The first time I seen the ICSP cables with PGC and PGD adjacent to each other I suspected it was not a good idea. As the technology is applied to ever faster chips crosstalk has got to be a limiting factor. If anyone is designing a PIC programmer I suggest changing VPP, VDD, GND. PGC, PGD to VPP, PGC, GND, VDD, PGD This should eliminate crosstalk. There is a short discussion on the subject at http://www.embedinc.com/picprg/icsp.htm Under the section header PGC to PGD Crosstalk. You can toss rotten fruit at me if you like...
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
To me VPP, Vdd, PGC, Gnd, PGD Could be a better option, keeping programming pins away of "higher voltage" signals.
__________________ Steve | |
| | #3 | |
I know a 5 pin ICSP can be inserted backward with a ICD2 or PICkit2 without damag. Switching VDD and PGC preserves this. Reversing your cable will switch VDD and GND and I think that would be a problem.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | ||
The reason most use VPP,+5,GND,PGD,PGC is it's the order Microchip uses on their programmers. Short cables keep the problem to a minimum. Microchips Real ICE suggests a differential cable at clocks above 40MHz. | |
The rate of flash memory burning is the only true problem. When flash burn is not the bottle neck, the very programming device is capable of pushing a clock above 40MHZ is not the bottle neck, then I will be concerned. Since a 60 inch cable has not ever caused a programming failure, any talk of crosstalk is snake oil in my ears. Off to the bath house I go. | |
| | #6 |
What programmer are you using?
| | #7 | |
At would be nice to use a longer ICSP cable. It could possibly fix that occasional programming error. Like I said. Feel free to throw fruit. I know I am going against the grain.
| | #8 |
When I designed the Inchworm I sweated over the pinout and connector.
| | #9 | |
One could quite possibly get the same benefit by using a cable that switched the signals at each end. With some care one could cut the 3-4 and 7-8 pairs loose and swap them at the IDC connectors. I will make up an 18 inch cable and give it a try. If it works it is the best of both worlds. Quote:
Still I think Microchips decision to put PGC and PGC next to each other is a poor one. IFF switching the two signals allows the use of longer cables and more reliability that would be a good thing. The down side is that to connect to other peoples targets you would have to use an adaptor with crossed wires.
| | #10 |
I have built a 35 inch twisted ICSP cable. It seems to be working. The construction is easier then I first indicated. All you do is cut the outside two wires loose and move each pair to the other side of the cable. Both ends. Rip the wires down far enough such that you can lay them flat under the strain relief. I know a few downloads and verifies are not enough to declare success. I will let you know in a week if it works well or sooner if not. The other thing that needs to be pointed out is that I did not make a 35 inch standard cable to compare it against. Given that the Microchp instructions suggest a cable under 6 inches that does not sound like a good idea. Try it if you like. The picture is large to show the cable ends. conductors 9 10 3 4 5 6 7 8 1 2 1 2 3 4 5 6 7 8 9 10 ... 1 2 3 4 5 6 7 8 9 10 9 10 3 4 5 6 7 8 1 2
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 13th April 2008 at 05:41 AM. | |
| | #11 |
3v0, Your image isn't showing and the IP address is 192.168.... which is a local address. Mike. | |
| | #12 | |
Fixed it.
| | #13 |
Though difficult, let us try shielded wire for either PGC or PGD (one of them would do)wires with shield grounded at one end. this would help I feel.
| | #14 |
I recall seeing sheilded ribbon cable, and twisted pair ribbon cable (not sure twisted pair would make any difference on this though)
| | #15 |
we cant go on changing the standards while we can shield one wire by a bypass cable and still maintain the order. screened interconnect cable patches are not uncommon in RF circuitry, i remember. entire ribbon is embedded in shield. it wont help. At times a 22E resistor in series to clock wire and a 22-47pf cap to ground close to load side,reduces the crosstalk
__________________ Regards, Sarma. Last edited by mvs sarma; 13th April 2008 at 04:51 PM. | |
| crosstalk, pgc, pgd |
| CD4051 analog multiplexer crosstalk | Mojalco | Electronic Projects Design/Ideas/Reviews | 3 | 20th March 2009 09:00 AM |
| Using the PGD and PGC pins | UTMonkey | Micro Controllers | 9 | 15th April 2008 08:22 PM |
| I can't find the PGD and PGC pins on the 16F887... | Krumlink | Datasheet/Parts Requests | 9 | 30th September 2007 07:44 PM |
