| | #47 (permalink) | |
| New Member Join Date: Feb 2007 Location: Morgantown, WV
F -> C subtract 32, multiply by 5/9. C -> F multiply by 9/5, add 32. Of course, it's the student's responsibility to check, since it's their project and they will be getting the grade. I was adjunct faculty in a chemical engineering department for several years. The first lecture in the first chemical engineering course taught to sophomores was unit conversions. I really hated to teach the problem session that went with that lecture - an hour and a half of unit conversion problems. How dry! Anyway, it's a bit disheartening that a senior engineering student is asking for help on unit conversions. Just my two cents! | |
| | #49 (permalink) |
| New Member Join Date: Apr 2008 Location: US
| You guys are great, I have never been so greatful that my project, would bring so much conversation I am currently debugging this code right now if you want to see it. I am rather proud of it since I am an amature and I was told that May 9th would be tough to get it working by. It is is almost working. Elizabeth |
| | #51 (permalink) | |
Elizabeth | |
| | #52 (permalink) |
| Experienced Member Join Date: Jan 2007 Location: U.K.
| hi Elizabeth, Ran your program in simulation. The Interrupt [ISR] needs to be corrected also the related Interrupt Enables. After the first ADC read, the program keeps looping in the Call CelConversion routines.? You are using TMR0 as an Intr. extract from microchip 16F877A template NOTE the ISR origin. ;************************************************* ********************* Code: ORG 0x000 ; processor reset vector nop ; nop required for icd goto main ; go to beginning of program ORG 0x004 ; interrupt vector location movwf w_temp ; save off current W register contents movf STATUS,w ; move status register into W register movwf status_temp ; save off contents of STATUS register movf PCLATH,w ; move pclath register into w register movwf pclath_temp ; save off contents of PCLATH register ; isr code can go here or be located as a call subroutine elsewhere movf pclath_temp,w ; retrieve copy of PCLATH register movwf PCLATH ; restore pre-isr PCLATH register contents movf status_temp,w ; retrieve copy of STATUS register movwf STATUS ; restore pre-isr STATUS register contents swapf w_temp,f swapf w_temp,w ; restore pre-isr W register contents retfie ; return from interrupt main ; remaining code goes here Do you follow.?
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ Last edited by ericgibbs; 9th May 2008 at 08:42 AM. |
| Uni Project Advice | 2-tone | Electronic Projects Design/Ideas/Reviews | 7 | 18th October 2007 12:11 AM |
| My professor screwed my final electronics project! | kungfusansu | Electronic Projects Design/Ideas/Reviews | 21 | 26th August 2007 09:57 PM |
| RPM Counter (Project Started PIC16F877A) | Ayne | Micro Controllers | 28 | 2nd May 2007 01:53 PM |
| PIC16f877A Project help | Alex Ng | Micro Controllers | 5 | 26th July 2006 07:48 AM |
| A Microcontroller based Analogue Waveforms Analyzer Project | km | Electronic Projects Design/Ideas/Reviews | 76 | 30th June 2004 06:40 PM |
