| Experienced Member | hello everyone, I came across this pic prototype board on the mikroe website. the link is as follows. http://www.mikroe.com/en/tools/pic-ready/ i just want to know what is the speed of the crystal connected to it. I can see the crystal in the lower middle of the board but I can't figure out what speed crystal it is. Tried zooming in using a picture viewer. but it just got blurry. And what are the small holes that are located on the lower left of the board for. They are in a 15 X 12 arrangement. That is 15 holes down and 12 holes wide. I intend to use the 16f877a pic with it, if I eventually buy it. Or is there any other better prototyping board i can buy Thank you
__________________ A scientist trys to see the world the way it is An enginneer trys to see a world that has never been Last edited by desijays; 19th April 2008 at 06:55 AM. |
| Experienced Member | Quote:
__________________ ========================= Futz's Microcontrollers & Robotics ========================= | |
| | (permalink) | ||
Get a Microchip PICkit 2 or a good clone like the Blueroom Junebug (which has a nice 18F1320 experimenter onboard) and some solderless breadboards and chips and components. MUCH more flexible and re-useable and better for learning.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= | ||
| Experienced Member | The thing is, I want a board where I can easily access the five ports of the pic16f77a. And that board must only have the crystal(preferrably 20MHz) and power supply circuitry so I can provide the power. I don't want something with LED's, LCD displays and all the other paraphrenalia. Easy access to the five ports is most important. I would like it to be small as well cos I intend to use it on a simple mobile robot. I already have a programmer. So i will be programming the 16f877a on that and will be prototyping it on the 'yet to buy' prototype board. Does the PICkit™ 2 have easy access to the 5 ports? There is a picture on the website but its too small to make any sense of it. I don't live in europe by the way.
__________________ A scientist trys to see the world the way it is An enginneer trys to see a world that has never been |
Mike. | |
| | (permalink) | |||
Or a Nightfire proto board. Quote:
Just out of curiosity, why does it have to be the 16F877A, exactly? Not that there's anything wrong with that.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 19th April 2008 at 07:42 AM. | |||
| Experienced Member | Actually I have a ICSP on my development board. The problem is the only port available for the user is portb and porta but i need access to portc for pwm functionality. All the other ports are connected to LED's, LCD, 4*4 keyad, pots, rtc, USB controller and the lot. So I can't use port c, port e or port d. Thats why I need a board that has the bare minimum so the controller can work and easy access to all the ports. And my development board doesn't have a ZIF socket. It is so tight on my development board I have to use a screw driver as a wrench to remove it, if I want to use it outside the development board. And like you said, it is hard to do that everytime and bad for the controller too. The 16f877a is the only one I have right now with me. And if I go ahead and buy another one it will take 2 weeks atleast to get here.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 19th April 2008 at 08:29 AM. | |
| Experienced Member | Thank you futz. I'll check that out.
| Experienced Member | Here's a pic of my PICProto board. The LED display section is incomplete. I put a MAX232 onboard for RS232, but the chip is wide open aside from that. picproto_800x600.jpgpicproto001_800x600.jpg That double-row header can be connected to a breadboard with a short 40-pin IDE cable. At the breadboard end you use a Technological Arts adapter. ![]()
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 19th April 2008 at 08:13 AM. |
| Problem with LCD code? | spondootre | Micro Controllers | 15 | 29th April 2008 09:15 AM |
| PIC PWM outputs? | Andy1845c | Micro Controllers | 33 | 30th November 2007 03:06 AM |
| Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) | smilen | Micro Controllers | 15 | 21st November 2005 09:23 AM |
| Help me on basketball's game clock and shot clock! | syaw_007 | Electronic Projects Design/Ideas/Reviews | 1 | 6th September 2004 09:50 PM |
| Need A Simple Alarm Clock Circuit | Handiplus | Electronic Projects Design/Ideas/Reviews | 0 | 29th March 2004 02:01 PM |
