Hi Folks.
I have a problem with programming various types of dsPICs, in a development environment There seem to be a very limited number of times that the PIC can be reprogrammed. Has anybody else encountered this problem, and or found a fix, (apart from replacing the PIC)? Thanks Roger |
You're doing something wrong or foolish if you're wearing out the Flash. Most modern PICs have 100,000 write cycles. What's the application?
I've had similar issues. Your programmer connector is not getting a good connection, or if you're doing in-circuit programming, you might have a power supply issue. I've found that with ICP, I have to have the whole system powered up for it to work.
I have managed to hit the eeprom write limit on a PIC. My program was writing to the same location as fast as possible and after an hour or so that location was stuck.
However, some PICs, such as the 18F25J10 are a lot more limited and have a minimum endurance or 100, with a typical value of 1000. It is also possible to have a PIC in an application that stops it being programmed. During programming the programmer briefly releases the reset line, and if the program / circuit does something odd immediately, the programmer gets upset. On one application, we have a power reset that causes a system reboot. We reallocated the pin that drives that between hardware versions. If we program one hardware version with the software of the other, this kicks in immediately, so the power is only on for 1/2 a second at a time. With a 18F25J10 the maximum voltage is only 3.6V so we can't power it from the ICD2. We have to physically disable the power reset before we can reprogram. |
Thanks guys.
The application is for a rotary steerable down hole tool. We use a dsPIC30F6015 for our main processor, and a dsPIC30F3010 for the motor controller. All voltages seem ok, including during programming. I have ,however, Just found that during programming the MCLR\ is going negative by some 1V. I have just fitted a 100R resistor to limit the current out of the pin during these negative excursion. Any other thoughts would be appreciated. Regards Roger |
MCLR should be tied to ground with a 4.7K resistor.
Oops. Yes. VDD. I have a MikroE programmer. 1K - 10K is the suggested range.
Thanks guys.
I will change the 4k7 that is currently fitted to 22k. We use an ICD2 programmer. Regards Roger |
If it works at 4.7K there's really no need to change it. If you have a hard time getting debug to work then it's worth a try.
How did you resolve the issue? Did you spread the writing across many locations, cut down on the frequency and only wright when the value actually changed.?
You can program PICs to program their own program memory. That is what bootloaders do.
On some PICs, such as pic18F24J10, the only EEPROM is the program memory. I wasn't actually programming the program space. I was writing to the data EEPROM. That has a larger endurance, but it is still only 1,000,000 or so. My code wrote to a couple of locations as fast as possible, so about every 2 ms, or 4ms for two locations. That is 250 times per second, so 1,000,000 in 4000 seconds, or about an hour. My code was faulty. I was trying to get it to write only when the data wasn't correct, but that obviously didn't work. I changed it to write when the data was new. |
| problems with programming a pic 16f628a | tanilas | Micro Controllers | 18 | 29th April 2008 10:46 PM |
| Quik PIC Programming kit | Krumlink | General Electronics Chat | 5 | 27th January 2008 11:27 PM |
| Problems switchin relay with PIC | Andy1845c | General Electronics Chat | 5 | 17th November 2007 06:13 PM |
| Question about Inchworm+ | Quan | Micro Controllers | 54 | 28th October 2007 12:20 AM |
| Programming PIC to generate square wave | elec123 | Micro Controllers | 11 | 13th October 2007 01:15 PM |
