hy, i am trying to do some interrupt programming test on my PIC18f4620 which i used previously as Zigbee node. means the zigbee node program was there. now i built another test program and successfully compleate the 'Project built' and 'program' by MPLAB ICD2. after that i connect Hyperterminal to see the serial port operation (sending information from pc to microcontroller and microcontroller to pc). but still i am getting the message "Microchip ZigBee(TM) Stack - v1.0-3.5......." which i had previously while working with zigbee. now my query is how to erase the previous program from PIC18f4620. | |
Hi, I am a newbie as well but I can suggest you things which I do to erase the program. If you are using MPLAB ICD2, then select the programming mode [NOT the debugging mode]. Set a connection with the PIC. Then go to program--> Erase part. After that click on Blank check. Finally click on program to load your code into the PIC. Hope this helps. Regards, Vili | |
| | #3 | |
Sounds to me like he either has something wired wrong, or his programmer isn't working right. And you can program it in debug mode, from the debugger menu. It takes a bit longer, as it has to program the debug code as well as your own.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 19th February 2008 at 05:16 PM. | ||
| pic, previous, problem, program |
| pic16f877 ram problem | osmandemirci | General Electronics Chat | 1 | 28th November 2006 04:11 PM |
| P16F628A w/ P16PRO programming problem | micro571 | Micro Controllers | 7 | 16th February 2006 05:17 PM |
| Program Address for 16F628A | johnnyquest | Micro Controllers | 1 | 11th January 2005 07:47 PM |
| A very strange problem on 16F877 | liupengjian | Micro Controllers | 5 | 21st April 2004 10:36 AM |
| how do I debug my pic program ? | lneijman | General Electronics Chat | 1 | 3rd March 2003 11:58 AM |
