LinkBack | Thread Tools | Display Modes |
#16 (permalink) |
I know, this programming for me, has brought me many questions and solutions, and i think that is why I am having so many problems, I don't know which solutions is best. Yes to the nearest Degree is fine, same with the nearest 1%, I also, have a push button that is going to be pressed to show the heat index or wind chill. And i was thinking about .5 seconds or so to be refreshed
#17 (permalink) |
May 9th, I would like to get it done before that of course to get it tested. that is right the temp is in mV and the humidty is a frequency, it is difficult to keep them straight since I am not setting them up.
#18 (permalink) |
Eric,
I know, this programming for me, has brought me many questions and solutions, and i think that is why I am having so many problems, I don't know which solutions is best. Yes to the nearest Degree is fine, same with the nearest 1%, I also, have a push button that is going to be pressed to show the heat index or wind chill. And i was thinking about .5 seconds or so to be refreshed blue, May 9th, I would like to get it done before that of course to get it tested. that is right the temp is in mV and the humidty is a frequency, it is difficult to keep them straight since I am not setting them up. |
#19 (permalink) | |
Experienced Member
Understood. I would recommend the follow bits of test hardware in order to simulate the inputs from the various sensors. 1. A 5K0 multiturn pot, connected from +5V to 0V with the wiper going to the PIC's AN0 input, together with a DVM capable of measuring mV, for simulating the LM335 temperature sensor. 2. A variable rate square wave pulse generator, with a setting read out, to simulate the HS1101 humidity 555 osc output. 3. A 8 bit DIL switch to simulate the Wind speed input. You say you are using 4 off, 7seg LED's,,, these will require a few extra components because of the multiplexing of the PIC port pins required to drive them. I would advise, that you write the program in a modular way, that is write the sub programs for each module before you integrate them in your final program. Thats a module for each of the three sensors, the LED display, switch inputs and the maths subroutines. I would start with the display drivers module. This then can be used to display the outputs of the various modules as you develop them. You say 8/9th May 2008 is the deadline, I think an experienced programmer would find it difficult to complete, fully test and debug the hardware/software in 3 weeks for this project. Can you say which country you are posting from.?
Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ |
#20 (permalink) | |
Elizabeth |
#21 (permalink) |
Experienced Member
hi Elizabeth,
The reason for asking your location is because it seems when I am close to closing down you are starting up.. These are asm tutorials from Nigel Goodwins site. http://www.winpicprog.co.uk/ Specific to your project are the 7seg LED mux and Analog tutorials. http://www.winpicprog.co.uk/pic_tutorial10.htm http://www.winpicprog.co.uk/pic_tutorial11.htm This one for switches. http://www.winpicprog.co.uk/pic_tutorial2.htm You could easily adapt these to suit the project. IIRC 'Bill' of Blueroom electronics has done some programming for the HS1101 sensor.? Why dont you write up a program for the LED's and post it, then we can work thru it with you. Likewise the analog module. I hope you are finding these posts helpful, if not ask specific questions. ![]()
#22 (permalink) |
Experienced Member
Hardware yes with the HS1101, software very basic but I cheated
Insteaded of a frequency counter it was simple to connect a spare I/O pin to the 7555 reset pin and the output to one of the CCP inputs. Easy.I agree, as a first PIC project you've got quite an effort ahead of you to complete it by May 9. |
#23 (permalink) |
Thank you, those will help. I am just getting frustrated with myself, because this all seems so new to me. I have had the semester to work on it, but we have also had to do tons of business work for marketing the product, and everything else. We don't get enough training with the programming, at school, we need to teach ourselves.
So thanks, I will be back with more specific questions if I have any. Elizabeth |
#24 (permalink) |
Experienced Member
hi Elizabeth,
This is a link just posted by Bill on another thread, thought it might be useful. http://www.gooligum.com.au/tutorials.html
#25 (permalink) |
Hey guys,
So I have more of a program written, It still isn't what it needs to be but i have a specific question, here is the code that i have include <p16F877a.inc> LIST p=16F877a errorlevel 1,-302 ;to disable MPLAB bank warnings. __config _XT_OSC & _PWRTE_ON & _WDT_OFF &_LVP_OFF ; ;Some versions of MPLAB use _LVP_OFF ;This sets all portB pins to output. ;Variables cblock 0x20 ;start of general purpose registers count endc ;/*---------Init Ports bsf STATUS,RP0 MOVLW B'00000001' MOVWF TRISA ;All outputs except RA0. MOVLW B'00000011' movwf TRISD CLRF TRISB ;RA0 is wiper of 50k pot/Vin movlw b'11111111' movwf TRISC ;PortB is 8 LED output to show ;/*-----Set up A2D parameters MOVLW B'00001110' ;Hex value of Vin from pot. MOVWF ADCON1 ;left justified, RA0 = input MOVLW B'11010111' ;prescaler 1:256 tmr0, internal clock MOVWF OPTION_REG BCF STATUS,RP0 ;/*---------Set up chip parameters Start CALL A2D MOVWF PORTB ;output Hex value to LEDs PC clrf count BTFSS PORTD,0 bsf count,0 BTFSS PORTD,1 bsf count,0 BTFSS count,0 goto Start movf PORTC,w movwf PORTB goto PC A2D MOVLW B'01000001' ;a2d = on, ch0, fosc/8 MOVWF ADCON0 ;/*-----Delay loop to settle A2D, similar to de-bounce??? mnloop btfss INTCON,T0IF ;50us loop delay @ 4Mhz goto mnloop ;/*-----Stop timer0 interrupt BCF INTCON,T0IF BSF ADCON0,GO_DONE ;start a2d conversion WAITA2D NOP ;wait 4 finish BTFSC ADCON0,GO_DONE GOTO WAITA2D ;/*-----Put A2D/PWM value in W and send to ports. MOVF ADRESH,W ;upper 8 bits-ignor lower 3 RETURN ;DUTY CYCLE IS 25% OF PWM PERIOD END Now I plug in the temperature sensor that is also tied to an amplifier to amplify the voltage, when it goes through this program and displays on the eight LEDs on port B it counts very fast. I tried to change the MOVF ADRESH,W to see if it was counting the wrong 8 bits, but it did the same thing. Any Suggestions? Also any quick suggestions for help with entering an equation like this into assembly windchill = 35.74+0.6215T-35.75(V^0.16)+0.4275T(V^0.16) Elizabeth |
#26 (permalink) |
Experienced Member
Gayan Forum Supporter |
#27 (permalink) |
Blue could you explain a little more what you did with the humidity sensor? And did you used a completely different port than the other inputs. And with the CCP pins, I am currently using the Port C as the input from the windchill. Should I move those?
#28 (permalink) |
Hey Guys,
I have been programming, and I have quite a bit done, I was wondering if any of you could help with the math. The equations are quite extensive and I am not that familiar with it enough to do these extensive of equations. Here is what I have got. AND IT WORKS Code:
#include <p16F877a.inc>
LIST p=16F877a
;Variables
COUNT
TEMP
CYC
endc
bsf STATUS,RP0
MOVLW B'00000001'
MOVLW B'00000011'
movwf TRISE
CLRF TRISB ;PortB is 8 LED output to show
movlw b'11111111'
movwf TRISD
MOVLW B'00001110'
MOVWF ADCON1
MOVLW B'11010111'
MOVWF OPTION_REG
BCF STATUS,RP0
Start CALL A2D
MOVWF TEMP
PC
BTFSC PORTE,0
goto Start
;TEMP <= 80
movf TEMP,w
addlw d'255'-d'80'
skpnc
Call HeatIndex
;TEMP <= 40
movf TEMP,w
addlw d'255'-d'40'
skpc
Call WindChill
GOTO Start
A2D
MOVWF ADCON0
goto mnloop
BCF INTCON,T0IF
GOTO WAITA2D
;/*-----Put A2D W and send to port B.
RETURN
HeatIndex
START MOVLW d'10'
MOVWF CYC
CLRF COUNT
L1 BTFSS PORTC,2
GOTO L1
L2 INCF COUNT
BTFSC PORTC,2
GOTO L2
DECFSZ CYC
GOTO L1
MOVF COUNT,w
MOVWF PORTB
BTFSS PORTE,0
GOTO HeatIndex
RETURN
WindChill
movf PORTD,w
movwf PORTB
BTFSS PORTE,0
GOTO WindChill
RETURN
END
#29 (permalink) | |
Experienced Member
Nice job. Post the 'equations' in their mathematic context so that we can suggest suitable software algorithm's for the program. ![]()
#30 (permalink) | |
Experienced Member
@engineergirl27, please put your combined code for both functions as an ASM file instead of Text. It will be useful to analyze
Regards, Sarma. |
| Uni Project Advice | 2-tone | Electronic Projects Design/Ideas/Reviews | 7 | 18th October 2007 12:11 AM |
| My professor screwed my final electronics project! | kungfusansu | Electronic Projects Design/Ideas/Reviews | 21 | 26th August 2007 09:57 PM |
| RPM Counter (Project Started PIC16F877A) | Ayne | Micro Controllers | 28 | 2nd May 2007 01:53 PM |
| PIC16f877A Project help | Alex Ng | Micro Controllers | 5 | 26th July 2006 07:48 AM |
| A Microcontroller based Analogue Waveforms Analyzer Project | km | Electronic Projects Design/Ideas/Reviews | 76 | 30th June 2004 06:40 PM |
