hi thr i need assembly code how to send serial data with pic 16F84a i wana pin RA3 to be the output for serial data also i want know how to generate clock pulse for with pic which is will be same time with send with serial data i wana use pin RA2 for tht | |
Check my PIC tutorials, although it's not very clear what you want to do?.
| | #3 | |
thanx i was looking this part Quote:
i want send the serial bit through pin RA3 to serial LCD my 1st frame will be as this 00010 0001 but LCD also require clock pulse and this pulse should be synchronize with serial data i want this pulse generate when pic start RUNing i hope u can help me in this when i finish this i will put complete one there | ||
It's still unclear what you're trying to do?, is it send syncronous serial?, and what's it got to do with an LCD?.
i am using nokia LCD 3310 and it is has this pin SCLK Input for the clock signal: 0.0 to 4.0 Mbits/s. D/C LOW command mode or high DATA mode SEC The enable pin allows data to be clocked in. The signal is active LOW RES RESET SDIN 8 bit serial DATA in i did every thing just remaining that there should be clock pulse for LCD i want RA4 to generat clock pulse 4 LCD (am using 16F84) some one told that i can use 16F877 which has bulid in clock pulse out which is pin RC3 i hope i make clear 4 u | |
| | #6 |
Isn't this just SPI?, try searching for examples, and I think the 877 has it in hardware?.
| | #7 |
i found that i can do that with 16F877 but i want know if it is posible to do it with 16F84 and thax | |
| | #8 | |
| data, pic, send, serial |
| HD44780 lcd help | jay543_uk | Micro Controllers | 12 | 8th November 2007 04:26 PM |
| Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) | smilen | Micro Controllers | 15 | 21st November 2005 10:23 AM |
| How to get an HC11E to send data through a COM port? | Thedoctorisin136 | Micro Controllers | 2 | 14th April 2005 01:41 PM |
| Serial Data Logging Software | Monkeyman87 | Micro Controllers | 8 | 12th October 2004 04:32 PM |
| 8051 microcontroller reading data from serial port | godatguitar | 8051/8951 | 11 | 17th February 2004 09:04 PM |
