Old 12th April 2008, 08:20 AM   (permalink)
Experienced Member
Anurag_Singh can only hope to improve
Originally Posted by ericgibbs
Is it possible to try your programmers on a different PC.?
I have tried using it on a latest PC...but same result.
By the way, my PC is an older one Intel Celeron processor 531MHz
Anurag_Singh is offline   Reply With Quote
Old 12th April 2008, 08:22 AM   (permalink)
Experienced Member
Also what is the PC's operating program/system. eg: Win XP Win98se etc.?
I tried it on different pC ..but same result.
The OS is WinXP
Old 12th April 2008, 08:29 AM   (permalink)
Experienced Member
ericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to behold
The OS is WinXP
I expect you have checked the 9W serial and 25W parallel port connectors you have wired up.?
A common mistake is to count the 9/25W pins from the wrong end of the connector.?
Have you any voltage measurements from the PIC16PRO that you could post.?
I have just downloaded from Nigels site the PIC16PRO zip, I'll look over it and try to suggest some ideas.
Have you been able to check/test the parallel port without the programmer plugged in. Can you read and write from it with a test program.?
Eric
"Good enough is Perfect"
PIC tutorials:
Nigel's: www.winpicprog.co.uk/
Gramo's: www.digital-diy.net/
Old 12th April 2008, 08:36 AM   (permalink)
Experienced Member
Another question.
Have you manufactured a pcb for the PIC16PRO using the artwork in the zip or have you hand wired a pcb.?
Any photographs you can post.?
Eric
PIC tutorials:
Old 12th April 2008, 09:17 AM   (permalink)
Experienced Member
I have handwired P16PRO40 ...but it is not with me...it is with one of my friend.
Now I am trying to program using JDM programmer made by me as well as that I bought from
http://triindia.co.in/shop/product_i...products_id=93
Old 12th April 2008, 09:35 AM   (permalink)
Experienced Member
OK
Your link is broken.
EDIT:
Looking for the JDM, I found this modification.
http://users.tpg.com.au/btkelly/jdm_b.htm
Also this:
I believe that the "JDM Programmer" is cheap and very useful PIC Programmer. However, since "JDM Programmer" cannot control VDD, the algorithm "VPP before VDD" is inapplicable. Programming to the latest device from this reason may go wrong when using CONFIG settings as "Internal oscillator" "MCLR OFF". These devices are given power from the "JDM programmer",and execute program code. An error may come out by verification, or it may become impossible erasure and become impossible re-programming . In order to solve this problem, I designed a programmer based on the "JDM programmer." Since this programmer was made of resistors, capacitors, and diodes, I named this the "RCD Programmer." "Hardware settings" of IC-Prog are the same as the "JDM programmer."
As I dont use the JDM, I cannot comment.?
Eric
PIC tutorials:
Old 12th April 2008, 10:24 AM   (permalink)
Experienced Member
mvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to all
Send a message via MSN to mvs sarma Send a message via Yahoo to mvs sarma
Instead of JDM B, which might work, I would rather suggest externally powered DL4YHF version whose schematic and a possible artwork as developed by me in the attached Zip file. Thanks to DL4YHF for the design. As Pommie rightly pointed out this version , perhaps, supports Vpp before Vdd. the power supply is designed accordingly. Also thanks to PCB123 software which helped me sketch this design for my hobby.
Regards,
Sarma.
mvs sarma is offline   Reply With Quote
Old 12th April 2008, 12:58 PM   (permalink)
Experienced Member
OY2L is on a distinguished road
Hi Anurag,
You can try P16PRO40 and Nigel's WinpicProg. Try now select option/hardware/Programmer type and p16pro40-7406 or 7407 (this depends on wich chip you have in your programmer), if you have a 7405 then select 7406 on the dropdown list. Now try to toggle the buttons the red LED's should ligth up when you toggle VPP and VPP40 and the input should follow when you toggle the output button high/low. This will tell you if your LPT port works ok, and if the voltage on VPP and VPP40 is about 12volt or more when you toggle them your programmer also works ok.
OY2L is online now   Reply With Quote
Old 19th April 2008, 04:25 AM   (permalink)
Experienced Member
Smile Thanks Everyone!!
I got my pic programmed...
I used the circuit given on site: http://feng3.cool.ne.jp/en/rcd.html
I just removed the connections of zener diode for providing 13V...instead i used an external 13V supply and it worked well...
Thanks to oyl(leif), mvs_sarma, nigel and all others who helped me.
BTW, the tutorials provided by Nigel are brilliant for a new pic programmer.
HATS OFF TO HIM..
plz help s29 Electronic Projects Design/Ideas/Reviews 12 7th February 2008 07:40 PM
Pan and Tilt Platform with Memory! PLZ help:) Cynergy Micro Controllers 3 31st October 2007 09:13 PM
small help plz HKS Electronic Projects Design/Ideas/Reviews 1 16th October 2007 04:56 PM
plz help me with xenon strobe flashers. swapitude Electronic Projects Design/Ideas/Reviews 5 29th September 2007 04:31 PM
Hey m Fial yr B.tech student can anybody plz suggest me any project for my final yr vivekagarwal141 Micro Controllers 8 27th September 2007 05:09 AM
