hi everybody . here its is what i want to do exactly and wat i got . i want to connect 4 pic16f84a to 1 pic18f4550 serially . and every pic16 send its portb value to pic18 serially . then pic18 send the value to my pc usb . so i write the code for pic16 and test it on my pc serial port and its working fine and send the right value . what when connect to pic18 , pic18 send wrong values . here is my code and hope to find anything wrong ? ************************************************** *** ' pic16f84a code include "modedefs.bas" define osc 4 TRISB = %11111111 ' portb all input PORTB = %00000000 ' portb 0 TX VAR PORTA.2 ' transmmit B0 VAR BYTE ' var for store portb value B1 VAR BYTE ' var for store portb value start : B0 = PORTB PAUSE 100 B1 = PORTB IF B1 = B0 THEN start IF B1<> B0 THEN SEROUT TX,N9600,[B1] B1 = B0 GOTO start ************************************************** ******* 'pic18f4550 code Include "modedefs.bas" INCLUDE "DT_INTS-18.bas" DEFINE OSC 20 PORTD = 0 TRISD = %11111111 ASM INT_LIST macro INT_Handler USB_INT, _DoUSBService, ASM, yes endm INT_CREATE endasm USBBufferSizeTX con 8 USBBufferSizeRX con 8 USBBufferCount Var Byte USBBufferIn var byte[8] USBBufferOut Var Byte[8] DataToSend var byte[8] RX VAR PORTD.1 VAR0 VAR BYTE asm SendUSB macro array variable i=0 while i<8 MOVE?BB (array+i),(_USBBufferOut+i) i+=1 endw L?CALL _DoUSBOut endm endasm SwHwInit: GOSUB DoUSBinit: Start: '************************************************* ********************* serin rx,N9600,VAR0 datatosend[4] = VAR0 '************************************************* ********************* @ SendUSB _DataToSend gosub dousbin goto start DoUSBIn: @ INT_DISABLE USB_INT USBBufferCount = USBBufferSizeRX USBService USBIn 1, USBBufferin, USBBufferCount, Timeout Timeout: @ INT_ENABLE USB_INT return DoUSBOut: @ INT_DISABLE USB_INT WaitPC: USBBufferCount = USBBufferSizeTX USBService USBOut 1, USBBufferOut, USBBufferCount, Waitpc @ INT_ENABLE USB_INT return usb_device_state var byte EXT CONFIGURED_STATE CON EXT DoUSBinit: pause 500 usbinit repeat usbservice until usb_device_state = CONFIGURED_STATE @ INT_ENABLE USB_INT return DoUSBService: usbservice @ INT_RETURN ************************************************** ******** thanks , regards
__________________ jax | |
| communication, pic, pic16f84a, problem, serial, strange |
| WIRELESS & SERIAL COMMUNICATION | DTMF | Micro Controllers | 11 | 22nd July 2005 11:18 PM |
| Serial communication problem | tbrown | Micro Controllers | 12 | 13th February 2004 11:32 AM |
| Serial Communication Problem. Need some help please. | Beefer3 | Micro Controllers | 5 | 12th November 2003 05:14 PM |
| strange color camera problem | schrodingerscat | Electronic Projects Design/Ideas/Reviews | 5 | 4th October 2003 08:25 PM |
| Serial Cable Problem | ElectroGeek_87 | Micro Controllers | 4 | 13th August 2003 11:48 AM |
