Old 15th April 2008, 08:37 PM   (permalink)
Experienced Member
UTMonkey is a jewel in the roughUTMonkey is a jewel in the rough
Default I2C Cracked - next SPI....
Hi all,
Got my I2C routines to work with a DS1307 and a 18F2550.
The next step I suppose is to have a tinker with SPI, I do have some RTC's coming from MAXIM so I shall have something to play with in the next couple of days.
I am very interested in data logging projects that are out there and I have read that SD cards can be read via SPI.
Great! however with the reading I have done so far, I have 2 questions
1. Where is the "official" documentation on interfacing with a SD via SPI?
2. I have read that FAT16 is copyrighted, if I was to develop and sell a product which incorporated the FAT structure - would I have to pay "Bill"?
Mark
UTMonkey is offline   Reply With Quote
Old 15th April 2008, 08:48 PM   (permalink)
Experienced Member
eng1 is a glorious beacon of lighteng1 is a glorious beacon of lighteng1 is a glorious beacon of lighteng1 is a glorious beacon of light
Check out Microchip Application Note 1045.
Link added
eng1 is offline   Reply With Quote
Old 16th April 2008, 12:14 AM   (permalink)
Experienced Member
futz is a name known to allfutz is a name known to allfutz is a name known to allfutz is a name known to allfutz is a name known to allfutz is a name known to all
I don't think I've ever (successfully) done I2C, but I have done SPI.
SPI is super easy. Nothin to it.
I'm working on exactly that right now. I have it all wired up and am just trying to puzzle out how to do the software. It's tougher than I expected, but I'll get it.
That's a 18F4620 with a Futurlec SD/MMC Mini Board and a Logic Converter Mini Board. SD's are 3.3V. You can use voltage dividers, but I had one of these boards so...
Unknown. But I have some useful stuff for you:
This is a GOOD one, and hard to find: sdcard_appnote_foust.pdf
This is the useful part of the MAXIM info in open document format: sdcard_info.zip
Toshiba SD Card Spec: TOSHIBA_SD_Card_Specification.pdf
Some links:
http://www.k9spud.com/sdcard/
http://www.kronosrobotics.com/Projects/MMC.shtml
http://uanr.com/sdfloppy/
http://www.roland-riegel.de/sd-reader/index.html
http://pinouts.ru/Memory/sdcard_pinout.shtml
http://www.technick.net/public/code/...onmem_sdcard_9
http://www.maxim-ic.com/appnotes.cfm/an_pk/3969
http://www.captain.at/electronics/pic-mmc/
http://www.mcu.fluxfocus.com/documents/SDSPI/sdspi.htm
http://www.maxim-ic.com/appnotes.cfm...te_number/4068
futz is online now   Reply With Quote
Old 16th April 2008, 12:36 AM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Since you have both a PICkit2 & a Junebug use one for the Logic Analyzer and watch the SPI or I2C bus.
I've got to try that myself
Bill
Smart Kits build Smart People
blueroomelectronics is online now   Reply With Quote
Old 16th April 2008, 12:37 AM   (permalink)
Experienced Member
Ya! I'm gonna do that!
Old 16th April 2008, 12:47 AM   (permalink)
Experienced Member
Post your results, you'll need to convert the BMP to PNG or GIF.
Bill
Old 16th April 2008, 12:53 AM   (permalink)
Experienced Member
donniedj has a spectacular aura about
Have you considered using a micro with built in RTCC? The 24F series has an RTCC and supports USB called the 24FJ256GB faimily. 24F is relatively new and the USB versions are brand new. Few are aware of them.
Cracked? Did you implement your own software I2C? Its not cracked until you do this, otherwise it is only bruised.
I can still log in! Delete my account and all my post now.
donniedj is offline   Reply With Quote
Old 16th April 2008, 05:05 AM   (permalink)
3v0
Moderator
3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold3v0 is a splendid one to behold
The C18 compiler has software/BitBang support for I2C in library sw_I2C.h.
I used it to to read back sound files programmed into the EEPROMs with a Junebug. The tools are getting nice.
Futz, FWIW...I see your Junebug is not mounted. In the early days of electronics people used to mount projects on wood blocks. I still like that method, cut a block to the size of the board and use standoffs to mount the board. It makes it easier to work with, slides around less.
search engine for electronic parts
Junebug USB PIC programmer kit. USB Bit Wacker
3v0 is online now   Reply With Quote
Old 16th April 2008, 01:05 PM   (permalink)
Experienced Member
I've got to find a supplier of the BT-04 case, dipmicro sells em with a PCB for $6.40 The Junebug PCBs need about 0.5mm sanded off the bottom to fit perfectly. Now where to get the super tiny screws...
http://www.dipmicro.com/store/index....&productId=596
Bill
Old 16th April 2008, 02:28 PM   (permalink)
Experienced Member
It's on little rubber (polyurethane) "feet". Five of them, four at the corners and one under the buttons. Doesn't slide all that much.
I have one of those. Bought it from DipMicro with the PCB for $6.40. The screws come with it. I dithered about installing Junebug in it for a while. Decided not to for now.
Old 16th April 2008, 08:40 PM   (permalink)
Experienced Member
Cheers Futz, some great info there.
I don't know if you recommend this, but I would like to be able to build the modules you describe from scratch (SD and Logic Converter boards), I would still categorise myself as a newbie so think this may be useful, what do you think?
I think when I manage to fathom access to the SD via SPI I will start to look at some FAT routines, I might try doing it in ASM (yes I must like pain).
- DonnieDJ
Software I2C? I did it using the MSSP module of the 18F2550, is doing it in software tough?
Thanks again
Mark
Old 17th April 2008, 02:04 AM   (permalink)
Experienced Member
Certainly. There's nothing complex about these boards. They're just time savers, and if you count the time it took me to make all the connectors, more like time sinks.
If you want schematics just ask. The 5V to 3.3V chip is a LCX245. That board also has a 3.3V regulator on it. The SD socket board has jumpered pullups for the SD lines, a couple LEDs, a cap and the socket.
Ya, I plan to do it raw first too, and then worry about the filesystem. Asm isn't painful! It's nice! But I'm a C guy these days.
Old 26th June 2008, 06:15 PM   (permalink)
Experienced Member
Someone Electro is on a distinguished road
Send a message via AIM to Someone Electro Send a message via MSN to Someone Electro Send a message via Yahoo to Someone Electro
Why don't you simply use the microchips app note for FAT16 and FAT32. I used it and it worked on the first try!
Il give you shocking experience.
Someone Electro is offline   Reply With Quote
SPI->I2C Converter dknguyen Datasheet/Parts Requests 16 12th March 2008 01:45 AM
Winbond SP03 i2c bitbang MikeC Micro Controllers 0 22nd February 2008 05:08 PM
SPI Testing with ENC28J60 mikesmixes777 Micro Controllers 9 17th January 2008 07:41 AM
Both parallel and spi in PIC microcontroller PLEASE HELP jitun2 Micro Controllers 12 24th October 2007 02:08 PM
Need help! I2c data bus with pic 16f84a rukshankb Micro Controllers 2 7th October 2007 11:57 AM
