Is it possible to make a program and choose uC afterwards?
Simplicity rules Good enought - its perfect ?? 2 Gig of free online backup space Are you a Chemist? |
Yes, as long as you choose the uC that you wrote the code for!
I would think of it as more of a neat trick than something you'd want to actually do. And it certainly would be easier for a beginner to just rewrite the code for each target uC. It might be realistic for a large codebase which needs to have the ability to use newer versions of an architecture while maintaining compatibility with existing/older ones. Then again, it might not*. Torben [Edit: *: Then again #2: but that's not really the same thing as having one codebase target i.e. AVR, PIC, and Z80 anyway.] Last edited by Torben; 31st January 2008 at 08:21 PM. |
well if i choos a PIC family (i.e PIC16FXXXX) does they have the same set of instructions? When using C code?
See two cases are there... if you write in c language then you can change your microcontroller whenever you want... from pic to avr to zilog to anyone... when you want to choose a microcontroler among any of the pic then you can write the program in both assembly and C and then can choose the microcontroller... All you need is to change the include (header) file on changing the controller... Regards, Simran..
Simran.. 8051 Specialist.. |
Ok well i see i need to specify my questions better
This is what i asked on the top !! Edit: What program do you sugest for making the firmware??
Simplicity rules Good enought - its perfect ?? 2 Gig of free online backup space Are you a Chemist? Last edited by Kryten; 8th February 2008 at 11:46 AM. |
You can write code targetted at a range of uCs, as long as the code works within spec on all of them. Writing code which could run equally well on an 8051, a PIC, or an ATMEGA would be worth it only if the program didn't rely on any of the advanced features of any of the uCs. Choose the environment and code to it. Within a family (like PICs) you could do some makefile magic to make it work, but I don't think it would be worth it. Torben |
You need to bear in mind that while C is far more portable than assembler, it's not really that portable, particularly for micro-controllers, where their specific requirements modify the language accordingly.
Torben |
Well Sir,
I feel it is a good habit of using the assembly language... C is a good language but at least you have to master one industry microcontroller first... hence start with assembly... Regards, Simran..
Yes sir Simran. In school we have used ASMide with the MC68HC11 (thats with Assembly code)
So am familiar with assembly coding.. Have just started C programming now the easy stuff such as definng the different Analog inputs and setting the AD converter on them
Im aiming at using the PIC16 family as i need a ADC that has hig resolution cos im measuring 100A @ 2.5V (hmm must aplify it a bit )
(permalink) | ||
Torben |
What is the budget for this project? There are things out there called SBCs (single-board computer) and SOMs (system on module) which include a processor and several peripherals such as serial, USB, and I/O ports; SD card drives; higher-resolution ADCs etc--but the ones I know about start at around $100 US. Depends on your budget and how much of it you want to do yourself, really. Torben |
| Question about Inchworm+ | Quan | Micro Controllers | 54 | 28th October 2007 12:20 AM |
| UNIT Committment solution using Dynamic programming | arijit18 | Electronic Projects | 1 | 18th October 2007 08:27 PM |
| my first 16F88 has me stumped | Hank Fletcher | Micro Controllers | 15 | 3rd August 2007 03:21 PM |
| Programming languages | sram | General Electronics Chat | 9 | 2nd March 2007 04:14 PM |
| Good Computer Programming Book | ThermalRunaway | Chit-Chat | 21 | 16th September 2005 10:05 PM |
