Old 13th February 2008, 10:02 PM   #1
Post i want to make 1 GB OR 2 GB PENDRIVE..PLZZ...HELP ME
HELLO,
FRNDS,
i want making a pen drive like 1GB, 2 GB, 4 GB, 8 GB, ETC...( any one pen drive out of this)...... if any one know perfectly ...abt this issue...... so....plzz.......help me.....and suggest me.....that how can i make this type flash drive ( pen drive )....
1) what type microcontroller very much suitable ??....
2) and then why we start first process meking code and programming..........what type programmer we used?...........tell me..........all necessery things .........plzz.......
regards,
frnd9765421
frnd9765421 is offline
Old 13th February 2008, 11:08 PM   #2
Not a hobby level project, but the good news is you can buy one cheap. Far less than what you could build one for! Isn't that wonderful news
Bill
Smart Kits build Smart People
Old 13th February 2008, 11:21 PM   #3
Yeah, you can buy a 1G for 5 bucks. No joke.
IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
Krumlink is offline
Old 14th February 2008, 02:53 AM   #4
As long as the Pen is the legal age, sure I see no reason you cannot make it drive. But what car what car...
donniedj is offline
Old 14th February 2008, 05:40 AM   #5
I suppose for a very first time you could do something with the flash modules that Atmel sells over at http://atmel.com/dyn/products/devices.asp?family_id=624 .
Salgat is offline
Old 14th February 2008, 07:38 AM   #6
Smile very simple...
very simple...
Take the flash out of the pic microcontrollers... collect them .... interface with each other...
Try your best...
Regards,
Simran..
Simran..
8051 Specialist..
simrantogether is offline
Old 14th February 2008, 08:31 PM   #7
Post
Originally Posted by simrantogether
very simple...
ok......but how can i interface ?........and tell me the link where i can collect information abt my project and tell me that can i use 8051 , or ATmega 32 microcontroller???? to make my project ( 1 GB, or 2 GB, ETC..PENDRIVE)
OK....SO...help me some information .....in this feild i m new .......so........first tell me ......that first what's type basics i m read completely that useful abt my project ....ok..
thanks 4 ur rply.......and fast me ur next rply.....frnd....simran.thanks...
REGARDS,
FRND9765421
Old 14th February 2008, 09:54 PM   #8
The question is why? Is it a school project?
Bill
Old 14th February 2008, 10:27 PM   #9
Start by reading the spec sheets from the manufacturer websites. Then search google and find some simple projects. You will have to start with the basics first. A usb interface is not easy. If you try doing that as your first project you will have lots of problems that you would learn to avoid by starting with simpler projects. Take small steps.
Ambient is offline
Old 15th February 2008, 06:02 AM   #10
Smile Well...
REGARDS,
FRND9765421
Well i am sorry... my this given formula will not work... as flash of pic microcontrollers or any other are inseparable...
I hope you understand...
Better follow this:
take an eeprom ( I2C ) interface it with PIC 18f microcontroller and then interface usb slave with PIC 18f microcontroller...
Regards,
Simran..
Simran..
8051 Specialist..
Old 15th February 2008, 05:17 PM   #11
@OP
if you read in the datasheet for the 18f, it has a special mass storage mode and a dedicated 8 bit bus for transferring data from the host to a sram / nand chip. the 18f cpu handles the handshaking and then a special module inside the 18f handles the actual transfer, eliminating the slow cpu as a bottleneck.
the 44 pin pic and single unit ram chips should only cost 5x what you could buy a real flash drive for
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 15th February 2008, 09:38 PM   #12
Post
Originally Posted by justDIY
@OP
the 44 pin pic and single unit ram chips "" should only cost 5x what you could buy a real flash drive for ""
FRND, justDIY, plzz,,,specify me clearly that u told me in this inverted comma .........
what u say to me ??......i don't understand it........ok
so....plzz specify inverted comma lines..........
u told me that i buy the real flash drive .........frnd i know that i can buy real flash drive but i want make an Autonomous robot with a cam and i interface my custom pen drive ( that i discussed it here ) and i want to store video/photos in my custom pen drive .....ok.......frnd
so....understand me.......and ......tell me my questions right ans..ok.......if u can...
don't any other suggesion me..........ok......frnd........
so.........thanks...........and enjoy ur life with electronics...........byee
REGARDS,
frnd9765421.
Old 15th February 2008, 09:54 PM   #13
It's a silly idea, use an SD memory card instead - a LOT simpler.
Old 16th February 2008, 11:42 AM   #14
Hellll Yeah.... Lot Simpler
Pasan...
pasanlaksiri is offline
Old 16th February 2008, 12:14 PM   #15
Why would you want to when you can buy one that will be alot smaller than anything you can make by hand?
HerbertMunch is offline
make, pendriveplzzhelp
Need help to make simple scoreboard with LEDs rydad Electronic Projects Design/Ideas/Reviews 15 5th July 2009 12:01 AM
How to make a 12 hour clock IlordrossI Electronic Projects Design/Ideas/Reviews 13 27th June 2007 01:11 AM
Car Adapter for Laptop-How to make? Bill_activist Electronic Projects Design/Ideas/Reviews 4 1st April 2005 08:37 AM
ps/2 keyboard to usb adapter, how to make bd13 Electronic Projects Design/Ideas/Reviews 3 7th October 2004 09:53 AM
Make exciter 0-40W RF moutouloss Electronic Projects Design/Ideas/Reviews 1 30th September 2004 03:27 PM
