| Cool thats hot. I want to try that. You used the 16x2 from dipMicro? LOL NEVERMIND just read the rest of posts
__________________ AtomSoftTech.com My YouTube Videos! My Favorite Stores: dipmicro Electronics SparkFun Electronics Futurlec BG Micro | |
| OK i got a good thread starter. How can i send data to hyper terminal through a MAX232 (rs232) DB9 I think i should have all the tools for that. I need to buy the LCD so i have to wait for another time to learn that.
http://www.electro-tech-online.com/m...rogram-ya.html RB1 and RB4 are TX and RX for async comm.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 18th March 2008 at 12:20 AM. | ||
| didnt notice i can use a basic rs232 setup thx
| ok for this to work i need some info... I know RB1/AN5/TX/CK/INT1 = TX RB4/AN6/RX/DT/KBI0 = RX Now what else i need? or is that the only wires from the PIC to the 232?
| You don't need any special wires the Junebug is already wired for the UART tool. The PICkit2 2.40 software (not MPLAB) has a UART tool (TTL rs232 terminal) built in and free. Just program the 18F1320 normally, turn off DIP switches 1,2,3 and turn on 4 & 5 (TX, RX) Run the PICkit2 software and from Tools / UART Tool... Set your baud rate (9600 is the default) then press connect. Try it with reaction timer on my site *uses Swordfish BASIC If you want the hex file I'll be happy to post it here. | |
Hope to see your working projects. | ||
| tired:
| Im tired so ima go to bed its 11:30pm here um.. ill read in the morning and try to amaze you all lol at least im trying (and having fun) (good night to all) (morning to some)
| wow that UART stuff is cool just tried it and nice! but iwould like to know(or will figure it out soon) how its done like the inners of making it work. To figure it out im going to check the schematics of junebug to determin what parts from the junebug has to be copied off and i need to buy some 18F1320s. I see you are using the 18F2550 to connect the USB. I would need to know how to do this. Or is it possible just to use the max232 for this but on a serial cable?
| im going to try something brb
| i got it sort of ... i used a Max232CPE and a DB9 but for some reason it locks up well doesnt lock up but it doesnt let me send data to it in hyper terminal. Any thoughts?
| LOL it was the Flow Control EDIT: Working Fine now 100% thx im going to study the code now and have some extra fun. Heres a picture (i love pictures) lol ![]()
| Im even able to DEBUG awsome (just flick 1,2,3 on tutor) Thanks again ill see what i can make and try to wow you lol
| The max232 is a handy chip for sure. Here's some food for thought. As long as you don't damage the bootloader on the Junebug its possible to use the Junebugs 18F2550 as an experimenter. Some possible programs and I'll look them up later today would be FT232R emulator (use your Junebug as a standalone USB to TTL RS232 adapter) PICkit Serial anaylzer, its similar to a PICkit2 but I've yet to make it work. Remember your Junebug has its own ICD connector (first 5 pins on the top 16pin connector) can be programmed and debugged from another Junebug or PICkit2 (you'll need to add a 22k resistor to debug pins1 & 3) That connector also has the 6 pin PICkit2 pinout (last 6 pins) and unused I/O is available with the remaining 5pins. | |
| controlling fan motors using pic16f84a | farasue | Electronic Projects Design/Ideas/Reviews | 2 | 4th March 2008 03:36 PM |
| Reading Volvo cooling fan schematic | jamyers | General Electronics Chat | 6 | 8th January 2008 06:32 PM |
| havea look at a fan circuit and tell if its fine | sjagandeep | General Electronics Chat | 4 | 15th December 2007 03:29 PM |
| Heat controlled fan. (High temp = fast fan) vice versa | zac-uk | Electronic Projects Design/Ideas/Reviews | 3 | 15th November 2007 03:33 PM |
| Automatic Fan | civictypeR | Electronic Projects Design/Ideas/Reviews | 8 | 11th October 2007 02:16 PM |
