| | #1 (permalink) |
| New Member Join Date: Apr 2008 Location: US
| Hello all, I in a senior design class and I am trying to program a PIC16F877A to be used as a weather analyzer. It needs to take input from a temp sensor lm35, a humidity sensor, a wind speed sensor, and out put temperature, heat index and wind chill. i have a program for a2d conversion, and I have some experience, but I am getting overwhelmed with how much i have to do, so i was wondering if anyone could help me out with some code. To output the wind chill or heat index i need to do some math, I don't know how to program equations. I have the temp and humidty both going into PORTA and I don't even know if I can do that. The wind speed is a digital input and that is going into portC. PLEASE HELP Elizabeth |
| | #2 (permalink) |
| Experienced Member Join Date: Oct 2003 Location: Buenos Aires - Argentina
| What have you tried, so far? At least a flow diagram of the main sequence?
__________________ Agustín Tomás In theory, there is no difference between theory and practice. In practice, however, there is. |
| | #3 (permalink) |
| Experienced Member | Check out kitsrus.com, they have a kit "kit75" which is a PIC trainer which has humidity and temp sensor with assembly code. I posted a fix for their code on their website a few years back but they still haven't applied it to their code, anyhow here it is, it might help: The kit: http://www.kitsrus.com/pdf/k75.pdf The code: http://www.kitsrus.com/zip/k75.zip Revised code of some sort: http://www.kitsrus.com/zip/k75_c711.zip |
| | #5 (permalink) |
| Ok , I don't know if this is what you guys are looking for but here it goes. Input all the time from the temp from port A Display the temp all the time take input from the humidity sensor through port A Heat index will be calculated for temps above 27 C/ 80 F with relative humidity > 40 % Take input from windspeed sensor Wind Chill will be calculated for temps below 4 C and 40 F with wind speeds > 5 mph one of these will be displayed when one push of a push button switch There are equations that will calculate these. I have the a2d program in ASM and the input of a switch, but these are two seperate programs, and need to be put together with equations. Here are the two programs I have that work on it, but now i need to put them together. I could also program in C but it has been awhile since I have worked with it. I hope you guys understand what i am trying to do. A2D ; This code will light a LED on portC pin RC2/CCP1 and ;display the 8 bit hex value on portB LEDs or bargraph. The CCP1 LED ;will glow from bright to dim as the pot varies the pulse width. ;Connect an O-scope to CCP1 and watch the PW vary. This code can be ;used on other PICs but you will have to change the code to fit it's ;instruction set. One wire on pot goes to +Vdd and the other end ;of the pot goes to -Vss/ground. The wiper goes to RA0 input pin. ;You can use any input signal source as long as you don't exceed the ;chips max specs. for example, a slow sine or ramp wave(1-5Hz) will ;flash the CCP1 LED. Make sure you use a common ground for the ;signal generator and PIC board. #include <p16F877a.inc> LIST p=16F877a errorlevel 1,-302 ;to disable MPLAB bank warnings. __config _XT_OSC & _PWRTE_ON & _WDT_OFF &_LVP_OFF ; ;Some versions of MPLAB use _LVP_OFF ;This sets all portB pins to output. ;/*---------Declare Registers STATUS EQU 03 ADCON EQU 08 PORTB EQU 06 F EQU 1 W EQU 0 ;/*---------Set up chip parameters CLRF CCP1CON ;CCP MODULE IS OFF CLRF TMR2 ;CLEAR TIMER2 MOVLW 0X7F ; MOVWF PR3 CALL A2D CLRF INTCON ;DISABLE INTRPTS ANDCLEAR T0IF BSF STATUS,RP0 BCF TRISC,2 ;MAKE PIN 2 PWM OUTPUT CLRF PIE1 ;DISABLE PERIPHERAL INTS BCF STATUS,RP0 CLRF PIR1 ;CLR PER INT FLAGS MOVLW 0X2C ;PWM MODE, 2LSBs OF DUTY CYCLE=10 MOVWF CCP1CON BSF T2CON,TMR2ON ;TIME2 STRTS TO INCREMENT ; ;CCP1 INT IS DISABLED ;DO POLLING ON THE TMR2 INT FLAG bit ; PWM_PERIOD_MATCH BTFSS PIR1,TMR2IF GOTO PWM_PERIOD_MATCH ; ;UPDATE THIS PWM PERIOD AND THE FOLLOWING PWM DUTY CYCLE ; BCF PIR1,TMR2IF A2D bsf STATUS,RP0 MOVLW B'00000001' MOVWF TRISA ;All outputs except RA0. CLRF TRISB ;RA0 is wiper of 50k pot/Vin CLRF TRISC ;PortB is 8 LED output to show MOVLW B'00001110' ;Hex value of Vin from pot. MOVWF ADCON1 ;left justified, RA0 = input ;/*-----Set up A2D parameters MOVLW B'11010111' ;prescaler 1:256 tmr0, internal clock MOVWF OPTION_REG BCF STATUS,RP0 MOVLW B'01000001' ;a2d = on, ch0, fosc/8 MOVWF ADCON0 ;/*-----Delay loop to settle A2D, similar to de-bounce??? mnloop btfss INTCON,T0IF ;50us loop delay @ 4Mhz goto mnloop ;/*-----Stop timer0 interrupt BCF INTCON,T0IF BSF ADCON0,GO_DONE ;start a2d conversion WAITA2D NOP ;wait 4 finish BTFSC ADCON0,GO_DONE GOTO WAITA2D ;/*-----Put A2D/PWM value in W and send to ports. MOVF ADRESH,W ;upper 8 bits-ignor lower 3 MOVWF CCPR1L ;PWM is output on pin 13 of 16F873 MOVWF PORTB ;output Hex value to LEDs RETURN ;DUTY CYCLE IS 25% OF PWM PERIOD END Dip switch representing the windspeed sensor ; FILE: helloDip.asm - WORKS! ; AUTH: P.Oh ; DATE: 1.0 - 04/13/02 16:30 ; DESC: Read Port A DIP switch and display on Port B LEDs ; NOTE: Tested on PIC16F84-04/P. ; Page numbers in code are in Easy Pic'n book ; REFs: Easy Pic'n p. 60 #include <p16F877a.inc> list p=16F877a radix hex ;---------------------------------------------------------------------- ; cpu equates (memory map) myPortC equ 0x07 myPortB equ 0x06 ; (p. 10 defines port address) ;---------------------------------------------------------------------- org 0x000 start movlw 0xFF ; load W with 0xFF make port C input (p. 45) tris myPortC ; copy W tristate to port C outputs (p. 58) movlw 0x00 ; load W with 0x00 make port B output tris myPortB ; copy W tristate to port B movf myPortC, w ; read port C DIP and store in W movwf myPortB ; write W value to port B LEDs circle goto start ; loop forever end ;---------------------------------------------------------------------- ; at blast time, select: ; memory uprotected ; watchdog timer disabled ; standard crystal (4 MHz) ; power-up timer on |
| | #8 (permalink) | |
| Experienced Member Join Date: Jan 2007 Location: U.K.
Tell us the program language. I use the MPLAB assembler. It helps to get a positive response if you can post the program you have written. Also welcome.
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ | |
| | #9 (permalink) |
| Here are my programs, I tried to just post them but it didn't let me, so here are the .asm files. here is also a flow of what i need the program to do, The programs attached work by themselves, the way that I have my circuit built, but I would like to get some ways of combining them to get what i need to acheive. Thanks for any help you can give. I am currently programming in assembly on mplab, because i do have some help from a professor and some experience in it, but I am getting lost easily. The circuit that I have shown is just my block, this is a group of 5 people and i have the microprocessor, I don't even know if the other peoples stuff will work by the time it is all said and done. Main flow Take inputs from the temperature as an analog frequecny convert to digital display all the time take inputs from the humidity sensor as an analog voltage convert to digital display as heat index when push button is pressed with an equation when temps above 27 C/ 80 F with relative humidity > 40 % take input from the windspeed sensor as a digital frequecy (8-bit binary) display as wind chill when push button is pressed with an equation when temps below 4 C and 40 F with wind speeds > 5 mph Elizabeth |
| | #10 (permalink) | |
What range of: Temperature, Humidity, Windspeeds and Chill factor are you required to measure and to what resolution.? These limits will effect the program maths and the displayed data. EDIT: Your atod.asm has a number of errors also its not necessary to define Registers and W/F. The include 16Fxxx takes care of the defines. PR3 is not declared. Check your subr calls and returns, the program generates a 'stack' error.
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ Last edited by ericgibbs; 13th April 2008 at 09:39 AM. | |
| | #11 (permalink) |
| Experienced Member Join Date: Oct 2007
| I can see one software and one hardware problem so far. SW3 will short out the supply if operated. R3 should be instead of the wire that connects Vcc to Vpp. In the software, you don't have a main loop. All code that runs continuously should have a main loop after the initialise that looks something like this: Code: Initialise
;set start values
;setup peripherals
Main_loop
;do stuff here
;call routines
;etc
goto Main_loop |
| | #12 (permalink) |
| [quote=ericgibbs]hi, What range of: Temperature, Humidity, Windspeeds and Chill factor are you required to measure and to what resolution.? These limits will effect the program maths and the displayed data. Temperature - LM335 not LM35-this was going to be 5 volts but it is going to be a analog frequency Humidity - HS1101 - up to 5 volts WindSpeed Sensor, has a whole circuit that will give an 8 bit number from 0 to 255 mph I don't know if there is anything else you guys need to know. |
| | #13 (permalink) | |
| [quote=engineergirl27] Quote:
The LM335 is an analog voltage output 10mV/K, its a Kelvin version of the LM35.? I'll look thru the HS1101 humidity sensor. I expect the Windspeed sensor outputs a continous, asychronous 8bit binary code. Did you see the notes regarding the program that I posted.? One point you will have to decide, is the refresh rate for displayed data. eg; Most weather station data has a slow rate of change, so some form of data averaging should be considered, prior to any display update. On the temperature data, what resolution do you want to display, will 1Cdeg resolution be OK .??? Likewise for humidity , will 1% be OK. Sorry to ask so many questions, but what you are asking has a number of solutions. Regards EDIT: the HS1101 is a capacitive sensor, it requires a C to F convertor, [as shown in the datasheet], it cannot be connected to PORTA as an analog signal.
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ Last edited by ericgibbs; 13th April 2008 at 06:25 PM. | |
| Uni Project Advice | 2-tone | Electronic Projects Design/Ideas/Reviews | 7 | 18th October 2007 12:11 AM |
| My professor screwed my final electronics project! | kungfusansu | Electronic Projects Design/Ideas/Reviews | 21 | 26th August 2007 09:57 PM |
| RPM Counter (Project Started PIC16F877A) | Ayne | Micro Controllers | 28 | 2nd May 2007 01:53 PM |
| PIC16f877A Project help | Alex Ng | Micro Controllers | 5 | 26th July 2006 07:48 AM |
| A Microcontroller based Analogue Waveforms Analyzer Project | km | Electronic Projects Design/Ideas/Reviews | 76 | 30th June 2004 06:40 PM |
