Hi all,
Got my I2C routines to work with a DS1307 and a 18F2550. The next step I suppose is to have a tinker with SPI, I do have some RTC's coming from MAXIM so I shall have something to play with in the next couple of days. I am very interested in data logging projects that are out there and I have read that SD cards can be read via SPI. Great! however with the reading I have done so far, I have 2 questions 1. Where is the "official" documentation on interfacing with a SD via SPI? 2. I have read that FAT16 is copyrighted, if I was to develop and sell a product which incorporated the FAT structure - would I have to pay "Bill"? Thanks Mark |
(permalink) | ||||
18F4620_sdcard002sm.jpg That's a 18F4620 with a Futurlec SD/MMC Mini Board and a Logic Converter Mini Board. SD's are 3.3V. You can use voltage dividers, but I had one of these boards so... Quote:
This is a GOOD one, and hard to find: sdcard_appnote_foust.pdf This is the useful part of the MAXIM info in open document format: sdcard_info.zip Toshiba SD Card Spec: TOSHIBA_SD_Card_Specification.pdf Some links: http://www.k9spud.com/sdcard/ http://www.kronosrobotics.com/Projects/MMC.shtml http://uanr.com/sdfloppy/ http://www.roland-riegel.de/sd-reader/index.html http://pinouts.ru/Memory/sdcard_pinout.shtml http://www.technick.net/public/code/...onmem_sdcard_9 http://www.maxim-ic.com/appnotes.cfm/an_pk/3969 http://www.captain.at/electronics/pic-mmc/ http://www.mcu.fluxfocus.com/documents/SDSPI/sdspi.htm http://www.maxim-ic.com/appnotes.cfm...te_number/4068
========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 16th April 2008 at 05:06 AM. |
Since you have both a PICkit2 & a Junebug use one for the Logic Analyzer and watch the SPI or I2C bus.
I've got to try that myself |
========================= Futz's Microcontrollers & Robotics ========================= |
Post your results, you'll need to convert the BMP to PNG or GIF.
Have you considered using a micro with built in RTCC? The 24F series has an RTCC and supports USB called the 24FJ256GB faimily. 24F is relatively new and the USB versions are brand new. Few are aware of them.
Cracked? Did you implement your own software I2C? Its not cracked until you do this, otherwise it is only bruised. |
The C18 compiler has software/BitBang support for I2C in library sw_I2C.h.
I used it to to read back sound files programmed into the EEPROMs with a Junebug. The tools are getting nice. Futz, FWIW...I see your Junebug is not mounted. In the early days of electronics people used to mount projects on wood blocks. I still like that method, cut a block to the size of the board and use standoffs to mount the board. It makes it easier to work with, slides around less.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 16th April 2008 at 05:10 AM. |
I've got to find a supplier of the BT-04 case, dipmicro sells em with a PCB for $6.40 The Junebug PCBs need about 0.5mm sanded off the bottom to fit perfectly. Now where to get the super tiny screws...
http://www.dipmicro.com/store/index....&productId=596 ![]() |
(permalink) | ||
========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 16th April 2008 at 02:41 PM. |
Cheers Futz, some great info there.
I don't know if you recommend this, but I would like to be able to build the modules you describe from scratch (SD and Logic Converter boards), I would still categorise myself as a newbie so think this may be useful, what do you think? I think when I manage to fathom access to the SD via SPI I will start to look at some FAT routines, I might try doing it in ASM (yes I must like pain). Quote:
Software I2C? I did it using the MSSP module of the 18F2550, is doing it in software tough? Thanks again Mark |
(permalink) | ||
If you want schematics just ask. The 5V to 3.3V chip is a LCX245. That board also has a 3.3V regulator on it. The SD socket board has jumpered pullups for the SD lines, a couple LEDs, a cap and the socket. Quote:
Why don't you simply use the microchips app note for FAT16 and FAT32. I used it and it worked on the first try!
| SPI->I2C Converter | dknguyen | Datasheet/Parts Requests | 16 | 12th March 2008 01:45 AM |
| Winbond SP03 i2c bitbang | MikeC | Micro Controllers | 0 | 22nd February 2008 05:08 PM |
| SPI Testing with ENC28J60 | mikesmixes777 | Micro Controllers | 9 | 17th January 2008 07:41 AM |
| Both parallel and spi in PIC microcontroller PLEASE HELP | jitun2 | Micro Controllers | 12 | 24th October 2007 02:08 PM |
| Need help! I2c data bus with pic 16f84a | rukshankb | Micro Controllers | 2 | 7th October 2007 11:57 AM |
