Old 16th April 2008, 03:33 AM   #16
You might accuse me of being a purist - but to reduce errors i'd suggest you let the compiler keep track of miniscule stuff like the size of an array - so instead of:
#define TABLE_SIZE 100
const rom unsigned char roots[TABLE_SIZE] =
{ 0, 1, 1, 1, 2, 2, 2, 2, 2, 3,
3, 3, 3, 3, 3, 3, 4, 4, 4, 4,
4, 4, 4, 4, 4, 5, 5, 5, 5, 5,
5, 5, 5, 5, 5, 5, 6, 6, 6, 6,
6, 6, 6, 6, 6, 6, 6, 6, 6, 7,
7, 7, 7, 7, 7, 7, 7, 7, 7, 7,
7, 7, 7, 7, 8, 8, 8, 8, 8, 8,
8, 8, 8, 8, 8, 8, 8, 8, 8, 8,
8, 9, 9, 9, 9, 9, 9, 9, 9, 9,
9, 9, 9, 9, 9, 9, 9, 9, 9, 9 };
const rom unsigned char roots[] =
#define TABLE_SIZE  sizeof(roots)
sizeof() always returns the size in bytes - so if it's an array of bytes you are good to go.
if it was an array of integers (16 bit value in the case of a PIC i think?) you would say:
#define TABLE_SIZE  sizeof(roots)/sizeof(int)
Just one less Constant you have to manually update is all - in the case of your example it comes back with the correct answer either way.
David / W9GF is offline
Old 16th April 2008, 04:04 AM   #17
Oops! I didn't realize we were talking about two different C compilers either.
Thank you for all the clarifications guys. I'm going to try and change the RAM array to a constant ROM array in that old DayOfWeek() routine...
Mike, K8LH is offline
c18, data, define, table
usart with pic neelam29 Micro Controllers 19 18th July 2009 09:39 AM
Motor controller Totally blank Electronic Projects Design/Ideas/Reviews 9 16th January 2008 02:12 PM
18F4550 - PORTD inputs are shaky, even with internal pull up enabled toodles Micro Controllers 0 29th April 2007 03:05 AM
help me to describe this code indie Micro Controllers 0 18th June 2004 02:11 PM
An error in pic16f84a, why? Zener_Diode Micro Controllers 6 11th April 2004 03:55 AM
