dear all m designing a project using pic18f4550 with usart . m not able to get proper data on hyperterminal. m using 4 mhz crystal.bellow is the code .please help me find mistake. #include <p18f4550.h> #include <stdio.h> #include <usart.h> /* Set configuration bits for use with ICD2 / PICDEM2 PLUS Demo Board: * - set HS oscillator * - disable watchdog timer * - disable low voltage programming * - enable background debugging */ //#pragma config OSC = HS //#pragma config WDT = OFF //#pragma config LVP = OFF //#pragma config DEBUG = ON void rx_handler (void); #define BUF_SIZE 25 /* * Step #1 – The data is allocated into its own section. */ #pragma idata bigdata char data[11][BUF_SIZE+1] = { { "String #0\n\r" }, { "String #1\n\r" }, { "String #2\n\r" }, { "String #3\n\r" }, { "String #4\n\r" }, { "String #5\n\r" }, { "String #6\n\r" }, { "String #7\n\r" }, { "String #8\n\r" }, { "String #9\n\r" }, { "Invalid key (0-9 only)\n\r" } }; #pragma idata #pragma code rx_interrupt = 0x8 void rx_int (void) { _asm goto rx_handler _endasm } #pragma code #pragma interrupt rx_handler void rx_handler (void) { unsigned char c; /* Get the character received from the USART */ c = ReadUSART(); if (c >= '0' && c <= '9') { c -= '0'; /* Display value received on LEDs */ PORTB = c; /* * Step #2 – This example did not need an additional * pointer to access the large memory because of the * multi-dimension array. * * Display the string located at the array offset * of the character received */ putsUSART (data[c]); } else { /* * Step #2 – This example did not need an additional * pointer to access the large memory because of the * multi-dimension array. * * Invalid character received from USART. * Display error string. */ putsUSART (data[10]); /* Display value received on LEDs */ PORTB = c; } /* Clear the interrupt flag */ PIR1bits.RCIF = 0; } void main (void) { TRISB = 0; OpenUSART (USART_TX_INT_OFF & USART_RX_INT_ON & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_HIGH, 103);/* Display a prompt to the USART */ putrsUSART ( (const far rom char *)"\n\rEnter a digit 0-9!\n\r");/* Enable interrupt priority */ RCONbits.IPEN = 1;/* Make receive interrupt high priority */ IPR1bits.RCIP = 1;/* Enable all high priority interrupts */ INTCONbits.GIEH = 1;/* Loop forever */ while (1) ; } thanks | |
You appear to have all the config lines commented!! Mike. | |
| | #3 | |
TRISC = b'10111111' Cheers Ravi | ||
| | #4 | |
Mike. | ||
| | #5 | |
Cheers Ravi | ||
| | #6 | |
Mike. | ||
| | #7 | |
Cheers Ravi | ||
| | #8 |
It's mentioned in section 20.0 in the datasheet. The microcontroller will automatically configure the TX pin as an output pin for transmission, but - as Mike said - you set bits TRISC,6 and TRISC,7 when you initialize the EUSART. | |
| | #9 | |
Cheers Ravi | ||
| | #10 |
A lot of the 16 series chips also require them to be input, even the 16F628A does. I think the only downside to not configuring as input is an increase in power consumption. Mike. | |
| | #11 | |
For the 18F series, the behaviour is the same in MPLAB. I will have to check it out practically. Cheers Ravi | ||
| | #12 |
Thanks pommie and ravi for replies ..i tried uncommenting the oscillator settings and configuration bits settings but it gave error .i tried changing the oscillator from xt to hs but still error persisted so i commented only that line....still it is not working.bellow m sending the usart.h file.does this file needs some changes..please help... #ifndef __USART_H #define __USART_H #define PARAM_SCLASS auto #define USART_TX_INT_ON 0b11111111 // Transmit interrupt on #define USART_TX_INT_OFF 0b01111111 // Transmit interrupt off #define USART_RX_INT_ON 0b11111111 // Receive interrupt on #define USART_RX_INT_OFF 0b10111111 // Receive interrupt off #define USART_BRGH_HIGH 0b11111111 // High baud rate #define USART_BRGH_LOW 0b11101111 // Low baud rate #define USART_CONT_RX 0b11111111 // Continuous reception #define USART_SINGLE_RX 0b11110111 // Single reception #define USART_SYNC_MASTER 0b11111111 // Synchrounous master mode #define USART_SYNC_SLAVE 0b11111011 // Synchrounous slave mode #define USART_NINE_BIT 0b11111111 // 9-bit data #define USART_EIGHT_BIT 0b11111101 // 8-bit data #define USART_SYNCH_MODE 0b11111111 // Synchronous mode #define USART_ASYNCH_MODE 0b11111110 // Asynchronous mode #if defined(__18F6585) || defined(__18F6680) || \ defined(__18F8585) || defined(__18F8680) || \ defined(__18F2480) || defined(__18F2580) || \ defined(__18F4480) || defined(__18F4580) || \ defined(__18F2585) || defined(__18F2680) || \ defined(__18F4585) || defined(__18F4680) || \ defined(__18F64J15) || defined(__18F65J10) || defined(__18F65J15) || \ defined(__18F66J10) || defined(__18F66J15) || defined(__18F67J10) || \ defined(__18F84J15) || defined(__18F85J10) || defined(__18F85J15) || \ defined(__18F86J10) || defined(__18F86J15) || defined(__18F87J10) || \ defined(__18F1220) || defined(__18F1320) || \ defined(__18F6525) || defined(__18F6621) || \ defined(__18F8525) || defined(__18F8621) || \ defined(__18F2515) || defined(__18F2525) || \ defined(__18F2610) || defined(__18F2620) || \ defined(__18F4515) || defined(__18F4525) || \ defined(__18F4610) || defined(__18F4620) || \ defined(__18F6310) || defined(__18F6390) || \ defined(__18F6410) || defined(__18F6490) || \ defined(__18F8310) || defined(__18F8390) || \ defined(__18F8410) || defined(__18F8490) || \ defined(__18F2455) || defined(__18F2550) || \ defined(__18F4455) || defined(__18F4550) || \ defined(__18F2510) || defined(__18F2520) || \ defined(__18F2410) || defined(__18F4410) || defined(__18F4420) || \ defined(__18F4510) || defined(__18F4520) || \ defined(__18F6527) || defined(__18F6622) || \ defined(__18F6627) || defined(__18F6722) || \ defined(__18F8527) || defined(__18F8622) || \ defined(__18F8627) || defined(__18F8722) || \ defined(__18F24J10) || defined(__18F25J10) || \ defined(__18F44J10) || defined(__18F45J10) #define BAUD_IDLE_RX_PIN_STATE_HIGH 0b11011111 // idle state for RX pin is high level #define BAUD_IDLE_RX_PIN_STATE_LOW 0b11111111 // idle state for RX pin is low level #define BAUD_IDLE_TX_PIN_STATE_HIGH 0b11101111 // idle state for TX pin is high level #define BAUD_IDLE_TX_PIN_STATE_LOW 0b11111111 // idle state for TX pin is low level #define BAUD_IDLE_CLK_HIGH 0b11111111 // idle state for clock is a high level #define BAUD_IDLE_CLK_LOW 0b11101111 // idle state for clock is a low level #define BAUD_16_BIT_RATE 0b11111111 // 16-bit baud generation rate #define BAUD_8_BIT_RATE 0b11110111 // 8-bit baud generation rate #define BAUD_WAKEUP_ON 0b11111111 // RX pin monitored #define BAUD_WAKEUP_OFF 0b11111101 // RX pin not monitored #define BAUD_AUTO_ON 0b11111111 // auto baud rate measurement enabled #define BAUD_AUTO_OFF 0b11111110 // auto baud rate measurement disabled #endif #if defined(__18F6520) || defined(__18F6620) || defined(__18F6720) || \ defined(__18F8520) || defined(__18F8620) || defined(__18F8720) || \ defined(__18F64J15) || defined(__18F65J10) || defined(__18F65J15) || \ defined(__18F66J10) || defined(__18F66J15) || defined(__18F67J10) || \ defined(__18F84J15) || defined(__18F85J10) || defined(__18F85J15) || \ defined(__18F86J10) || defined(__18F86J15) || defined(__18F87J10) || \ defined(__18F6527) || defined(__18F6622) || \ defined(__18F6627) || defined(__18F6722) || \ defined(__18F8527) || defined(__18F8622) || \ defined(__18F8627) || defined(__18F8722) || \ defined(__18F6525) || defined(__18F6621) || \ defined(__18F8525) || defined(__18F8621) || \ defined(__18F6310) || defined(__18F6390) || \ defined(__18F6410) || defined(__18F6490) || \ defined(__18F8310) || defined(__18F8390) || \ defined(__18F8410) || defined(__18F8490) /* ***** USART1 ***** */ /* status bits */ union USART1 { unsigned char val; struct { unsigned RX_NINE:1; // Receive Bit 8 if 9-bit mode is enabled unsigned TX_NINE:1; // Transmit Bit 8 if 9-bit mode is enabled unsigned FRAME_ERROR:1; // Framing Error for USART unsigned OVERRUN_ERROR:1; // Overrun Error for USART unsigned fill:4; }; }; void Open1USART (PARAM_SCLASS unsigned char config, PARAM_SCLASS char spbrg); #if defined(__18F6525) || defined(__18F6621) || \ defined(__18F8525) || defined(__18F8621) || \ defined(__18F64J15) || defined(__18F65J10) || defined(__18F65J15) || \ defined(__18F66J10) || defined(__18F66J15) || defined(__18F67J10) || \ defined(__18F84J15) || defined(__18F85J10) || defined(__18F85J15) || \ defined(__18F86J10) || defined(__18F86J15) || defined(__18F87J10) || \ defined(__18F6527) || defined(__18F6622) || \ defined(__18F6627) || defined(__18F6722) || \ defined(__18F8527) || defined(__18F8622) || \ defined(__18F8627) || defined(__18F8722) #define DataRdy1USART( ) (PIR1bits.RCIF) #else #define DataRdy1USART( ) (PIR1bits.RC1IF) #endif char Read1USART (void); void Write1USART (PARAM_SCLASS char data); void gets1USART (PARAM_SCLASS char *buffer, PARAM_SCLASS unsigned char len); void puts1USART (PARAM_SCLASS char *data); void putrs1USART (PARAM_SCLASS const MEM_MODEL rom char *data); #define getc1USART Read1USART #define putc1USART Write1USART #define Close1USART( ) RCSTA1&=0b01001111,TXSTA1bits.TXEN=0,PIE1&=0b11001 111 #define Busy1USART( ) (!TXSTA1bits.TRMT) #if defined(__18F6525) || defined(__18F6621) || \ defined(__18F8525) || defined(__18F8621) || \ defined(__18F6310) || defined(__18F6390) || \ defined(__18F6410) || defined(__18F6490) || \ defined(__18F8310) || defined(__18F8390) || \ defined(__18F8410) || defined(__18F8490) || \ defined(__18F64J15) || defined(__18F65J10) || defined(__18F65J15) || \ defined(__18F66J10) || defined(__18F66J15) || defined(__18F67J10) || \ defined(__18F84J15) || defined(__18F85J10) || defined(__18F85J15) || \ defined(__18F86J10) || defined(__18F86J15) || defined(__18F87J10) || \ defined(__18F6527) || defined(__18F6622) || \ defined(__18F6627) || defined(__18F6722) || \ defined(__18F8527) || defined(__18F8622) || \ defined(__18F8627) || defined(__18F8722) void baud1USART (PARAM_SCLASS unsigned char baudconfig); #endif /* ***** USART2 ***** */ /* status bits */ union USART2 { unsigned char val; struct { unsigned RX_NINE:1; // Receive Bit 8 if 9-bit mode is enabled unsigned TX_NINE:1; // Transmit Bit 8 if 9-bit mode is enabled unsigned FRAME_ERROR:1; // Framing Error for USART unsigned OVERRUN_ERROR:1; // Overrun Error for USART unsigned fill:4; }; }; void Open2USART (PARAM_SCLASS unsigned char config, PARAM_SCLASS char spbrg); #define DataRdy2USART( ) (PIR3bits.RC2IF) char Read2USART (void); void Write2USART (PARAM_SCLASS char data); void gets2USART (PARAM_SCLASS char *buffer, PARAM_SCLASS unsigned char len); void puts2USART (PARAM_SCLASS char *data); void putrs2USART (PARAM_SCLASS const MEM_MODEL rom char *data); #define getc2USART Read2USART #define putc2USART Write2USART #define Close2USART( ) RCSTA2&=0b01001111,TXSTA2bits.TXEN=0,PIE3&=0b11001 111 #define Busy2USART( ) (!TXSTA2bits.TRMT) #if defined(__18F6525) || defined(__18F6621) || \ defined(__18F8525) || defined(__18F8621) || \ defined(__18F64J15) || defined(__18F65J10) || defined(__18F65J15) || \ defined(__18F66J10) || defined(__18F66J15) || defined(__18F67J10) || \ defined(__18F84J15) || defined(__18F85J10) || defined(__18F85J15) || \ defined(__18F86J10) || defined(__18F86J15) || defined(__18F87J10) || \ defined(__18F6527) || defined(__18F6622) || \ defined(__18F6627) || defined(__18F6722) || \ defined(__18F8527) || defined(__18F8622) || \ defined(__18F8627) || defined(__18F8722) void baud2USART (PARAM_SCLASS unsigned char baudconfig); #endif #else /* ***** USART (TXSTA, RCSTA, etc.) ***** */ /* status bits */ union USART { unsigned char val; struct { unsigned RX_NINE:1; // Receive Bit 8 if 9-bit mode is enabled unsigned TX_NINE:1; // Transmit Bit 8 if 9-bit mode is enabled unsigned FRAME_ERROR:1; // Framing Error for USART unsigned OVERRUN_ERROR:1; // Overrun Error for USART unsigned fill:4; }; }; void OpenUSART (PARAM_SCLASS unsigned char config, PARAM_SCLASS unsigned spbrg); #define DataRdyUSART( ) (PIR1bits.RCIF) char ReadUSART (void); void WriteUSART (PARAM_SCLASS char data); void getsUSART (PARAM_SCLASS char *buffer, PARAM_SCLASS unsigned char len); void putsUSART (PARAM_SCLASS char *data); void putrsUSART (PARAM_SCLASS const MEM_MODEL rom char *data); #define getcUSART ReadUSART #define putcUSART WriteUSART #define CloseUSART( ) RCSTA&=0b01001111,TXSTAbits.TXEN=0,PIE1&=0b1100111 1 #define BusyUSART( ) (!TXSTAbits.TRMT) #if defined(__18F6585) || defined(__18F6680) || \ defined(__18F8585) || defined(__18F8680) || \ defined(__18F2480) || defined(__18F2580) || \ defined(__18F4480) || defined(__18F4580) || \ defined(__18F2585) || defined(__18F2680) || \ defined(__18F4585) || defined(__18F4680) || \ defined(__18F1220) || defined(__18F1320) || \ defined(__18F2515) || defined(__18F2525) || \ defined(__18F2610) || defined(__18F2620) || \ defined(__18F4515) || defined(__18F4525) || \ defined(__18F4610) || defined(__18F4620) || \ defined(__18F2455) || defined(__18F2550) || \ defined(__18F4455) || defined(__18F4550) || \ defined(__18F2410) || defined(__18F2510) || defined(__18F2520) || \ defined(__18F4410) || defined(__18F4510) || defined(__18F4520) || \ defined(__18F24J10) || defined(__18F25J10) || \ defined(__18F44J10) || defined(__18F45J10) void baudUSART (PARAM_SCLASS unsigned char baudconfig); #endif #endif #endif | |
| | #13 |
| HELP I ran the code written in the beginin of the thread and got the following error... Error - section 'bigdata' can not fit the section. Section 'bigdata' length=0x0000011e Please help.. | |
| | #14 |
The error is while compiling the code and not on loading it into the PIC.
| | #15 |
This is something you can fix on your own length=0x0000011e is 286. Ask the world's hotdog eating contest winner what it's like to fit more than you can ![]() World's most hot dogs eaten. Takeru "Tsunami" Kobayashi. | |
| pic, usart |
| Drive 33 Servos With One PIC + USART | wschroeder | Micro Controllers | 45 | 25th October 2008 10:10 AM |
| Quik PIC Programming kit | Krumlink | General Electronics Chat | 5 | 28th January 2008 12:27 AM |
| Capturing and reproducing audio with a PIC | Fred.Amoson | Micro Controllers | 14 | 14th December 2007 09:22 PM |
| RF receive using PIC USART | col_implant | Electronic Projects Design/Ideas/Reviews | 11 | 15th November 2007 05:06 PM |
| High ADC sampling rate PIC, 18F needed? | bananasiong | Micro Controllers | 24 | 28th October 2007 01:13 PM |
