| Experienced Member | ive got several different 16f in farly large number i believe, i bought up a bunch when i was just getting started. ill pull out the box when i get home and take a look. I really want to settel on using 2 chips the 18f4550 and 18f2550, i like the number of pins, program space, and the usb cababilites. |
| Experienced Member | well for programmer, like I said a lot of people recommend Bill's stuff I don't personally have one of his programmers, but out of the ones I have I love my mikroelektronika easypic4 (www.mikroe.com), it's a development board so it's a bit pricier, but it provides a huge bang for the buck. I got started using kit 150 from kitsrus and never had any problems with it, used it for ICSP until I got my ICD2 from microchip. I'm happy with all of them, initially I started with a JDM programmer, but after screwing around with it for like 2 weeks and not getting a single PIC programmed, I tossed it and went with the kit 150. |
| Experienced Member | Quote:
These days I program PICs with a Blueroom Electronics Junebug, a Microchip PICkit 2 and a Blueroom Inchworm+/Unicorn The Junebug & PICkit 2 get used the most. If you're looking for an excellent, inexpensive PIC programmer that does everything, get one of those two. Pros/Cons: Con 1. Junebug won't program 3.3V PICs without modification. (Not that big of a problem) Pro 1. Junebug has an 18F1320 experimenter onboard with the PICkit 2 clone programmer part. Con 2. PICkit 2 has a programming cable connector that I'm not thrilled with. But it's useable.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 16th April 2008 at 11:46 PM. | |
| Experienced Member | so what would be the best recommendation for programming the 18f2550, and the 18f4550. and programming in basic thanks |
__________________ ========================= Futz's Microcontrollers & Robotics ========================= | |
| Experienced Member | With the ICSP programmers, do you have to supply power to the chip in the circuit? or could i just connect an icsp connector to a zif socket addressing the 5 pins for programming and program it like that and then move if over to the target circuit, or, does it have to be in the target circuit with the minimam basic circuit attached to it to program it ? (crystal, pull resistor, ect.. ) thanks Last edited by joshua17ss2; 17th April 2008 at 02:32 PM. |
Why on earth would you want a ZIF socket? Occasionally they're useful (if you need to program a batch of chips with the same program or something), but the beauty of ICSP is that you don't have to use that nasty thing. Don't forget that when you're writing programs and trying things you're going to be reprogramming the chip hundreds or even thousands of times. You definitely don't want to be prying that chip in and out of the circuit every time. Wears out the pins and they break off. It's tedious (I've done it) and very slow. For everyday use just put the chip in the target circuit and put a ICSP connector onboard. When you make a change to the program, a few keypresses or clicks and the chip is reprogrammed, ready for test. Easy and quick that way. Have a look at a few of the breadboard setups and schematics on my site to see how the connector is wired.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 17th April 2008 at 02:59 PM. | |
| Experienced Member | What i meant was, with the serial programmers i know that they needed the 14 volts from the serial port to pull the programming pin and change the status of the pic so that it can be programmed, i know that with usb the max youll pull is 5, so you have the 5 pins going to the micrcochip, from a usb programmer like http://cgi.ebay.com/PIC-kit-2-COMPAT...QQcmdZViewItem this one, wouldnt i need to supply the 14 volts to the chip in my circuit to program it, or would it just be the usb cable to the programmer and the programmer to the chip. thanks |
| Experienced Member | so i think i will order this programmer: http://cgi.ebay.com/Clone-Microchip-...QQcmdZViewItem it should support what i need, any suggestions, or warnings agianst the pic kit 2? josh |
If it turns out it's no good you're not out too much $$ anyway.
| Experienced Member | Thats what i was thinking to, and it come with 2 different cable for programming, i do love my options. i saw that it was a clone that dosent bother me both my lcd tvs are copies of major brands and they just keep plucking along just fine. ive orderer from the guy before as well the stuff is nice and well packaged. I am gonna try and list some of the pics i have for sale, the 16f and a few of the 18s. any suggestions for listing them on ebay ? |
| Errors while programming a PIC16F874A | Kitt0s | Micro Controllers | 17 | 8th March 2008 07:12 PM |
| Question about Inchworm+ | Quan | Micro Controllers | 54 | 28th October 2007 12:20 AM |
| UNIT Committment solution using Dynamic programming | arijit18 | Electronic Projects | 1 | 18th October 2007 08:27 PM |
| Programming languages | sram | General Electronics Chat | 9 | 2nd March 2007 04:14 PM |
| Good Computer Programming Book | ThermalRunaway | Chit-Chat | 21 | 16th September 2005 10:05 PM |
