity at this point
Default PIC cant blink LEDS
Hi, im using PIC16F877A , and im using the compiler MikroC example Blinking LEDS in portC and it doesnt blink the leds ...
I use a universal programmer , here's a pic of the configurations .. .
all the connections are correct MCLR tied to VCC, VDD to 5V,VSS to GND , i use 11MhZ osc
ahmedragia21 is offline   Reply With Quote
Old 19th April 2008, 03:13 PM   (permalink)
Experienced Member
mister_e is on a distinguished road
Could you attach your code and .HEX files in a .ZIP file format here?
Steve
______________________
info@mister-e.org
www.mister-e.org
mister_e is offline   Reply With Quote
Old 19th April 2008, 03:19 PM   (permalink)
Experienced Member
hex and code
File Type: zip LED_Blinking.zip (747 Bytes, 8 views)
Old 19th April 2008, 03:39 PM   (permalink)
Experienced Member
Your .HEX file work for me, nothing really bad in your code. Double check your hardware and if your universal programmer is set to program the configuration fuses.
Steve
info@mister-e.org
www.mister-e.org
Old 19th April 2008, 03:41 PM   (permalink)
Experienced Member
thanks for the check , but i dont know how my universal programmer works with PICs ... i posted a pic of the configuration , would you check it ?
Old 19th April 2008, 03:53 PM   (permalink)
Experienced Member
I don't know this programmer and they seems to use a weird syntax. What happen if you click on the ReadCFG button?
Doesn't seems he read/updae the config fuses automatically when you load the .HEX in your software... well from what i see on your picture...
Steve
info@mister-e.org
www.mister-e.org
Old 19th April 2008, 04:10 PM   (permalink)
Experienced Member
arhi is just really nicearhi is just really nicearhi is just really nice
Originally Posted by ahmedragia21
hex and code
works like a charm .. I tested it on mikroe easypic board and also programmed using: http://www.oshonsoft.com/picprog.html (simple 13V parallel port programmer )
arhi is online now   Reply With Quote
Old 19th April 2008, 04:18 PM   (permalink)
Experienced Member
i dont know really where's the problem , im really so frustrated now
Old 19th April 2008, 04:20 PM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Your problem appears to be the way your programmer is setup.
Bill
Smart Kits build Smart People
Old 19th April 2008, 04:24 PM   (permalink)
Experienced Member
eng1 is a glorious beacon of lighteng1 is a glorious beacon of lighteng1 is a glorious beacon of lighteng1 is a glorious beacon of light
As pointed out by mister_e, it seems that the software is not configured to handle the config settings properly. Try reading the PIC as suggested; what value do you get?
The config word saved within the hex file is 0x3F7A (read with IC-Prog)
eng1 is offline   Reply With Quote
LEDs to blink with music Musicn00b08 Electronic Projects Design/Ideas/Reviews 3 27th March 2008 01:17 AM
Adding LEDs to ICs (PIC - MAX232) Suggestions? johankj Electronic Projects Design/Ideas/Reviews 2 18th February 2008 01:26 PM
Introduction to High Brightness LEDs and Thermal Management Ocelaris Electronic Projects Design/Ideas/Reviews 3 17th March 2007 05:35 AM
Problems with Dual Brightness (Current) LED Tail Lights? Eagle Schematics! Ocelaris Electronic Projects Design/Ideas/Reviews 12 31st December 2006 06:17 PM
LEDs to blink like lightning mattyfab General Electronics Chat 4 28th December 2005 08:08 PM
