Old 3rd April 2008, 06:00 PM   (permalink)
Default Questions about PIC16F628
Back to PIC, I've got some questions:
1- In the PIC name PIC16F628-20/P, what is 20/P stand for? Speed or memory?
2- Is it possible to run more than one Delay subroutine at the same time for different parts of the program?
3- Can i assign all the PIC16F628A pins as output ( except for VCC & Gnd )
4- In my programmer, the ICSP pins are marked with the pin names, do I have to connect them directly to the PIC pins ( If I want to do in circuit programming )
Its what your friend in Your mind, what you in your friends mind
aljamri is offline
Old 3rd April 2008, 06:06 PM   (permalink)
20 = 20MHz
P = Plastic
I = Industrial
2. yes, you'll probably need timers / interrupts.
3. No MCLR (RA5) is input only, RA4 may be open collector output on some PICs
4. yes you connect directly to the PIC pins for ICP
Bill
Smart Kits build Smart People
Old 3rd April 2008, 07:04 PM   (permalink)
Thanks for your fast reply, I'm using 16F628A can i ask for more:
Originally Posted by blueroomelectronics
20 = 20MHz
Is this maximum i can drive it externally? because i knew that its internal Clock is 4MHz ( Thanks to N.Goodwin ) am i right ?
software or hardware ?
so maximum of 14 outputs can be used ?
With the circuit supply ON?
aljamri is offline
Old 3rd April 2008, 08:21 PM   (permalink)
20MHz is the maximum clock frequency for the 16F628A
Timers and interrupts are all built in peripherals. So you just program them to work the way you want them to. You can simulate timers & interrupts with the MPLAB simulator.
15.5 outputs, the open collector is still an output but it can only pull low.
It can have its own power or depending on the programmer the programmer may supply power.
Bill
Old 4th April 2008, 12:18 AM   (permalink)
what about overclocking it with bigger crystal?
whiz115 is offline
Old 4th April 2008, 12:37 AM   (permalink)
Works fine, but don't count on it working on every chip, or being reliable.
http://www.google.ca/search?q=pic+overclocking
futz is offline
Old 4th April 2008, 01:02 AM   (permalink)
Better to use a fater PIC. How much did you plan to overclock it by?
Bill
Old 4th April 2008, 11:51 PM   (permalink)
about 5 MHz
whiz115 is offline
Old 4th April 2008, 11:54 PM   (permalink)
about 5 MHz
Try it and see. It won't hurt anything. All that can go wrong is that it might not work. It will run a bit warmer and consume a little more current. Neither will likely be a problem.
EDIT: Just tried a 25MHz on my 16F877 with the GLCD. No go. Went back to the 20MHz and it's happy again. The 25 might need different caps or some small changes to the program. I didn't test, as I'm busy doing different things right now.
futz is offline
Radio questions Tchaikovsky01 Electronic Projects Design/Ideas/Reviews 2 3rd October 2007 08:06 AM
877A to DAC (MCP4922)... SPI questions. ChemE Electronic Projects Design/Ideas/Reviews 1 8th June 2007 04:22 PM
PIC16F628 to PIC16F84 kasamiko Micro Controllers 2 5th May 2005 05:27 PM
Exam tomorrow...help with questions?? petesmc General Electronics Chat 5 14th June 2004 02:17 PM
Electronics Pre-Test questions Mike_07 General Electronics Chat 0 13th November 2003 03:22 AM
