Got a question about the serial output of a microcontroller
I want to make a serial output signal, so that i can send a couple of pulses serial. The puls patron must be variable. after making one serial output signal, i want to make a sort of a splitter between 6 channels. so that i can lead the signal through one of the several channels. so the purpose is to create 6 serial output signals out of 1 serial output of the microcontroller. I was thinking about SPI or UASART. It's for demonstrating some different output signals to a scope. Why i don't use 1 channel and change the serial software registers ? because to each output a different distortions will be added. Some suggestions for solving this problem? |
You must be a hardware guy.
Use software to simulate as many serial outputs as you like. Most C compilers include them in their library. Many examples of them on the net. Also know as "bit bang" or "bit banging" or "software uart".
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
Yes i am!
So i can simply made 6 serial output signals out of one microcontroller. because there is only one or two usart or spi modules on the microcontroller, i have to do it with a shift register (created in software)? Something like this: http://en.wikipedia.org/wiki/Bit-banging ?? Thanks for helping me out |
| 32 Bit Serial IO Expander Firmware Check | freeskier89 | Micro Controllers | 4 | 30th June 2006 09:14 PM |
| ezVID serial TV output module | jrz126 | Micro Controllers | 5 | 11th February 2005 02:41 PM |
| Serial to parallel output | cwt | General Electronics Chat | 1 | 25th June 2004 06:27 AM |
| 8051 microcontroller reading data from serial port | godatguitar | Micro Controllers | 11 | 17th February 2004 08:03 PM |
| Serial Mouse - Suitable Microcontroller? | swamytk | Micro Controllers | 2 | 16th June 2003 02:04 PM |
