Old 20th February 2008, 02:15 AM   #1
Default need help...
helllo everybody...
actually right now i'm doing dc motor speed controller using pic16f873...
but the problem is the code that i have is error...
and i'm new in this electronic project(hobbyist)...
i'm already try to find out the error but with the knowledge that i have is so limited really upset me....i've learn the instruction that be used in pic(assembly language).....35 instruction totally...
can anyone help me...i've got this code from internet also....
this is the source code...
list p=pic16f873
include p16f873.inc
__config _hs_osc & _wdt_off & _pwrte_on & _lvp_off
errorlevel -302 ;Suppress bank warning
;**************** Label Definition ********************
speed equ d'8' ;Reference speed (5x8/256=0.156V)
change equ d'1' ;Change value (2mV/ms)
led equ h'20' ;LED control data save area
;**************** Program Start ***********************
org 0 ;Reset Vector
goto init
org 4 ;Interrupt Vector
goto int
;**************** Initial Process *********************
init
;*** Port initialization
bsf status,rp0 ;Change to Bank1
movlw b'00000001' ;AN0 to input mode
movwf trisa ;Set TRISA register
clrf trisb ;Set TRISB to uotput mode
clrf trisc ;Set TRISC to output mode
bcf status,rp0 ;Change to Bank0
;*** A/D converter initialization
movlw b'10000001' ;ADCS=10 CHS=AN0 ADON=ON
movwf adcon0 ;Set ADCON0 register
movlw b'00001110' ;ADFM=0 PCFG=1110
movwf adcon1 ;Set ADCON1 register
;*** PWM initialization
clrf tmr2 ;Clear TMR2 register
movlw b'11111111' ;Max duty (low speed)
movwf ccpr1l ;Set CCPR1L register
movlw d'255' ;Period=1638.4usec(610Hz)
movwf pr2 ;Set PR2 register
movlw b'00000110' ;Pst=1:1 TMR2=ON Pre=1:16
movwf t2con ;Set T2CON register
movlw b'00001100' ;CCP1XY=0 CCP1M=1100(PWM)
movwf ccp1con ;Set CCP1CON register
;*** Compare mode initialization
clrf tmr1h ;Clear TMR1H register
clrf tmr1l ;Clear TMR1L register
movlw h'61' ;H'61A8'=25000
movwf ccpr2h ;Set CCPR2H register
movlw h'a8' ;25000*0.4usec = 10msec
movwf ccpr2l ;Set CCPR2L register
movlw b'00000001' ;Pre=1:1 TMR1=Int TMR1=ON
movwf t1con ;Set T1CON register
movlw b'00001011' ;CCP2M=1011(Compare)
movwf ccp2con ;Set CCP2CON register
;*** Interruption control
movlw b'00000001' ;CCP2IE=Enable
movwf pie2 ;Set PIE2 register
movlw b'11000000' ;GIE=ON PEIE=ON
movwf intcon ;Set INTCON register
wait
goto $ ;Interruption wait
;*************** Interruption Process *****************
int
clrf pir2 ;Clear interruption flag
ad_check
btfsc adcon0,go ;A/D convert end ?
goto ad_check ;No. Again
movfw adresh ;Read ADRESH register
sublw speed ;Ref speed - Detect speed
btfsc status,c ;Reference < Detect ?
goto check1 ;No. Jump to > or = check
;--- control to low speed ---
movfw ccpr1l ;Read CCPR1L register
addlw change ;Change value + CCPR1L
btfss status,c ;Overflow ?
movwf ccpr1l ;No. Write CCPR1L
goto led_cont ;Jump to LED control
check1
btfsc status,z ;Reference = Detect ?
goto led_cont ;Yes. Jump to LED control
;--- control to fast speed ---
movlw change ;Set change value
subwf ccpr1l,f ;CCPR1L - Change value
btfsc status,c ;Underflow ?
clrf ccpr1l ;Set fastest speed
;**************** LED control Process ******************
led_cont
comf ccpr1l,w ;Complement CCPR1L bit
movwf led ;Save LED data
movlw b'00010000' ;Set compare data
subwf led,w ;LED - data
btfsc status,c ;Under ?
goto led1 ;No.
movlw b'00000000' ;Set LED control data
goto int_end ;Jump to interrupt end
led1 movlw b'00100000' ;Set compare data
goto led2 ;No.
movlw b'00000001' ;Set LED control data
led2 movlw b'01000000' ;Set compare data
goto led3 ;No.
movlw b'00000011' ;Set LED control data
led3 movlw b'01100000' ;Set compare data
goto led4 ;No.
movlw b'00000111' ;Set LED control data
led4 movlw b'10000000' ;Set compare data
goto led5 ;No.
movlw b'00001111' ;Set LED control data
led5 movlw b'10100000' ;Set compare data
goto led6 ;No.
movlw b'00011111' ;Set LED control data
led6 movlw b'11000000' ;Set compare data
goto led7 ;No.
movlw b'00111111' ;Set LED control data
led7 movlw b'11100000' ;Set compare data
goto led8 ;No.
movlw b'01111111' ;Set LED control data
led8 movlw b'11111111' ;Set LED control data
;************ END of Interruption Process **************
int_end
movwf portb ;Set PROTB
retfie
; END of DC motor speed controller
end
imisendo_4036 is offline
