i have a problem using this device.
how may i connect it to to my board i m using dot matrix board. thanks. |
Do you have pictures ?
The Zif sockets are normally on a standard .1" pitch so will fit into most breadboards. What kind of Zif socket are you using ? How many pins ? |
im using this type of zif (40pin for atmel)
![]() and i using this 40 pin dip ![]() but i cant get it work meaning the zif cant get into the 40pin dip what should i use instead thanks. |
That looks like a 28 pin ZIF to me.
I don't understand the question. You solder it to the PCB, how else would you do it?
Nail and head there I think Hero999
This is what you have..
![]() This is what you need... ![]() 1st pic Screw Machine Pin have very small tolerance, can't fit in BIG FAT pins like the ZIF socket has. 2nd pic Stamping Pin can expand more so FAT pin's can be forced in, not a good practice to remove it to often anyway, once you got it in keep it there unless you must remove it. Csaba
I'm could be wrong many time's, at least I know what I'm doing. |
My ZIF socket fits fine into the receptacles of a machine pin DIP socket. The trick was to remove the cross connecting links to give two, single row, machine pin carriers. I have been using it like that for a couple of years in my proto boards.
John |
Oh I get it now. You want to mount the ZIF in the DIL socket.
I don't see why you want to do this. Why don't you just solder the ZIf straight to the PCB?
I don't know about the OP, but for me it was to get reliable connections with the breadboard. The ZIF socket pins were just too fine and short. John
I use the same method, zif into a standard DIL socket. Never have any problems
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
I use my ZIF into a machined pin socket without any problems. Means I get a couple more years use out of it before I damage the pins too much.
| Magnets and Electromagnets | ElectroMaster | Electronic Theory | 11 | 27th November 2007 02:31 PM |
| Motor Sizing For Moving Robots | dknguyen | Electronic Theory | 6 | 25th April 2007 10:43 PM |
| Phisic's Problem Here !! | TiagoSilva | Robotics Chat | 11 | 10th July 2006 06:30 PM |
| how to get force sensing on bottom of 3 DOF leg? | NleahciM | Robotics Chat | 10 | 24th June 2005 05:43 AM |
| Earth Stator Motor | Gavilan | Electronic Projects Design/Ideas/Reviews | 4 | 24th April 2005 09:06 PM |
