Howdy All, I am a newbie to using microcontrollers and have just finished puting together the Inchworm+. I think it's working ok since I was able to load the operation system. But now I would like to start playing around with it. I assume there are two way to use the programmer. The first is build a project and connect the Inchwork to the finished project to program the pic. The second is to have a carrier board with a ZIF socket and program the pic then put the pic in the project. Can someone suggest a ready made/kit carrier board with a zif socket maybe a prototyping board that works with the Inchworm. Thanks for any help advice. | |
| | #2 | |
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | ||
The Firefly was designed as a ZIF socket and / or a 16F88 Tutor. ZIF is handy for bulk programming but ICD can offer both programming and debugging. You can also connect the Inchworms ICD connector to a breadboard and your target PIC. | |
Thanks for the info! I did not make the connection (no pun intended) for the total use of the Firefly. I think I will place an order for the TZ. That will allow me to learn the PIC with the 16F88 and then use it to program other models for the projects I have in mind. I guess the Inchwork+ and the Firefly make a nice learning/development environment.
| | #5 | |
Like this. Just imagine your Inchworm+ sitting where that PICkit2 is: http://www.electro-tech-online.com/a...g?d=1205565788
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 17th March 2008 at 04:17 PM. | ||
| | #6 |
I have a lot of components and breadboards but the PIC is new to me. I was playing around with basic stamp but that seems to be an expensive way to go just to play around so I thought I would learn the Microchips. So, if I have this right. I would use the combination of Inchworm+ and Firefly to program the PIC with the Firefly just being an easy way to attach the PIC to the programmer (and also a tutor to learn) The breadboard would be used to prototype my circuit and I just add the PIC I just programmed using the Inchworm/Firefly?
| | #7 | ||
When using a ZIF for programming, you pry your PIC out of its socket, put it in the ZIF, program it, pull it out, put it back in its socket, test it, pry it out... Over and over and over hundreds of times. This gets REALLY old really really fast. It's slow and tedious. With an ICSP connector on your target board (whether it be breadboard or dev board) you simply change your program and tell the programmer to program the chip. No removal of the chip from its circuit is necessary. It's simple and quick. Quote:
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 17th March 2008 at 05:35 PM. | |||
| | #8 |
Oh, another thing. With many PICs, using ICSP, you can do on-chip debugging. You can start and stop your program, single step it, use breakpoints, examine and change registers and memory, all right on the chip, while it's running your program. Breadboards are the way to go for experimenting, but a good dev board can be a good starting point too. And you can connect the dev board to the breadboard as a way to expand the dev board's capabilities. For instance, here's a homebuilt dev board connected to a breadboard with a ribbon cable so I can do temporary things without having to solder everything in. The dev board PIC is the brains, but the circuit being controlled is on the breadboard. The small ribbon is the ICSP cable for programming the 18F452 on the dev board. ![]() In case you think I'm full of crap cuz I have different programmer than you, I also own an Inchworm+ and the Unicorn USB upgrade for it too. I just use the Junebug/PICkit2 more often these days.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 17th March 2008 at 05:23 PM. | |
| | #9 |
Thanks for the info...I think I got it! I think what I was missing was not understanding the "What do you need to program the PIC" So, if I got it right this time, I can breadboard my entire circuit PIC and all on a solderless breadboard and include the needed ICSD pins (VPP, VDD, GND, PGD, PGC ) and connect this to the Inchworm and i'm good to go. I the Firefly would still be a good learning platform.
| | #10 | |
Build yourself one or more of these for connecting your ICSP cable to the breadboard. The male connectors are cheap and easily available. The reason the header is missing one pin is that it was a USB connector that was salvaged off an old computer mainboard. That pin isn't needed anyway so I didn't cut a new piece of header: ![]() ![]() ![]() ![]() You can get free programming cables by ripping parts from ancient pre-pentium computers and assembling two old serial cables into one programming cable. Or you can buy them new from SparkFun or other company. Or just buy the connectors and build your own cables using ribbon from old floppy/IDE cables.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 18th March 2008 at 03:07 AM. | ||
| | #11 |
Another option which I found handy was to choose a PIC with "self programming" capabilty and program it once with a "bootloader". After that I would download new programs onto the PIC via the bootloader using the PIC and PC serial ports and Hyperterminal 'front end'... No programmer necessary...
| | #12 | |
You own a programmer. A bootloader isn't necessary anymore. Whether you have to put a ICSP connector or a serial connector on your target board makes almost no difference. Either way you put some kind of connector on there. Probably the ICSP is easier anyway.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= | ||
| | #13 |
If you prefer having your Laptop, Programmer, and Project board all laid out in front of you during your development sessions, that's fine. There's nothing wrong with that. Myself, I find it faster and more convenient using just my Laptop and Project board (programmed with a serial bootloader) which also seems to be a bit more portable (I always carry my Laptop and my Project board may be small enough to fit in a shirt pocket). I also don't have to dedicate (sacrifice) my PIC ICSP pins or take up board space for an ICSP connector. Bootloaders aren't for everybody and I haven't found one I really liked and so I write my own. Both 16F' and 18F' versions use less than 256 words of program memory. My bootloaders don't require a proprietary PC 'front end' but use Hyperterminal instead (which comes with the PC). I also use any existing pin that's connected to a switch or speaker or something like that as the bootloader 'trigger'. That is, if there's a switch connected to RC0 for example, the bootloader simply tests to see if that switch is pressed during "power up" or after a "reset" to 'trigger' the bootloader. This makes it extremely easy to get into and out of the bootloader during the development process. For example, I press and hold the switch connected to RC0 and press the "reset" push button to bring up the bootloader. I download the new hex file using Hyperterminal. Then I press "reset" again to restart the Project board with the newly downloaded program. The whole process takes only a few seconds. Yes, you do need to modify your application programs to operate correctly with a bootloader. This is easy for assembly language programs but requires a little more work for C or BASIC programs; Code: ;
; 16F' assembly language example
Start equ h'0100' ; bootloader present
org Start+0 ; 0000 or 0100 (bootloader)
Reset_Vector
clrf STATUS ; force bank 0, IRP 0 |B0
goto Main ; |B0
org Start+4 ; 0004 or 0104 (bootloader)
Interrupt_Vector
< picture below of Hyperterminal screen after a program download and just before pressing "reset" on the Project board to start the new program> Last edited by Mike, K8LH; 17th March 2008 at 11:34 PM. | |
| | #14 |
I use a bootloader only if I want the customer to update the firmware sans programmer. It's not a great development tool IMO. Neat trick, the Junebug (PICkit2) has a USB bootloader when you hold down the button when powering it on. I think I saw a FT232 emulator that uses it. | |
| | #15 |
Well, some people (you included if I recall correctly) object to dedicating a pin to 'trigger' the bootloader and so that's why I try to use an existing pin with something attached to it. A switch is most convenient but since almost all of my projects include a piezo speaker connected directly to a pin for switch press beep feedback, I layout pcb's with a pull-up resistor on that pin and a jumper between the pin and the piezo speaker. This allows me to pull the jumper and the bootloader will read a '1' on that pin after "reset" or read a '0' with the jumper in place. And so I don't have to dedicate a pin just for the bootloader 'trigger'. Yes, the ability for a customer to download an updated program without a programmer could come in handy but in that case I think I would use a custom PIC firmware and custom PC 'front end' to make the process as bullet proof as possible. Mike | |
| board, pic, prototyping, suggestions |
| Home made PCB's | markland556 | General Electronics Chat | 27 | 22nd February 2008 03:31 PM |
| Adding LEDs to ICs (PIC - MAX232) Suggestions? | johankj | Electronic Projects Design/Ideas/Reviews | 2 | 18th February 2008 02:27 PM |
| CPLD prototyping board. | jrz126 | General Electronics Chat | 1 | 18th October 2007 02:39 PM |
| Blueroomelectronics PB01 Prototyping board, Opinions welcome (picture) | blueroomelectronics | Electronic Projects Design/Ideas/Reviews | 7 | 4th February 2007 12:58 PM |
| why is the prototyping board called "breadboard"? | janetsmith2000@yahoo.com | General Electronics Chat | 3 | 25th July 2005 02:45 PM |
