Old 10th February 2008, 02:06 PM   #1
Unhappy Easy to make PIC programming
Hi
As the title says. Im looking for a easy to make PIC programming circiut.
I have found one @ oshonsoft but the PCB layout (wich i need to be in bottom layer only) becomes so large with traces going all over the place.
Does anyone have a similar circiut (serial is prefered but not a must)
The best is yet to come
Good enough - its perfect !!
2 Gig of free online backup space
cq cq de LA3BNA
Kryten is offline
Old 10th February 2008, 06:24 PM   #2
Post Use Nigel's
Use Nigel's Tutorial boards. They are built with strip board and give you a variety of things to plug into them.
http://www.winpicprog.co.uk/pic_tutorial.htm
If you have questions, a lot of us, including Nigel hang around here.
August Treubig
AG5AT
August Treubig is offline
Old 10th February 2008, 06:26 PM   #3
Default If you mean a programmer
If you meant a programmer, rather than pic boards themselves. I built the programmer part of Blueroom's Junebug on stripboard. Or you can just get the whole kit from him. It runs under $50 US.
August Treubig
AG5AT
Old 10th February 2008, 10:26 PM   #4
I build the 16PRO40 programmer on stripboard.
OY2L is offline
Old 11th February 2008, 05:56 AM   #5
Smile Well ...
Please see this page:
http://www.kmitl.ac.th/~kswichit%20/ezpic/index.html
Software : ezPIC works with ' IC - Prog 1.05 D ' which you can download from
http://www.ic-prog.com/index1.htm
Regards,
Simran..
Simran..
8051 Specialist..
simrantogether is offline
Old 11th February 2008, 08:44 AM   #6
Well again I see that I have expressed my self in an unclear matter......
I mean the Unit that you either put the PIC in or connect to the PIC in circiut to download the program to the PIC so Simrans post is what im looking for i think..
cq cq de LA3BNA
Kryten is offline
Old 11th February 2008, 09:15 AM   #7
Does it only work with version 1.05D??
cq cq de LA3BNA
Kryten is offline
Old 11th February 2008, 09:49 AM   #8
It will work with other versions but don't know when it will stop work.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 11th February 2008, 09:50 AM   #9
Ahh so to be sure it will work allways i should use 1.05d ? but i can try others to see
cq cq de LA3BNA
Kryten is offline
Old 11th February 2008, 10:03 AM   #10
Smile
Well you can see on this written on the bottom of the thumbnail...
and the version of ic-prog you can see on the window opened in the thumbnail...
Regards,
Simran..
Simran..
8051 Specialist..
Old 11th February 2008, 10:18 AM   #11
Oshonsoft programmer is superior compared to sunrom which happened to be a JDM. JDMs behave erratic at times.if it works well with 1.05D also works well with V1.06A.
Instead try to settle for PICKIT2 or its nearest compatible JUNEBUG. I made one and is really fantastic. Afterall, it is a one time investment and software upgradable.
Regards,
Sarma.
mvs sarma is offline
Old 11th February 2008, 02:01 PM   #12
I agree.
You can not build a Junebug without another programmer to flash the PIC18F2550 in the Junebug. If you want to go the DIY route you need to build a programmer that does not use a processor prior to building the Junebug. The Junebug/PICkit2 is worth the effort. It also allows you to do in circuit debugging (ICD) and program serial EEPROMS.
BCHS/3v0's Tutorials
3v0 is offline
Old 11th February 2008, 05:46 PM   #13
So if I got this correctly then the Oshonsoft is the way to go (since I allready have made a PCB Layout for it) I have looked at the Junbug but i thought that I need a programmed PIC
cq cq de LA3BNA
Kryten is offline
Old 11th February 2008, 05:54 PM   #14
Yes you need a preprogrammed PIC with either the Junebug or Inchworm, sort of a chicken before the egg thing. Most people who have bought or built them are already JDM or other simple PIC programmer users that want something modern. Some users even post their homemade versions here.
JDM is a bear to get running on a modern PC, worked great on computers 10yrs ago. BUT if you've got an old PC with win98 and a real serial port then you could cobble a JDM together pretty easy and then use it to program the 18F2550. Of course the kit comes with a programmed 18F2550 (shameless plug)
Bill
Smart Kits build Smart People
Old 11th February 2008, 05:58 PM   #15
Ok but this is supposed to bee as cheap as possible beeing a school project.
Althou I will look in to the Junbug thing
cq cq de LA3BNA
Kryten is offline
easy, make, pic, programming
PIC C programming ahmedragia21 Micro Controllers 4 15th November 2007 07:15 PM
Best Pic Basic Compiler ... simrantogether Micro Controllers 12 29th October 2007 08:52 AM
UNIT Committment solution using Dynamic programming arijit18 Electronic Projects 1 18th October 2007 09:28 PM
Battery Tester with a PIC 16F818 Cicuit Question dmarciano Micro Controllers 1 9th October 2007 05:41 AM
If anyone is looking for an FM receiver to make..please read brancambre500 General Electronics Chat 2 21st January 2003 09:20 PM
